01-16-2020, 12:58 PM | #89 | |
Rep 1,934
01-16-2020, 01:33 PM | #90 | ||
Rep 3,540
For other applications, like a sway bar end link, the load is perpendicular to the threaded rod coming out of the ball joint and there's much more surface area supporting the load.
01-16-2020, 08:52 PM | #91 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
https://www.dinancars.com/product/d1...0i-335i-335is/ I feel like it would be a perfect solution for most people who just want 1.5-2 camber and stock NVH levels. |
Littlebear3511.50 |
01-17-2020, 09:31 AM | #92 | |
Rep 891
If you open the hood and look at the top hat on an F, there are aluminium extrusions that completely fill the circumference of the opening in the strut tower on the chassis and the tower itself is hardly larger than the entire plate. A plate like the Dinan would only work if it also functioned as a spacer to clear the extrusions but that doesn't solve the overall tower size limitation. Additionally, BMW integrated the stabilizer bar mounts on the top hat so those would no longer be usable. In short, there are a lot of reasons why it won't work. Next best option are these Millway plates
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 01-17-2020 at 09:51 AM.. |
Nugget649.50 |
01-20-2020, 12:36 AM | #93 |
Rep 3,540
Just got the Millway Street camber plates installed today. Props to Samuel for getting them to me so quickly!
Some observations: -The plate height is indeed the same 10mm thickness as the OE top mount. -It's easy to take apart the sliding mechanism and replace the damper piston shaft mount and polyurethane buffers if they ever wear. -The screw HW supplied are 6mm hex, grade 8.8. Personally I hate hex for things that need to get torqued to spec, and I'm wondering why the HW is grade 8.8 when the OE bolts are grade 10.9. -I've asked Samuel if there's any issue with running the OE bolts. I don't think there should be since they're the same thread size and pitch. They will protrude past the bottom of the plate below the shock tower unlike the bolts supplied, but that doesn't seem to be an issue when I took a look. I've only driven a bit around town so far, but I'm impressed with how little change there's been in NVH. I actually can't even tell if there's been any change from my setup before. I'll leave the possibility that if you have OE bushings for the tension strut you may have a small increase in NVH, but if you already have monoballs like I do, you might not notice anything. It'll be interesting to see the data I collect on my commute this week. Video to come...
01-20-2020, 12:49 AM | #94 | |
Rep 1,294
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
01-20-2020, 11:42 AM | #95 |
Rep 681
Would be nice if we can use OEM bolts because the provided washers are a bit small and don't bite well on strut bars. If we can use OEM bolts, i'll swap mine out asap.
My replacement bearings from Millway have shipped as well. Will update when I get them in and the car apart to see how the (currently installed) bearings have held up.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
01-20-2020, 01:29 PM | #96 |
Rep 3,540
Samuel got back to me on using the OE bolts.
There's no problem using the OE bolts, BUT you have to make sure that none of them protrude below the bottom of the plate and interfere with the camber slider and thrust bearing as camber is adjusted. In my case that means the two bolts on the engine side of the plates have to be the shorter Millway ones. I'm going to swap the others for the OE bolts though.
andino479.50 |
01-20-2020, 06:02 PM | #97 | |
Cheapskate
4455
Rep 4,995
01-20-2020, 09:23 PM | #98 |
Rep 3,540
Lower grade, and for those of us using strut tower braces the screws are a bit short (not as much thread engagement) and the washers aren't quite wide enough to bite down on both sides of the material due to the smaller OD. Plus I hate how easy smaller hex bolts strip compared to larger sockets.
01-22-2020, 04:47 PM | #99 |
Rep 15
Hi guys. Thanks for giving us feedback about the bolts.
There is one reason we supply the bolts instead of just using the OE-bolts. That is because the design is made to be exactly the same height as OE top mounts. I don´t think any other has that important feature. That means that the bolts that is in the direction of the camber change comes in the path of the OE-plastic bearing. So the 5-hole cars need to have 2 bolts per side shorter. The remaning 3 can be OE-bolts. We have discussed earlier if we should supply only the 2 bolts that is mandatory to change. But some people like the look when all five are the same. One option could be to install several thick washers and use OE-screws. But since the OE is a little conical in the end it is a bit risky. Regarding the 8.8 and 10.9. We had 10.9 before. The difference is that a 8.8 should be torqued to 24Nm and 10.9 to 30Nm. The goal is always to have a stretch in the bolt. So a 10.9 with 24Nm is not as good as a 8.8 with correct torque. We have a stainless thread insert with locking function in the camber plate that we think works really good with 8.8 but 10.9 could also be used. I really appreciate your feedback and will see if we can fulfill the desire for different screws in the future. |
01-22-2020, 05:00 PM | #100 |
Rep 15
01-22-2020, 05:47 PM | #101 | |
Rep 3,540
01-28-2020, 12:57 AM | #102 |
Rep 3,540
I've put up my video on the "street" camber plates:
01-28-2020, 08:45 AM | #103 |
Rep 272
01-28-2020, 08:52 AM | #104 |
Cheapskate
4455
Rep 4,995
adding camber with plates is ok because it shortens the length of the axle. The problem is making the control arm longer lengthens the axle, reduces engagement, and can cause damage.
01-28-2020, 09:16 AM | #105 |
Rep 272
i get that, I just didn't know if there was a limit i.e. 2 degrees is okay but 3.5 will bind the axle when cornering.
01-28-2020, 01:04 PM | #106 |
Rep 3,540
Yup xDrive. I set the front to -2.5deg.
01-28-2020, 04:08 PM | #107 |
Rep 681
I've been running mine on xdrive for a while now. I run -2.5* as well up front without issue. I've run mine for about 10k miles now through varying conditions without trouble. Keep in mind, I have the monoball plates and not the street ones but functionally, they're the same albeit just some more NVH.
2006 997.1 C4S |
01-29-2020, 09:15 AM | #108 |
Rep 787
Thanks for trying these out. I'm looking forward to hearing your experiences after you've run them for a while
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
02-03-2020, 01:08 PM | #109 |
Rep 77
For those with camber plates set at relatively high negative front camber (compared to stock or what can be achieved with eccentric bushings), have you tested different front toe settings? I.e., does the inward camber thrust from ~-2.5 degree camber warrant/allow slightly less toe in without making the car too darty?
02-03-2020, 01:36 PM | #110 | |
Cheapskate
4455
Rep 4,995
ktw54.50 |
