06-28-2019, 04:25 AM | #1 |
sunjas
Rep 97
Coding
Hi All,
Another coding question (no doubt there are loads already on the forum): Just wanted to ask from people's experiences which coding software is best (and easiest) to use, i.e. Bimmercode or Carly or another? Also do you have to use the recommended Bluetooth adaptors for each, or will a 'generic OBD2' Bluetooth adaptor work just as well? For example, something like this: https://www.gearbest.com/car-gadgets...ml?wid=1433363 Can anyone recommend a relatively cheap Android OBD2 Bluetooth adaptor that will work with either Bimmercode or Carly (or both)? Thanks. |
06-28-2019, 04:52 AM | #2 |
Rep 243
Drives: BMW F82 M4 Competition Pack
I use the carly app and carly adapter. I'm not sure on its quality but seems straight forward to use.
The carly adapters are about £60 on Amazon. I have heard that Carly are slow at updating the ECU's when BMW update their software. |
06-28-2019, 04:56 AM | #3 |
Rep 2,444
Drives: 2018 630iGT sport
Can't comment on Bimmercode, but heard good things.
Carly, you're better off paying for the genuine adaptor (I did) - with generic ones, they can often not fully communicate with all ECU's. You won't know until you've tried. Personally, I don't think it's worth skimping on the adapter for either - you're going to be fucking about with the brains of your car, so you want proper/decent and stable communication between the adapter and your phone to minimise the risk of something screwing up. Any cost will be offset by the savings you'll be making by doing codings yourself. |
06-28-2019, 11:19 AM | #4 |
Rep 232
I've only used BimmerCode. After some initially faffing around connecting to the OBD adaptor, it's very easy to use. There are a few decent YouTube videos too if you get stuck.
06-28-2019, 11:31 AM | #5 |
Rep 32,881
Definitely Bimmercode
You only need a cheap adapter like this one for F series cars: https://www.amazon.co.uk/dp/B075MBZ8..._LcKfDbTJFDD9V |
06-28-2019, 11:34 AM | #6 |
Rep 1,049
Drives: F31 320D Xdrive Msport+
Another Vote for BimmerCode here and also the other app for fault diagnosis and new battery coding BimmerLink
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
06-28-2019, 01:54 PM | #8 |
Rep 8,493
Another preference for BimmerCode for coding. I've used both.
06-29-2019, 03:20 PM | #10 | |
Rep 1,799
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
06-29-2019, 06:30 PM | #11 | ||
Rep 32,881
06-30-2019, 03:07 AM | #12 |
Rep 1,992
Drives: F30 335d
Esys and ista for me, because it was free and I'm a tight arse adopted Yorkshireman.
06-30-2019, 03:25 AM | #13 |
Rep 297
I use Bimmercode and on the odd occasion where things didn't go to plan I requested help from the app and Stephan the developer was very quick in his response and resolved the issue. Requesting support from the app sends the data logs as well so he can see exactly what has happened.
Also Bimmercode is a one off payment where Carly is an annual subscription. |
06-30-2019, 03:52 AM | #14 |
Rep 1,049
I use this Bluetooth dongle for both BimmerCode & BimmerLink works flawlessly with both iPhone & iPad just charge either to 100% put into aeroplane mode then connect to dongle via BT.
07-01-2019, 01:02 PM | #16 |
Rep 1,799
I’ve downloaded the latest Esys software but for the life of me can’t get the Launcher to work - I previously coded 4 F31’s without problem but this has me beaten at the moment. Hence why I am tempted by Bimmercode & a dongle.
07-01-2019, 02:49 PM | #17 | |
Rep 2,444
I agree, I wouldn't pay £60 annually or whatever now, that's daft. |
