BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Cluster White LED retrofit
      03-23-2022, 09:02 AM   #1
kkonrad02
Poland
Drives: BMW F30
Hi there! Recently I found out that I can replace the stock orange LED's from cluster to white LED. I have replaced 3 of 12 leds and they don't work (one clock doesn't work). What may have I done wrong?
      03-23-2022, 09:11 AM   #2
Onizukachan
Great Teacher
Onizukachan's Avatar
1495
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Put them in wrong way round?
Also why? It already has both orange and white LEDs, mines white by day and orange at night.
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
      03-23-2022, 09:17 AM   #3
orha12
Drives: BMW F30 316i
How did you replace them?
      03-23-2022, 09:28 AM   #4
kkonrad02
Poland
Drives: BMW F30
I haven't the white leds, that's why I want to replace the stock orane to white
      03-23-2022, 09:29 AM   #5
kkonrad02
Poland
Drives: BMW F30
I have took the cluster out, open it and solder the new leds, but apparently the new leds won't work
      04-03-2022, 07:04 AM   #6
belgrade79
Drives: BMW 320d F30 8AT
Did anybody find a working solutions to change orangel leds to white?
Display would allways go to orange by night?
      04-03-2022, 08:47 AM   #7
NxTH
AH3 Owner
NxTH's Avatar
238
Drives: BMW 335i ActiveHybrid 3
Take out the cluster, disassemble it, take out orange leds and swap them with white leds.
      04-03-2022, 09:04 AM   #8
belgrade79
TNX Nico.
      04-03-2022, 03:46 PM   #9
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
F30 clusters do not have backlit LEDs in white.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      02-22-2023, 01:59 PM   #10
Guus keunen
Guus keunen's Avatar
Netherlands
17
Drives: BMW F30 328i
Just did this mod, the white LEDs are quite bright so I have turned down the brightness in the instrument cluster. I've missed 2 LEDs and my oil temp needle is a little bit off now, so will fix that this week. Overall very happy with this simple mod, cluster looks cleaner with the white LEDs.
      02-09-2024, 10:25 AM   #11
sraba
Drives: bmw f30 316d lci
Hello, i have the basic cluster in my f30 and i did the white led swap… the problem is that the left side (speed) is not as bright as the right (rpm)… i did the swap twice because i used other kind of led to try and fix the problem… has anyone had the same issue and how did you fix it?
      03-03-2024, 04:02 PM   #12
Siettopes
Drives: bmw serie 1 118d
I have the same problem too... have you solved it somehow?
      03-03-2024, 04:04 PM   #13
sraba
No i have not, i will try using different LED but i dont have much hope… i just want to get it at least bright so it is not almost full dark…
      03-03-2024, 06:48 PM   #14
eff32fl
eff32fl's Avatar
1234
Drives: 2019 440i M Sport THP MPPSK
Switching to white LEDs is complemented well with the Venoxy replacement gauge faces. The F3x 6WA gauge faces are kinda ugly imo lol.
https://venoxy.com/699-f3x
https://venoxy.com/700-f80-f82
      08-08-2024, 10:14 AM   #15
3ermejo
3ermejo's Avatar
Peru
Drives: BMW 316i 2012/13 N13
      08-25-2024, 12:40 AM   #16
ThatOne340i
ThatOne340i's Avatar
Drives: 2016 Bmw 340i
2016 BMW 340i  [0.00]
Polarity on the led is prolly wrong, I would see how it was stock and then flip the replacement to that same polarity
      09-08-2024, 02:47 PM   #17
sraba
I put a small resistor for one of the left LED so there are basically 3 and not 4 LEDs now. It has still a small difference but its a lot more similar than before. Thats what i can recommend. If someone has a better fix please write
