      08-19-2018, 05:20 AM   #13685
GCUK
Drives: BMW 320d
ISTA Error
Hi, I'm having a problem running ISTA.
I follow the steps in the manual and always get the error:
Failed to start ISTA
Please make sure ISTA configuration is valid.
In doubt reset any non standard ISTA configuration and reinstall ISTA.
I have put a fresh install of windows 7 on my Laptop, downloaded the link Shawn sent me again, but no luck.
Would really appreciate any help
      08-19-2018, 11:07 AM   #13686
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
That means you are missing prerequisite software or registry entries.
      08-19-2018, 02:08 PM   #13687
GCUK
Drives: BMW 320d
Ok and how do I find out what is missing? I followed the instructions during install, really don't know what I am missing.
      08-19-2018, 03:36 PM   #13688
Almaretto
Almaretto's Avatar
2374
Tough to tell. I would have to see registry entries and screenshots of installed programs.
      08-19-2018, 07:41 PM   #13689
iAlexander
Drives: F30 320i, W211 E350
Shawn, would you be able to send the latest E-Sys and PsdZData please?
This is probably the third time I've reached out. It's been a few months since I last worked on coding my car and I decided to make some adjustments tonight but I'm stuck in the token loop again. I had it working perfectly a few months ago! Any idea how I got stuck in the loop?
      08-19-2018, 07:46 PM   #13690
shawnsheridan
shawnsheridan's Avatar
PM sent.
      08-20-2018, 09:58 AM   #13691
rambalu80
rambalu80's Avatar
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
Shawn, can you please send me the latest E-Sys and PsdZData files? Thanks in advance!
2016 BMW 340i
688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494
Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals
      08-20-2018, 10:37 AM   #13692
shawnsheridan
PM sent.
      08-22-2018, 07:13 AM   #13693
Gespar
Drives: F31 320d 2013
Hi everyone,
I recently buy F31 320d and noticed that rain sensor was missing. I did some research and found out that my car has all the sensors, wires and buttons existing but only coding is needed.
I already know from other thread what values i need to change but as a newbie i dont have any experince about coding. Ibought coding cable from ebay and next step is to get all the software and basic knowledge.
Could someone give me link to working software and guidance how to set it up?
Thank you.
Originally Posted by sdk888 View Post
Hi there,
I picked up a 2015 435i xDrive on the weekend and am looking to get stuck in with some coding. I have E-Sys up and running and am looking for the data.
Shawn - could I ask for your help please? Thnx.
PM sent.
      08-22-2018, 08:17 AM   #13694
shawnsheridan
Originally Posted by Gespar View Post
Hi everyone,
Thank you.
PM sent.
      08-23-2018, 01:44 AM   #13695
Markeris
Drives: BMW F82
Hello all,
2014 BMW F30 335i. No sport + mode. Can someone exactly tell what changes i must do? i found to many info, and i am scary to do it wrong.
      08-23-2018, 07:58 AM   #13696
garygarykun
Japan
Drives: F31 318i Touring Luxury
Will definitely go through the guide and try coding my F31 some day!
      08-23-2018, 03:33 PM   #13697
Viper4770
Drives: 2013 328i Xdrive
Enhanced Bluetooth Troubles
I recently took my car to the dealer to get them to update the istep version. However after this upgrade I can no longer get the enhanced bluetooth to work in the car the option is listed in the car however when I pair my phone it will no longer ask to stream audio as well as telephone. Any help would be appreciated as I had originally coded this feature in before the update. I'm using Psdzdata 4.12.35 along with launcher 2.8.2. When I went into the VCM to write the new values after hitting read it was listed as 10(Unknown).
Sorry if I should've included something is this I haven't as I don't have an in-depth knowledge if the coding.
      08-23-2018, 06:10 PM   #13698
shawnsheridan
What did you do exactly to enable Enhanced Bluetooth (EBT)?
You should not be in VCM at all. Where exactly do you see "Unknown"?
      08-23-2018, 06:39 PM   #13699
Viper4770
Hey Shawn thanks for replying.
I following the instructions listed here https://www.bimmerfest.com/forums/sh...96&postcount=7
On step 10
10. Click “read FA FP VIN” button and check FA to make sure changes are saved to the car.
I believe it is under vehicle profile that shows unknown after I write the modified FA to the car.
      08-23-2018, 06:48 PM   #13700
shawnsheridan
On step 10
Following those instructions should work fine. Don't worry about what FP (Vehicle Profile) shows. It's not important. All that matters is that FP Calculates without error.
      08-23-2018, 06:58 PM   #13701
Viper4770
Well unfortunately I followed these instructions and I seem unable to stream music via bluetooth any suggestions?
      08-23-2018, 07:00 PM   #13702
shawnsheridan
If it is coded, it should work. You need to unpair phone, pair it again, and make sure Music is enabled under both Phone and Bluetooth Options.
      08-23-2018, 07:33 PM   #13703
Viper4770
Thanks for all your help I just went out and tried the whole process again and its working thank you.
      08-23-2018, 08:41 PM   #13704
shawnsheridan
      08-24-2018, 11:55 AM   #13705
Viper4770
Hey Shawn the only thing I can't seem to code through FDL coding on my F30 is the Easy Entry I do not have a module called SM2 only SM however I found EINAUSSTIEGSHILFE and set it but it still will not work. Is there anything I can do to make this feature work or am I out of luck?
      08-24-2018, 12:00 PM   #13706
shawnsheridan
Sorry, but I have no idea. I never code it before.
