01-23-2020, 08:08 AM | #2289 | |
Rep 14
so you do have the version with the updated graphics? instead of blue icons the greyish icons at the start of HUR where you choose the right mode to start right? What i did with the payed version of HUR install and start android auto (5.0.500224-release APK January 22, 2020 arm64-v8a Android 5.0+ nodpi) Become developer in android auto through settings (but you all did that since it works in self mode in specific resolutions.) Then offcourse start the headunit server and exit the android auto app. Start the payed version of HUR ( i also uninstalled the trial version of HUR) tap self mode you get a few permission questions on first startup. and off you go it worked with me on every resolution and every dpi setting when i also tested the screen. Maybe try to clear the data and cache on HUR (trough android app settings) and retry the setup where you can also test the different resolutions and dpi settings again before it really starts? All i got left is an issue with waze itself but the HUR works. |
lehtee144.00 |
01-23-2020, 09:46 AM | #2290 | |
Rep 8
akirax30.50 |
01-23-2020, 10:35 AM | #2291 | |
Rep 399
Previous models of Android units were poorly designed in this regard, discussed here. I don't know if all of this is still true for our models, we need pictures or open the unit to know if proper shielding is in place now. This app can run on the phone and record mic output from the Bluetooth connected device, so you can actually hear how your voice sounds like to people you talk to. |
01-23-2020, 10:48 AM | #2292 |
Rep 79
Thank you, got it working after doing a factory reset. However I get the same issue as someone said before if u try to input an address in maps it crashes HUR.
01-23-2020, 10:55 AM | #2293 | |
Rep 2,367
Drives: E63 645Ci
01-23-2020, 11:50 AM | #2294 | |
Rep 79
There is also a bug in factory config I think. For some time people have been complaining that their sound/volume/eq settings are not being saved between restarts. I have the same issue and I also noticed that other factory settings have the same issue; for example I set the voice key to "disable", but it still opens my navi app. It looks like the headunit does not have write access to the factory_config file or something? Could the issue be that my unit is from "LS" vendor (I can see this from the MCU version string), but I am using modified factory_config which is for GS vendor? Unfortunately I don't have a backup of my old factory_config so I cannot test it. People who have issue with inconsistent factory settings: can you please report are you using original or modified factory_config from this forum,and which vendor is your unit? Also if someone has the OEM folder/factory_config for LS units, please share! Last edited by lehtee; 01-23-2020 at 11:56 AM.. |
01-23-2020, 01:05 PM | #2295 |
Rep 3
I have 2013 F30 and am looking for my first 10.2" touchscreen with latest Android, wireless Apple carplay, perhaps also LTE 4g sim slot etc. I got a bit overwhelmed by the selection in aliexpress and seems like very little information/reviews/comparisons about these devices.
I currently have my eyes on this: https://aliexpress.com/item/33027583700.html Seems like it is quite new (and expensive) version. Has there been progress beyond that device? Is there any other device that you would recommend me to have a look? |
01-23-2020, 02:17 PM | #2296 | |
Rep 79
Also someone said there will be new generation coming with Android 10 but its just rumors |
01-24-2020, 02:46 AM | #2297 |
Rep 46
Good morning, my Chinese IDrive supplied with the Android 10.25 display does not give me the opportunity to move sideways, do you know if I can replace it with the original BMW one? I could find it used but I'm not sure it can work, has anyone tried it?
01-24-2020, 03:50 AM | #2298 | |
hardware modder
26
Rep 31
01-24-2020, 05:59 AM | #2299 | |
Rep 79
01-24-2020, 08:32 AM | #2301 |
Rep 86
01-24-2020, 09:33 AM | #2303 | |
Rep 1,048
Kri |
01-24-2020, 12:47 PM | #2304 |
Rep 33
01-24-2020, 06:03 PM | #2305 | |
Rep 3
This seems like the best one in AliExpress...carplay and android9 id7, hd screen with antiglow, 4g simcard slot etc... https://aliexpress.com/item/33027583700.html Is there similar options from USA or European manufacturers? |
01-24-2020, 11:51 PM | #2306 | |
Rep 79
01-25-2020, 02:56 AM | #2307 | ||
Rep 32
01-25-2020, 03:22 AM | #2308 |
Rep 17
BMW e90 with 10.25 snapdragon android
Hi, i have this rádio on my BMW e90 2006 pré lci and its os great! But i have an issue.. when i Touch on car info ONLY appear an analog clock why? How can i customizado this to other info from the car? Thanks..
My original system was rádio professional cd73..thanks |
01-25-2020, 03:57 AM | #2309 | |
Rep 1,048
Kri |
01-25-2020, 04:10 AM | #2310 |
Rep 17
Thanks Kri, so i can't customize that ? Any solution ir another APP? Another question i have carly obd2 bluetooth..i can t pair with my android.. this is why?
