01-13-2020, 04:53 PM | #2047 | ||
Rep 16
When i am on Android side, it opens Android navi app (i use Waze), but if i am on OEM side, first click on Navi Burton opens OEM Navigation, second click opens Waze |
01-13-2020, 05:15 PM | #2048 |
Rep 79
01-13-2020, 09:14 PM | #2049 | |
Rep 80
Finally, on your headunit with Lucky Patcher's signature verification disabled simply install it. If you send me the apk I can try adding a toast on start and send it back to you. Just make sure you have a way to recover the headunit if the installation doesn't go through correctly. |
RedErik1023.50 |
01-14-2020, 01:13 AM | #2050 | |
Rep 2,367
Drives: E63 645Ci
01-14-2020, 02:03 AM | #2051 |
Rep 16
Yes i think so.. But still, i think it would be the best workaround if it is possible to code the Android unit, to have two different "Car Display" settings, so it has the (6.5",10.25") setting when you enter the Navigation, and (8.8",10.25") setting on rest of the OEM side.
01-14-2020, 04:23 AM | #2052 |
Rep 80
Quick question for all the experts around here.
I'm looking at buying the Navifly snapdragon unit for my E91 with CIC: https://www.aliexpress.com/item/32900353654.html (4G/64G LTE for CIC) Since it comes with LTE for internet connectivity do you think I need to worry about also getting a USB Android Auto adapter like this one https://www.aliexpress.com/item/33034329378.html or I will be pretty well covered? Btw, it's been insane combing through AliExpress to find the right version... So many clones and not so clones. Eg Andream was offering only the PX6 version for cars with CIC. I was happy to finally find the above one that offered snapdragon for CIC. |
01-14-2020, 07:40 AM | #2054 | |
Rep 2,367
Drives: E63 645Ci
01-14-2020, 08:20 AM | #2055 | |
Rep 5
01-14-2020, 08:45 AM | #2056 | |
Rep 80
01-14-2020, 09:00 AM | #2057 | |
Rep 120
01-14-2020, 09:13 AM | #2058 | |
Rep 2,367
Drives: E63 645Ci
01-14-2020, 09:48 AM | #2059 | ||
Rep 1,048
i also tried installing this time, there does come a parsing error Quote:
Your Thumbdrive is Fat32 ? , file path is Drive:\OEM\splash.img ? There does no message appear that the file has been sucesfully importet, just wait some time and do a reboot. Oh, and this method only does work for snapdragon afaik ! Kri |
RedErik1023.50 |
01-14-2020, 10:10 AM | #2060 | |
Rep 2,367
Drives: E63 645Ci
Interesting thing is that when I run verification process on stock app it throws errors. To me it looks like there is something wrong with this app, yet somehow it works when installed via OTA update... or I'm stupid. |
01-14-2020, 11:09 AM | #2062 |
Rep 44
to what and how did you connect your rear view camera? and if the Android automatically switches to reverse gear, I don't need a det cable connection or? Did you also install a filter or relay? My picture always disappeared (was switched to reverse light)
01-14-2020, 12:16 PM | #2063 | |
Rep 2,367
Drives: E63 645Ci
For Android Auto to work with your phone, you need to emulate its service on the unit and pair it with your phone. To emulate it you need HeadUnit Reloaded app installed. Edit: I'm not running Android Auto myself. I just don't find it appealing. If you need detailed information I'm sure others will be willing to help. |
01-14-2020, 01:07 PM | #2064 | |
Rep 399
Just browsing through your bug/wish list. Did you know that this functionality can be achieved by selecting OEM Camera (Settings, System, Camera selection)? I tried this today, and it works. |
01-14-2020, 01:54 PM | #2065 | |
Rep 1,048
Yesterday i had the same idea and testet it sucessfully In Addition i`m thinking about, what if i code also front PDC into my car, will it then be active until i drive +15 km/h ? But i can`t try the moment as i`m not able to code my car at the moment :/ Kri |
01-14-2020, 03:15 PM | #2067 | |
Rep 399
01-14-2020, 03:26 PM | #2068 | |
Rep 1,048
I then did the same procedure with kswplauncher, and also no error message. But the app does still not start, maybe something else , not signing related does prevent it from working ? Kri |
