BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Rear LED Reflector Replacement
      10-25-2020, 08:39 PM   #1
UrbanCarCulture
UrbanCarCulture's Avatar
Drives: BMW 340i
Looking to switch the rear deflectors on the back of the car to the LED replacement ones, but having a hard time finding a link to them.
Its for my F30 2016 BMW 340i xDrive if anyone has the link they can share.
      10-25-2020, 09:04 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The rear reflectors don't have bulbs.
      10-26-2020, 07:35 AM   #3
UrbanCarCulture
Drives: BMW 340i
Yeah, I know that but there is an aftermarket reflector that seems to light up when you activate you're turn signals.
I saw it once on a F30, not entirely to sure if it was a 340 or not.
      10-26-2020, 02:22 PM   #4
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
eBay or Aliexpress - there is tons of sellers with those LED reflectors with tinted/red/clear lenses.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      10-26-2020, 08:03 PM   #5
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
Looks tacky but here you go
https://www.ebay.com/i/383457644596
Looks to be non msport though.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      10-27-2020, 01:49 PM   #6
Oksamit78
Oksamit78's Avatar
Originally Posted by wdeerfield View Post
Looks tacky...
Agreed. Personally, I'd prefer if there was an option available that lights up as a panel with diffused beam and not as a string of LEDs behind the lens...
      07-22-2024, 12:53 PM   #7
Sprinterman
Sprinterman's Avatar
Drives: F31 touring
Want to thank oksamit for all his advice regarding wiring. Wasn’t an easy task, as the wires from the led reflector running underneath the car up to the taillight fitting (no other way to route them) do I need to seal them with electrical tape or maybe something more robust, to protect them from rotting in bad weather or will they be ok?
Martin
      08-14-2024, 09:24 AM   #8
Master_Igz11
Drives: N/A
Can you provide the details/ tips on wiring?
      08-14-2024, 09:58 AM   #9
Sprinterman
Drives: F31 touring
This worked for me thanks to another member here. Wouldn’t recommend them as brake lights due to the frequency of them lighting up,they’d probably wear out faster. But I’ve never seen them used as brake lights so may work for you. Try them and see, you can thread the wiring up from the reflector to the lamp housing through a small gap, you will see daylight. It’s not easy to thread it through and you will curse a lot and cut your arms up trying! But persist and you will get there. Be sure to insert the reflectors gently or you will snap the fitting, make sure you push the wires through the reflector gap before you click them in, I made the mistake of not doing this and had to take the reflectors off again.other advice is before you fit them, wrap the wires of the led reflectors with fabric tape, not electrical tape as the damp and and rain will pull it off. This is to prevent the wiring from perishing in bad weather
Martin
