BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Driver Front Tire/Wheel Losing Air
      09-17-2018, 05:43 PM   #1
enchilada
Drives: 2013 320i xDrive
Hello all,
Driver front tire/wheel loses air frequently. On cold mornings, I can expect to need to fill it up with my portable air pump. I also randomly need to air up even on warmer Southern California days. I definitely leaking somewhere.
Both America's Tire and Sam's Club Auto have water dunked my wheel/tire and saw no leaks. I personally think it's a wheel issue, as this wheel was difficult to balance when I first purchased them.
Does the below make sense? Any other suggestions to resolve this?
1. Mount/remount tire to see if it helps
2. Take it to a BMW service center, maybe they'll know?
3. Buy new wheel, tire, or both.
Wheel: 19" 351m
Tires: 245/40-19
      09-17-2018, 06:58 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Sometimes corrosion around the bead can cause this... although usually in snowier/saltier climates...
Id try to dismount tire from wheel and clean BOTH the mating surfaces of the tire and wheel real good (with grinder/sand paper).
See if that works before ditching an other wise nice wheel and tire.
      09-18-2018, 11:23 AM   #3
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
I think the soapy spray solution is a better indicator for a slow leak. Mix some car wash with water in a spray bottle and spray it around the wheel/tire to see where it bubbles up. On my car I actually had a loose valve stem so it was a quick and easy fix.
Youtube/Instagram/TikTok: @kern417
      09-18-2018, 08:00 PM   #4
enchilada
I'll give the soap test a shot and then do a remount/cleaning if it is still a problem.
I suppose going back to stock is not really a big deal since I plan to trade the car in at the end of the year anyway. It's just I like to go into the mountains for hiking/fishing and don't want to be stuck out there unable to pump a flat up...
Thanks for the suggestions!
kern4174446.50
