BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Umm, so I havenít tuned my F30 yet. But...
      07-26-2019, 03:47 PM   #1
F30_Joey
Drives: 2015 BMW 328xi
I took my car to dyno day (it was a warm night) and I was expecting low numbers because I didnít have an upgrade intercooler and had a stock down pipe. Could anybody explain this dyno to me?
Mods: CAI and Muffler delete are the only engine mods Iíve done.
I know the car (Stock) is suppose to make 240hp and 255 lb-ft tq but why am I trailing 365 lb-ft tq?
The Lower Hp number of 220 is explainable because it was hot and Iím running a stockie cooler.
      07-26-2019, 06:24 PM   #2
T5viggen
Drives: F30 335i
The above dyno
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3ís | Vorshlag Camber Plates
      07-26-2019, 06:31 PM   #3
fantanas
Drives: F33 435d
It seems that the torque is shown in Nm instead of ft lbs....
      07-26-2019, 06:55 PM   #4
F30_Joey
Thanks! I was thinking it was in ft-lb but itís a little strange they would do that. Thanks for the answer!
      07-26-2019, 07:43 PM   #5
Enabled
Drives: 328xd Wagon, M2 Competition
Tell them to set up the dyno printout better, and give you a correct printout. Since the picture is cropped, we can't see the units they used. Newton-meters does make sense.
Also 220hp at the wheels is more than 250hp at engine, so it's actually more than the factory rating, which is typical for your altitude and the corrections used on the dyno data.
See if your dyno shop can email you the dyno run files. Then you can generate your own graphs with and without SAE corrections, in whatever units you want.
-2014 328d Wagon 2WD, 8HP flash, self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition, Alpine White. Self-tuned 530hp
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      07-28-2019, 11:58 AM   #6
jmg
jmg's Avatar
Drives: F80 M3 CS, I01 i3 REx LCI
Agreed the torque units are probably Nm and besides that dyno numbers are meant to be baselines. Tune/modify your car and come back to the same dunk to see relative gains. Even though BMW underrates their cars, your dyno numbers aren't gospel. Different dynos can give you different numbers. They are a guide.
2018 F80 ///M3 CS - Lime Rock Grey Metallic | MPE | MPHAS | GC Camber Plates | PFC-08 | RE-71R
2019 I01 i3 BEV - Giga World
Previous: F80 M3 | I01 i3 Rex LCI | I01 i3 REx | F30 340i M Sport ZTR | F30 328i Sport | Audi B7 S4 25Quattro #33 of 250 | E21 320i
      07-28-2019, 12:26 PM   #7
deviantspeed
poopycat
Drives: 2017 F31 330i
Software is called winpep:
https://www.dynojet.com/downloads/do...tware/Firmware
328xi, dyno, question
