BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > AWE Tuning: BMW F30 340i Exhaust Suite
      03-11-2017, 10:15 PM   #67
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
Originally Posted by Thisisdudewhoru View Post
We have confirmed this is actually the M Performance Exhaust on this car. NOT the MPPSK or factory M Sport muffler.
Correct. Typo on my behalf. Apologies!
      03-19-2017, 04:29 PM   #68
obiwanshinobi87
Drives: BMW 340i M-Sport
Where would you recommend having something like this installed? Can any good automotive shop/dealership do it, or should I drive down to Dallas to go to an AWE dealer? I live in Oklahoma.
      03-19-2017, 08:08 PM   #69
G.Newt
Drives: CT4-V Blackwing 6MT
I got mine done at a local shop where I'm located. Any half-decent muffler shop should be able to do it. Took almost exactly 1 hr.
      03-20-2017, 08:58 AM   #70
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
You could go to Blair Auto if you wanted. Unfortunately I don't have anyone directly in OK.
Or like G said, you don't have to get it installed at an AWE dealer, it's just preferred as they're familiar with our configurations. It's a fairly straight forward installation process, nonetheless.
      03-23-2017, 01:49 PM   #71
G.Newt
Has anyone experienced a cold start rattle? It only happens for the first minute or so and quickly goes away, so it's not a big deal. Does the exhaust and/or midpipe need a readjustment after initial install? I'm thinking it might be a loose clamp or it's hitting up against the rear heat shield.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      03-23-2017, 01:58 PM   #72
jalkster
Drives: X3MC
People with stock exhaust, including me have had this happen.
      03-23-2017, 02:31 PM   #73
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
This. It happens on all of them, oddly enough. Not sure whether its waste gate or not though.
      03-23-2017, 06:12 PM   #74
G.Newt
Does this affect only cars with the stock exhaust? This started happening after the AWE install. If it's just a normal thing, I assume it affects both, stock and aftermarket.
      03-23-2017, 09:21 PM   #75
Beek
Beek's Avatar
Drives: Most folks crazy.
I had it stock and I've got it with MPPSK also, go's away quick. I also had the "stumble" on initial cold take off but that seems to have gone away when I added the MPPSK?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter.
      03-23-2017, 10:38 PM   #76
PeterA90
Drives: 340xi
No completely normal. It's the vibration of the straight pipe. The rattling is there even with stock midpipe... but it's not as pronounced because of the resonators and larger rear muffler.
      03-24-2017, 11:41 AM   #77
G.Newt
Thanks guys for the info and peace of mind. I'm guessing it's the infamous wastegate rattle and since it's normal, I'll just deal. Maybe the dealership will replace turbo under warranty.
      03-24-2017, 11:57 AM   #78
PeterA90
Drives: 340xi
No wastegate rattle on the b58. It's the straight pipe rifling noise because there's no resonator. Most apparent when exhaust is cold.
G.Newt810.00
      03-24-2017, 04:00 PM   #79
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
Does anyone have a picture of the resonator on the stock midpipe?
      04-03-2017, 08:17 AM   #80
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
Also - are we saying that the non-resonated midpipe with a catless DP sounds like poopoo? I currently have the MPE and ER catless downpipe. It sounds great, but I'm a sucker for sweet exhaust sounds so I'm not sure if I should go for the midpipe or not.
      04-04-2017, 11:04 AM   #81
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
Here's a diagram of the 340i's stock configuration minus DP. Hope this helps:
I don't have a video of a catless DP paired to our Non-res Mid Pipe and Touring Edition, unfortunately.
ray340i283.50
      05-15-2017, 11:10 AM   #82
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
AWE 340i Non-Res Mid Pipe paired to the Touring Edition Axle-back Exhaust.
Pipe up with your own configuration for your 340i via an AWE dealer or direct, right this way.
      05-15-2017, 03:48 PM   #83
calibro9
Drives: Incoming 2021 G80 M3 SPY
any vids of just the awe axl-back with stock resonators?
      05-15-2017, 03:57 PM   #84
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
Here ya go:
      05-15-2017, 06:36 PM   #85
calibro9
thanks. sounds similar to the full cat-back with the mid pipe to me....pop, burples, and all that good stuff!
      05-16-2017, 08:00 AM   #86
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
Indeed, just less pronounced and not as snappy with the factory mid section in place.
      05-16-2017, 01:06 PM   #87
MUFCbmwbear
MUFCbmwbear's Avatar
Drives: 24 M2 & 20 M340xi
I have a AWE midpipe on order to pair with my MPE axle back.
Can't wait!
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd
Chicago-Lake County-Milwaukee-Shorewood
      05-17-2017, 09:14 AM   #88
Josh/AWE
Josh/AWE's Avatar
561
Drives: F80 M3 Comp
Can't wait!
Nice! Burbles inbound
