01-13-2020, 12:02 PM | #2025 |
Rep 120
01-13-2020, 12:06 PM | #2026 |
Rep 120
So for example, I turn on the car, start HUR via the navigation control while my OEM music is playing, then the left speaker stops working and the Android sound starts, then I go back, I start the Android music (those preset) and the left speaker returns to play, playing my OEM music
01-13-2020, 12:08 PM | #2027 |
Rep 6
Issue: My carplay via carlinkit (autokit) can't receive calls. When a call comes through, I pick it up via carplay interface, then no sound of any kind. This happens like 90% of the time. Anyone else having the same issue or have a solution for it?
01-13-2020, 01:05 PM | #2029 | |
Rep 1
01-13-2020, 01:11 PM | #2030 | ||
Rep 29
I don't know if they offer mics that fit your cars, but I think for f series they have one. They produce high quality sound and call systems for retrofitting cars. Maybe try to give them a shot and read a review. I ordered mine staight from amazon with prime and it works flawless LINK: http://www.fiscon-mobile.eu/products/mic.php |
01-13-2020, 01:20 PM | #2031 | |
Rep 14
Kri1083.50 |
01-13-2020, 01:22 PM | #2032 |
Rep 14
What you mean? I can since version 3.8.0 on snapdragon set Spotify as the music app. So the left music button goes to Spotify. In the big right active menu items the music player is still the default. But it helps a lot that I don't have to go to apps and then scroll to Spotify to start it. So I'm happy with that functionality.
01-13-2020, 02:01 PM | #2033 |
Rep 16
Hi all,
I have installed the Snapdragon Android 9.0 HU from AVINUSA. My car originally came with the 6,5" NBT HU and was equipped with the BMW Integrated Navigation system. After swapping the HU's, i coded the breites_display option via BimmerCode and everything just works perfect on OEM side......except the Navigation... I believe that the BMW Integrated Navigation was originally only coded to work on low resolution screens (6,5"), as it looks really messy on my new 10,25" HU. Does anyone know what I can do, to have the Navigation working on bigger HU? Coding something or...? See image attached here: |
01-13-2020, 03:18 PM | #2035 |
Rep 2,367
Drives: E63 645Ci
I give up... for now at least. I've tried few different methods of signing apk file and result is always the same: App not installed. The package appears to be corrupt.
Side note: changing file extension form .apk to .rar, replacing resources, signing app etc. works fine till I try to install it. However, when I edit app through the APK Editor and try to re-build it I end up with over 600 errors: libpng warning iCCP known incorrect sRGB profile. Pretty much every single png file I didn't touch. This could be easily ignored but APK Editor won't finish re-building with these errors present. |
01-13-2020, 04:02 PM | #2036 |
¯\_(ツ)_/¯
945
Rep 1,762
Received and installed my headunit today. I need help with the rear camera wiring.
The previous owner did install a Bimmertech MMI but it went bad. The wiring for the rear camera is as follows. - 1 cable leaving the rear camera and going to the cabin - That 1 cable splits into two: an RCA cable and a positive/ground connector - An additional cable was tapped into one of the reverse light wires and was set up front into the wire harness for the MMI. I assume this is the trigger wire. How do I connect these? RCA and ground as simple. For the red positive does that go to the red 12v cam cable from the headunit? Where does the trigger wire go? Any help would be appreciated. The car is MANUAL transmission. 6.5" headunit.
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC Last edited by Solidjake; 01-13-2020 at 04:11 PM.. |
01-13-2020, 04:12 PM | #2037 |
Rep 237
you should have a labeling on your headunit harness... Mine has reverse signal on orange cable if I remembre correctly, but I have OEM camera and didn't used it. But you have to check somehow. +12 can go to anything under ignition imho
01-13-2020, 04:14 PM | #2038 | |
Rep 16
Well, is there somehow a possibility to code the Android unit, to have two different "Car Display" settings, so it has the 6.5",10.25" setting when you enter the Navigation, and 8.8",10.25" setting everywhere else? |
01-13-2020, 04:17 PM | #2039 | |
¯\_(ツ)_/¯
945
Rep 1,762
Camera +12v Rear cam RCA in 360/camera det
01-13-2020, 04:20 PM | #2040 | |
Rep 79
01-13-2020, 04:22 PM | #2041 |
Rep 399
Is the Android camera screen activated when you engage reverse gear? In that case you can wire it up the easy way: Connect the RCA in both ends, connect the red positive split cable to the positive camera cable, and connect the same red split cable to the 12V cam cable at the other end. That's all. No need for ground, as it is connected to ground through the RCA, and no need for trigger wire.
01-13-2020, 04:23 PM | #2042 | |
Rep 16
How can i make the navi button go to Android navi instead of OEM? Couldn't find that setting og Android side, i use version 3.6.8 |
01-13-2020, 04:26 PM | #2043 | |
¯\_(ツ)_/¯
945
Rep 1,762
So just to be sure, the red positive from the camera goes to the red 12v in the head unit and the grey trigger wire from the reverse cable goes where? I really appreciate it. Parking without the rear camera sucks.
01-13-2020, 04:29 PM | #2044 |
Rep 399
You connect only cable 4 (RCA Rear Cam) and 5 (Camera +12V) in your picture. I just did this, works perfect. The Chinese have done a really great job in making it easy for us to connect a backup camera. Couldn't be easier.
Solidjake945.00 |
01-13-2020, 04:33 PM | #2045 |
¯\_(ツ)_/¯
945
Rep 1,762
01-13-2020, 04:34 PM | #2046 | |
Rep 399
Password for Factory menu is usually 1314, or 0 if you used the factory_config from Kri on this forum. |
