12-04-2018, 04:04 AM | #133 |
Rep 500
Remember to measure the distance with measuring tape if you use Audiotec Fischer standard profile. It does make a big difference in imaging. Also, you can tweak the bass boosted 3-6 db by taste and shelf filter at 5k and above by -3db. Hope you are satisfy with simple amp swap.
12-04-2018, 08:19 AM | #134 | |
Rep 1,911
12-04-2018, 10:53 AM | #135 |
Rep 16,138
Only for the driver. For every other seat position it's worse. That's OK if you seldom have passengers, or if said passenger is female, as females in general really don't care how it sounds. That's not a sexist remark, it's a well documented fact. If it were not there would be no such thing as WAF with respect to audio.
12-04-2018, 11:14 AM | #136 |
Rep 1,911
...I need to recruit some more females to confirm on this sound quality issue😉
Correct re:time alignment- one tweaks system to optimize sound at single 'focal point'. |
12-04-2018, 02:43 PM | #137 |
Rep 16,138
Women for the most part have the Fernando attitude towards audio: "I don't care if it sounds good, so long as it looks good', though many won't even accept good looking audio gear, preferring invisible. They're not great fans of lots of bass either. Deep in their genetic memory the rumble of low bass means approaching danger, in the form of anything from lightning to a woolly mammoth to an earthquake. Men have the same genetic memory, but to them an approaching herd of woolly mammoths or giant bison didn't mean danger, it meant dinner.
pierreye212.00 |
12-04-2018, 03:01 PM | #138 | |
Rep 66
12-04-2018, 03:09 PM | #139 |
Rep 1,911
Physical Distance from each set of speakers to your listening position. Plug that info into the DSP's programming software and the software will translate the relative physical dimensions to the appropriate time delay- so that sound from the various speakers reaches your ears at same point in time.
This is part of creating an effective 'sound stage' - you basically are creating a situation where your ears perceive the sound coming from on top of car's dashboard, like musicians are up front performing as they do at a concert. This is a good configuration if you as driver are the only person in the car most of the time. If you want rear seat passengers to have decent sound you'll have to alter your setup to accommodate that situation. |
12-04-2018, 06:25 PM | #140 |
Rep 500
I normally prefer driver seat. Wife and kids wouldn't care much. Well, kids like heavy bass but they don't know what is good imaging. Measure the tweeter to between your two ears.
12-04-2018, 06:27 PM | #141 | |
Rep 500
12-06-2018, 03:18 PM | #142 | |
Rep 66
a. Stick to the OEM woofers b. Go for the Focal ifbmw-subv2 c. Pick the Earthquake Sound SWS 8Xi (2ohm) d. Get the Earthquake Sound SWS 8X (4ohm) - cheaper What would you do, how to marry this 2x160w (for the woofers) amp? |
12-06-2018, 03:53 PM | #144 | |
Rep 66
So you think that the improvement offered by the replacement under seat woofers is negligible, really helpful, this avoid throwing away money. And what would be a decent setup of a trunk woofer, something that can be installed in a corner with an amp that is plug and play? I don't like wireing and I just hate to pay for this kind of work. |
12-06-2018, 05:20 PM | #145 |
Rep 16,138
I know that there are custom made subs that fit behind the left wheel well, you should be able to search them out. As for plug and play that I can't say.
12-06-2018, 06:08 PM | #146 | |
Rep 500
I'm getting the Bimmertech Alpha One underseat sub to replace in my F10 L7 Top Hifi sub. I'll let you know if that make a difference. |
12-07-2018, 11:01 AM | #147 | ||
Rep 66
12-11-2018, 11:15 AM | #148 |
Newbie to G30
Rep 37
Gents,
I have the G30 530e base system, need to upgrade ideally without spending too much. I fear putting an AMP will require a lot of wiring which will mean a lot of time taking off the trims to get to the trunking. Is there an easier way of upgrading? |
12-11-2018, 11:40 AM | #149 |
Rep 16,138
Since the amp is the weakest link of the system it's the first thing that needs replacing. With the base system, assuming it's the same as that in the F30, you actually have an advantage, because you have no separate amp. That means you can use a much less expensive amp than those required with the higher end systems. Check this out:
https://f30.bimmerpost.com/forums/sh....php?t=1475424 As for the need for wiring changes that's non-negotiable. |
12-11-2018, 01:00 PM | #150 |
Newbie to G30
Rep 37
Thank you for the reply. What AMP would you recommend in terms of a mid-range with DSP and one that is going to be the best option if i decide to upgrade the system further at a later point.
12-11-2018, 01:53 PM | #151 |
Rep 16,138
Not being in the UK I don't know what's available to you. In the US I'd be looking at this for a DSP: https://www.parts-express.com/dayton...audio--230-500
Perhaps this for an amp: https://www.parts-express.com/re-aud...fier--268-8207 |
12-12-2018, 07:25 AM | #153 |
Rep 16,138
Thanks, but I'm no audiophile, I'm an acoustical engineer. The two terms are pretty much mutually exclusive. This is why:
Onizukachan1118.00 |
12-14-2018, 08:03 PM | #154 |
25cent millionaire
253
Rep 1,220
Drives: 2020 m4 comp vert
just ordered a set of Rockford p3 shallow 8 2ohm versions, lets see if they can due any better than those helix d200s I had in there.. I will advise... 190 watts per driver, 60 to 350 hz 24db/oct.
