02-10-2021, 01:21 PM | #1 |
Rep 162
Oil temp low Coolant temp fine
Coolant temp comes up fine, even on these single-digit days it hit 90c within 10-15min and stays there.
Engine OIL temp however doesn't come up to normal range. I'm hovering around 160f. Is there a thermostat within the oil loop? Thx. Kevin |
02-10-2021, 01:56 PM | #2 |
Rep 1,811
Are your drives just 10-15 minutes?
02-10-2021, 02:20 PM | #3 |
Rep 80
This is to be expected at that low of temperatures. I have seen the oil temp never fully get to operating temps during these rather cold winter days. If you are driving more city it will likely increase a bit quicker. But at highway speeds I noted that the engine just isn't stressed enough at 70mph with the cold wind cooling things down. If you are going on a longer trip out. Keep the gearbox in 6th or 7th gear for a bit. Should see the temps come up.
