12-14-2018, 12:26 PM | #1 |
Rep 17
Driver's Side Mirror Turn Signal Not Working?
Good afternoon, everyone:
I have a 2014 320i F30 and I'm having a bit of an issue. Some time ago, my driver's side mirror turn signal had somehow gotten enough water behind the mirror to get into the signal housing. Nevertheless, I ordered a new signal and have installed it. Upon connecting the wire and trying to use the turn signal, this shorted out the driver door window controls, causing them to no longer light up or operate, and the signal still didn't work. I pulled out my fuse box chart (see attached) and changed fuses 22, 83 and 84 (according to the chart, those are the fuses for both the doors and the side mirror turn signals) and the window controls re-illuminated. However, the signal on the mirror still doesn't work. Does anyone have any suggestions as to any other fuses to check? Again, I have attached the fuse chart for my vehicle model. Thank you for any help you guys can provide. |
03-22-2021, 07:29 PM | #5 |
Rep 41
Hey guys, same issue here, i have a 2015 328i xdrive and the right side mirror turn signal does not have power but everything else functions ie heated mirror, folding and adjusting mirror, all door functions work also. Its not the connector plug because i poked into the yellow wire with a circuit light tester thing while grounded to the main jump ground under the hood. Any ideas as to how just that one led signal is not recieving power? Thanks!
07-13-2021, 07:34 PM | #7 | |
Rep 17
07-15-2021, 11:16 AM | #8 |
Rep 41
I learned that those 2 leds do not have a fuse, bizarre but true. Also they connect directly to the fem. Lmk if the new set works. Does this prevent you from getting a state inspection?
07-30-2021, 09:51 PM | #9 |
G
129
Rep 162
Drives: 2013 BMW 328i F30 Luxury Line
You can find the mirror signal lights on Amazon and other sites. I had my passenger side go out and replaced them with a sequential set. Easy install and work great.
