08-29-2018, 05:42 AM | #1 |
Rep 29
6wb retrofit full instruction guide
Hi all,
i would like to start and do myself the coding and the retrofit for the f30 6wb retrofit since they asked 200 usd for the coding can anyone tell me the step by step guide to do it? actually i have a normal one thank you all |
09-04-2018, 10:08 AM | #3 |
Rep 2,302
If it's new there's no need to change the eeprom data.
Only coding is necessary. Here's a guide for VO coding: http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf At point 6 you have to change the 6WA to 6WB. And at point 12 you have to code your HU and DKombi. |
jimmy8904563.00 rwallis0.00 |
09-18-2018, 07:04 AM | #5 | |
Rep 45
Finally did you code it?? |
09-18-2018, 06:19 PM | #6 |
Rep 765
09-18-2018, 10:29 PM | #7 | |
Rep 10,473
”They should” is not “innocent until proven guilty” in these instances. |
09-19-2018, 01:34 AM | #8 | ||
Rep 765
09-24-2018, 07:54 AM | #9 |
Rep 29
Hi i'm waiting for my 6wb to arrive, it has been virginized already the final cost is 825 € shipped and is a very good price.
as soon as it arrive i will have to code it i've purchased the cable and i will have to download the eysy but in order to do not make truble i will ask someone to code it for me and activate my shift paddle also thanks for the guide it seems very dettailed |
10-01-2018, 04:19 PM | #10 | |
Rep 244
11-09-2018, 10:37 AM | #13 |
Rep 64
12-15-2018, 08:01 AM | #15 |
Rep 29
Hi i've finally installed my 6wb but i have the red dot do you have a full instruction on how to remove it?
also do i need to change some setting into the navi to make it work i don0t have the possibility to set the time i have a nbt evo retrofitted thank you |
12-15-2018, 11:58 AM | #16 | |
Rep 878
04-03-2019, 02:18 PM | #17 | |
Rep 36
Hi,
The link to the document is broken, can you fix it or send me the coding guide? Thank you! Quote:
04-03-2019, 03:26 PM | #18 | |
Rep 2,302
https://www.bimmerfest.com/forums/at...2&d=1377379630 |
08-27-2019, 06:23 PM | #19 |
Rep 198
Hello,
Has anyone installed a 6WB cluster on an F30 and gotten a "Cruise Control Malfunction" message upon start-up randomly every few start ups? Everything works fine including cruise control, I just happen to get this message every couple of start ups |
08-27-2019, 09:42 PM | #20 | |
Rep 10,473
Guess 825€ wasn't a great deal. |
09-12-2019, 10:41 AM | #21 |
Rep 61
Is there a current guide from start to finish what needs to be done exactly for F3x with NBT_EVO? The PDF guide I have seen just has some generic stuff in it and doesn't explain where/what to find and change.
04-26-2020, 09:39 AM | #22 | ||
Rep 379
I just bought a 6wb cluster, brand new with 0miles and never coded for any car or vin. so is it just a matter of removing 6wa and vo code 6wb and code headunit and kombi or is it more than that? Also do you suggest to do the coding with factory headunit on and once the cluster is all set then install the retrofitted id5 headunit or i can directly code with retrofitted id5 headunit on? Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
