12-15-2016, 08:44 AM | #1 |
I even mod my cereal
245
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
328d Issues
Hey guys,
I'm a long time forum member and BMW Owner/fanatic that happens to have a daily driver VW JSW TDi that I'm turning in next month and will replace with a 328d X drive wagon, hopefully CPO'd. I wanted to know if there's any issues to look out for. I owned an N54 335 a few years back and don't really want to deal with fueling issues. Any insights would be greatly appreciated. Hope to be driving a 328d soon!
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
12-15-2016, 09:43 AM | #2 | |
Curmudgeon and Pedant
690
Rep 3,489
12-16-2016, 08:18 PM | #3 |
Rep 700
Going on 3 years and 61k on mine without any problems aside from the NOx sensor at purchase. Didn't know about the break in procedure when I bought it, so it's been driven like a BMW since the day I bought it, although it pretty much stays in ecopro though.
12-17-2016, 08:49 AM | #4 |
Rep 123
We have the xdrive version at 61k. Wife's daily driver so it has seen an easy life. Leaking seal on the rear diff (37k) and front diff (49k). Transfer Case/Power Divider went at 49k also. Symptoms weren't noticeable unless you floored it, then it had a horrible drivetrain knock about every second. Brakes (frt & rear) went 49k also.
12-17-2016, 12:52 PM | #5 | |
Rep 1,447
12-17-2016, 03:11 PM | #6 |
Rep 123
Found the rear diff leak when I was changing diff fluid. It was weeping but not enough for a drip. The dealer found the front diff leak while looking at other warranty items. It was also a weep without drips.
12-18-2016, 10:18 AM | #7 |
Rep 906
Hello fellow TDI owner!
I'm in the same about, about to take delivery of a new F31 diesel. I've been looking at issues too and this is what I can find:
Old habits die hard. I already bought a bottle of DieselKleen and a cool lab-grade refill jar. There's a couple Propel stations nearby, may try to use that instead for lubricity.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-18-2016, 07:01 PM | #8 | |
Rep 700
12-18-2016, 10:39 PM | #9 |
690
Rep 3,489
Many of the failures on the VW TDI were (allegedly) caused by miss-fueling with gasoline. Our BMWs have miss-fueling interlocks; I've only read about 2-3 miss-fuels.
12-19-2016, 02:08 AM | #10 |
Rep 700
They must have been using the adapter then, I've tried to put the gas nozzle in it and could not get it in.
12-19-2016, 08:19 AM | #11 |
Rep 906
I do hope BMW sourced another pump vendor or Bosch finally fixed the design. That CP4 pump has been giving other diesel makes grief.
01-23-2017, 11:18 AM | #13 |
Rep 49
Drives: 2017 M4 ZCP
Garage List 2018 Toyota Tundra ... [0.00]
2017 Mazda 3 GT Manual [0.00] 2017 BMW M4 ZCP [0.00] 1990 Eunos Cosmo [0.00] 1991 Mazda RX-7 Turbo [0.00] 1989 Mazda RX-7 Rac ... [0.00] 2014 BMW 328d Xdrive [0.00] |
We own a 2014 328d xdrive, currently has 53k miles and change.
We had issues with the Nav/Idrive system traced back to a bad battery shortly after purchase in dec 2013 Broken rear ride height sensor caused the adaptive headlights to go into truffle hunting mode at around 5k miles. Relatively trouble free up until shortly after the factory warranty expired...now we've had two check engine lights within 500 miles of each other. First one identified as a bad DPF sensor. They had to replace the entire converter pipe because when they went to remove the sensor it broke off in the pipe... Our extended warranty did not cover this repair and the dealer had to goodwill it. Even though the sales guy who sold us the BMW extended warranty (with the optional extended full service coverage) when the car was purchased new said it covered all service AND repairs... "everything but tires". Unknown what the 2nd check engine light is about...going into the dealer tomorrow morning. Would not be surprised if its something related to the first DPF sensor problem... As far as performance: It's great other than from a dead stop it has a pretty significant hesitation if you are aggressive with the accelerator. It will barely go for about a second then once the turbo spools or whatever takes a min to spin up (torque converter) it launches. No hesitation once the car is moving. Can be a bit unnerving if you are trying to thread the needle taking a left hand turn onto a busy highway or something. The thing also eats tires quickly, even for an AWD car...and no, i dont have an alignment problem. Last edited by Rocklobster; 01-23-2017 at 11:30 AM.. |
01-23-2017, 11:36 AM | #14 |
245
Rep 3,441
thanks for the feedback Rocklobster, I appreciate it.
I'm getting close to pulling the trigger on a 328d wagon....
01-23-2017, 12:23 PM | #15 |
Rep 49
Drives: 2017 M4 ZCP
It seems to me that the US only emissions control subsystems on the 328d are not as thoroughly tested/engineered as the rest of the car/engine. One of the reasons the government's war on diesels in the US is so frustrating. Not that the VW tactic is acceptable but having to engineer complicated emissions control systems for one market is bound to cause problems. It's kinda made me decide to steer clear of diesels. Which is a shame because i love driving them, love the torque and love the efficiency. I'd strongly consider another BMW diesel or the new upcoming mazda diesel if it wasn't for the US spec emissions systems and the wildcard reliability that comes with them.
01-23-2017, 03:39 PM | #16 | |
690
Rep 3,489
But I wanted to mention some things: 1) Even the Europeans have had DPFs for 10 years or more, so any problems with it are not the result of poorly-designed/US-only systems. 2) BMW almost certainly used the early 335d/X5d vehicles (10K units, >10K units) as a test bed for the current 328d DEF/SCR systems. Note that the DEF tanks are separate on the 328d, partly because the 335d single-unit setup is so bad (the X5d always had separate tanks), with a single fill point (rather than two.) 3) BMW has been beset by bad quality control on NOx sensors, and the high cost of said sensors. Is that BMW's fault? not fully. |
01-25-2017, 10:31 AM | #17 |
Rep 49
Drives: 2017 M4 ZCP
Interesting insight. Thanks.
It was certainly my assumption that at least until recently it was the US emissions that drove the bus at least on the DEF subsystems. Further the 6 cyl engines i assumed were quite different and while a good test bed for theory were unlikely to have been simply copied as-is over to the 4-cyl engine. The 4cyl diesel offering was new for the 2014 model year in the US and i thought i had read a few places that prior to that,where offered over seas, did not have the DEF system. As with all emissions control systems they are a single system of associated sub systems all designed to meet tailpipe emissions laws. So, adding a DEF sub-system to an emissions system which already includes the DPF would at the very least incur some different tuning, testing, calibration, control, etc... |
01-25-2017, 03:28 PM | #18 | |
690
Rep 3,489
The DEF/SCR system was an option in the EU for as many years as it's been on the USA/CA cars - but it doesn't appear that many were sold. In looking around at things, I noticed that the DPF canisters (and DOC) are different on US and EU cars: curious, but perhaps not unexpected. |
01-25-2017, 10:03 PM | #19 | |
Rep 700
01-26-2017, 05:06 PM | #20 |
Rep 49
Drives: 2017 M4 ZCP
I'd imagine, like fuel, it depends on how it's driven, ambient conditions, etc. Maybe it will last 10k no matter what and since that's the oil change interval the just recommend you refill when you change the oil...
01-31-2017, 01:49 PM | #21 |
Rep 49
Drives: 2017 M4 ZCP
Update. SCR metering error code. They "Calibrated" the SCR metering system and had us pick up the car. We made it 5 miles down the road and the CEL came on again. Back into the dealer for further diagnosing (round 3). Dealer has had the car for the better part of Jan. They have been good to work with but have not yet been able to repair the car 100%. I've not been under these cars but for anyone who knows the DEF/SCR system....
Could a careless mechanic potentially damage the SCR/DEF metering system while replacing both the DPF sensor and the catalytic converter pipe it threads into? |
01-31-2017, 02:03 PM | #22 |
245
Rep 3,441
Thanks for the feedback guys, keep it coming if you have additional comments.
I ended up putting a deposit on a 2014 328d X drive wagon....should be shipped in a week. Starting to get excited about the new ride.
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser Last edited by bigdaddycane; 02-01-2017 at 12:35 PM.. |
