06-21-2015, 05:53 PM | #111 |
Rep 578
Well... 3 months later i finally got around to working on this project again (crazy when you become a parent how you life changes)...
After adding option 3AG & coding HU_CIC, ICM, REM & FEM_BODY... i'm getting an error: Parking AID not available, Please park unaided... something like that.... Then the image comes of the car & what should be the camera.. Crappy part is, not only does the camera not work but neither does my rear PDC... So then i tried removing option 3AG & recoding those same modules.. the camera is gone but my rear PDC is no longer working... I get the same error, the image comes on the screen but doesn't work... WTH... Some notes on my install...
some install photos to help others out... After wasting about 2 hours trying to figure out the factory location of the Camera module unit up under the driver side dash... i gave up & went to the trunk.... i went on the driver side... From the wiring harness, you run a cable to the bottom side of the fuse box.. here is the cable being installed This is a view of me routing the camera cable along the trunk arm one of the original post said it was a PITA to remove the trunk handle... from the back side you can pop out the far right piece (if looking at the trunk handle from outside the car).. then i took this plastic tool at this contact point & it came right out.. there are 4 contact points to just to both on the top side you can get to & it comes right out As the day went on (it's only 99 degress here in NC this week) i got more tired & didn't get anymore photos... this DIY is not for for the faint of heart... and to be honest, what is posted here isn't exactly a start to finish DIY.. you have to piece together several post... don't get me wrong, i would have never even attempted this if it hadn't been for the info provided but this isn't easy. |
06-24-2015, 09:52 PM | #113 | |
Rep 578
Where do you get these install instructions? I want one for the top view/surround view install. My control switch isn't lighting up &/or not working at all. I also want to review the TRSV wires. It's also worth noting that Roxxor mentions picking up the A6 & A7 (orange/green & green cable) in the IDrive socket... this install instructions has this going to Plug 173 in the Passenger footwell. Must be the same pins b/c it's working for him but just noticed that is different in my install. |
06-25-2015, 08:37 AM | #114 | |
Rep 1,480
Drives: 2020 M340Xi (G20)
Can't recall which of the two forums I got the Retrofit Instruction off of (this one or BimmerFest). While my problem with the cameras working hasn't been resolved, because the shop foreman was out for medical and my car recently had a close encounter of the rear-end kind while I was stopped at a light and is in shop -- but fortunately is mostly body work. Here are a couple of thoughts for your consideration:
When I get the body work completed will finally revisit camera hook up to prove out, if you will, my belief. More to follow Glad to help!!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
06-26-2015, 07:27 AM | #115 |
Rep 196
Hi Guys
Can I ask how are you tapping into the K Cam lines. Are you using the wire taps (Minature connectors as per BMW instructions) also known as T taps. Or another method? - Positaps (if so what model would you suggest) - Strip and solder The T taps do not get a good feedback. Thanks The |
06-26-2015, 08:01 PM | #116 | ||
Rep 578
I used the Minature connectors as per the BMW kit... Quote:
Did you get the Retrofit instructions for Surround view cameras? if so, please post it. Thanks everyone for the assistance, i want to get this working so bad... |
06-27-2015, 11:00 AM | #117 | |
Rep 1,480
Regarding the center console switch wiring, please check this post out:http://f30.bimmerpost.com/forums/sho...d.php?t=869735 Go down below the 4th installation picture, there is an explanation of the wiring. Unfortunately, I have not seen any Retrofit instructions for surround view cameras, but have seen a posting either here or on BimmerFest that helped. Will try to find
Al
06-28-2015, 11:37 PM | #118 |
Rep 578
Update
No smoking gun yet... i already had A8 to the Z2*6B fuse box. I also looked at the center console switch & it already had Pin 3 prior to my retrofit. I have to remove my center console to get to the ICM so wasn't doing that tonight. We also have a F25 X3 that has the Driver assistant package. I looked on RealOEM & saw our cameras were the same.... so i removed the camera from my car & installed in our X3 & the camera works just fine (i bought the camera used off ebay, the TRSV & console switch were both new, so was all the cabling). With the camera ruled out, it's back to the drawing board. Downloading Rheingold now, hopefully that will be a helpful tshooting tool. While i was running cables, thought i would save some time & run my cables for the front PDC... even though the one is left unconnected (i didn't run the cable through the firewall), i went ahead & connected all the wires at the REM... surely that isn't causing my issue... it hasn't been coded to tell it i have front PDC (i did thinking in needed that for the switch but then removed that option & went back to 508). Said it once before, this DIY is not for the faint of heart. |
07-12-2015, 06:52 AM | #119 |
Rep 13
With help of this posts and a (professional) acquaintance I installed a rear-view camera in my 08-2013 BMW F30. We had a fun morning and it took us a few hours to finish the job. All parts are OEM BMW, the camera and module were bought on e-bay.de, all other parts were ordered at a local BMW dealership.
I am a 'coding rookie' and only coded a few small things like start in eco-pro mode and disable start-stop. After reading 'How to change FA (VO) in F-series car Version 8-24-2013' I added 3AG to the SALAPA-Elements and clicked on the 'Write FA FP' button, following all the steps in the document. After that I restarted the unit by pressing the volume button for 20 seconds and waited a day without result. In reverse I still get the same old screen with only PDC . It is posible I bought a faulty unit or did not correctly wire the TRSVC unit, I don't know how to check this. In other words: I need some coding advise, step by step for dummies. I don't get far with 'just add 3AG and code all the necessary modules'... Any help is appreciated, a step-by-step explanation would be great! |
07-12-2015, 06:58 AM | #120 | |
Rep 40,984
You need to now Read modified FA back from VCM, and then VO Code (Right-Click on ECU => Code) CIC / NBT, PDC, and TRSVC.
07-12-2015, 08:20 AM | #121 | |
Rep 13
Connect => Read FA (VO) => Read SVT (VCM) in expert mode - coding Now I see my SVT list, but no CIC/NBT, PDC module. The TRSVC [6] is there but without an active item but with BTLD_000000467..., HWEL_0000008SE.. and SWFL_000000468... I do see a HU_NBT and a REM folder (these are mentioned on other posts) for newer models... Should the TRSVC have three empty items? |
07-12-2015, 08:25 AM | #122 | |
Rep 40,984
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired TRSVC => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on TRSVC (the ECU itself not the underlying CAFD) => Select CODE. If that does not work, keep trying all CAFD's to see if one takes. If none take, then you have to flash TRSVC.
07-12-2015, 08:51 AM | #123 | |
Rep 13
I selected F020-15-07-500 CAFD_00000223_013_009_014 from the list (this is the latest?) and coded CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_009 CAFD_00000223_013_009_013 CAFD_00000223_013_009_013 CAFD_00000223_013_009_013 CAFD_00000223_013_009_014 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_009 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 CAFD_00000223_013_009_007 TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2015/07/12-15:38:01.533 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [TRSVC - 6] prepareECUforCoding started [TRSVC - 6] prepareECUforCoding finished [TRSVC - 6] authenticateECUforCoding started [TRSVC - 6] authenticateECUforCoding finished [TRSVC - 6 - cafd_00000223-013_009_014] Transaction type: cdDeploy; Message: TA started [TRSVC - 6 - cafd_00000223-013_009_014] Transaction type: cdDeploy; Message: TA finished [TRSVC - 6] finalizeECUCoding started [TRSVC - 6] finalizeECUCoding finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "Finished". [C207] TAL execution finished. Duration: "37s". [C206] Abarbeitung beendet Now I have to code the other modules, but I don't have PDC or NBT. |
07-12-2015, 08:52 AM | #124 | |
Rep 40,984
07-12-2015, 09:33 AM | #125 | |
Rep 13
When starting with coding it is difficult to find all the steps in E-sys and I don't want to brick the car. First I coded the HU_NBT, then the screen changed to PDC with camera view, but with video grayed out. After that I coded REM and KOMBI. I restarted the system by pressing the volume button for 20 seconds and picture was there. Now I maybe can do some tweaks like full screen etc, but for now I am very happy and will test the rear-view camera! Shawn, thank you very much, without your help and quick replies it would have been another dull sunday. |
07-13-2015, 12:44 PM | #126 |
Rep 13
One last question, we connected the TRSVC on a permanent 12v pin, of course behind a fuse. Is this correct or should the unit be connected to a switched pin on the fuse box.
We are in doubt because in the installation instruction the signal says '15N' for position A8. |
07-14-2015, 11:03 AM | #127 | |
Rep 578
You talking about this step? I would say it needs to go in the correct Fuse.. I have a screen shot above on that step. |
07-14-2015, 01:41 PM | #128 | |
Rep 13
Sadly since yesterday the display shows 'rear view camera malfunction' but the camera is working OK.... |
07-15-2015, 02:21 AM | #129 | |
Rep 42
07-15-2015, 09:24 AM | #130 | |
Rep 13
Where can I download BMW ISTA-D Rheingold (PM?). |
07-20-2015, 02:08 PM | #131 | |
Rep 13
CA8CD04 - LIN-Bus: Rear View Camera antwortet nicht D0157A - Signalfehler (Radmoment Antrieb 4, ID: WMOM_DRV_4 - Ungültig The 'Rear View Camera antwortet nicht' / Rear View Camera does not respond' can mean the camera is broken, but I don't see any problems (clear picture, fast response). A little help would be appreciated ... |
07-21-2015, 01:45 PM | #132 | |
Rep 42
I had the same LIN-bus problem with my side-view camera retrofit, and I had to play around a bit with the ECU reset and clearing the errors. I don't remember exactly what I did, but after a few retries the error message was gone. |
