02-16-2021, 10:50 AM | #1 |
Rep 525
xHP - jerk shifts now only in sport+
Flashed stage 3.
after completing around 100 miles of normal driving in Eco/Comfort, i finally unleashed the beast.......... only to find that the head-jolting aggressive shifts in sport mode have gone, and they are only in sport+. (yes i have my shifter in sport also, this is all in manual mode) Why xHP configured this i have no idea, makes no sense to me. I don't want to have to switch to Sport+ just so i can feel more aggressive upshifts, which were previously in sport mode before the flash..... i appreciate that maybe the upshifts are faster, but i don't really care, i liked that 'mechanical' feeling. how do i fix this please? |
02-17-2021, 08:54 AM | #3 |
Rep 525
02-20-2021, 07:38 PM | #4 | |
Rep 4,841
02-20-2021, 08:22 PM | #5 | |
Rep 525
There's no way to change that. They have purposely made sport mode completely smooth. |
02-20-2021, 10:10 PM | #6 |
Rep 4,841
Well, that licks... royally. I use manual mode all the time, so I never experience the earlier shifts, but would like that harshness back on the gear changes.
Comfort is there for a reason. Make that one smooth.... |
02-21-2021, 04:37 AM | #8 |
Rep 3,832
Everyone complaining, but no one here asking the most important question...:
WHY have they done that......? A. Just for fun B. To annoy you C. Their email box is feeling lonely, they love questions D. To prevent damage to your gearbox or make damage of abuse less likely (based on complaints or experience they gathered) E. It was Friday afternoon and they felt like they have to change something completely randomly Not an xHP user myself, but just guessing...
02-21-2021, 09:38 AM | #9 |
Rep 4,841
No clue. The engineer in me is asking all those questions.
Their marketed pitch is you need to crisper / hard shifts to save the clutches when you have a lot of power (which is also conventional wisdom from the dawn of the automatic). Just odd they don't allow it in sport. When you check that setting that was listed above, it does say "sport/sport+ can have hard/soft shifts". That is still the same message in the latest update from 2 days ago. Now, that being said, I did just re-flash with the same map, so maybe they "fixed" it on the Feb 19th update? Haven't gotten out yet today to try it. |
Skyhigh1870.50 |
02-21-2021, 12:02 PM | #10 | |
Rep 525
i have to say sport+ is fantastic and it justifies the cost of it, especially when i take it out on track, but its annoying that they've given options to change things in some areas, and not others. Indeed, there are already 2 other modes, ecopro and comfort, + 2 combinations of each of them (selector in D or S), they even acknowledge this in a blog post where they talk about how this creates 10 different combinations to play with, so why they feel like Sport mode needs to be 'softened' doesn't make much sense to me. i did select the 'enable soft shifts in sport mode' setting and made sure it was set to Off too, thinking that may override any softness in the Stage3 map, but it was the same. guess we can't have everything! (unless theres enough demand for it i suppose) |
02-21-2021, 12:35 PM | #11 |
Rep 4,841
I opened up the all the custom settings, and found something "interesting". Clicking the box, doesn't necessarily enable or disable the setting. Clicking the box takes you to the feature, and then there is an on/off.
IE, I had the gear numbers on. Even with that checked, if I selected off once in that feature, they went away. Soooo.... I went through and checked EVERY box and then in each setting that I wanted (gear change, 8th gear in cruise and hard shifts) I selected what I want. Going out to grab lunch soon and see how that works. It might be the OTS maps have it disabled, but you can override it with the custom settings? Fingers crossed.... |
02-21-2021, 02:32 PM | #12 |
Rep 4,841
OK, sees like my idea was just a red herring. It's not "sport+" mode specifically, you need to have "DTC off" clicked (something that happens when you do sport+ mode) to get the firmer shifts.
The release notes for map 1.7 only indicates the harder shifts in sport+, regardless of what the hard shift mode feature says. I'm going to punt xhp an email to clarify. |
02-21-2021, 04:59 PM | #13 |
Rep 4,841
Sent a note to XHP to check.
Thinking out loud, it might be an issue where you can get wheel slip on hard shifts, which would engage the traction control (hence why it only works with DSC off). Kind of like watching a classic muscle car with a high stall converter where there tires would chirp at low speeds on each gear change. |
02-21-2021, 07:12 PM | #14 |
Rep 408
@Wires I could see that being plausible as I find myself hitting the traction button once even when in comfort for the faster shifts as I drive in manual mode unless going on long trips and want to use cruise control. Curious to see what they write back but your assumption seems spot on in my opinion.
02-23-2021, 08:50 AM | #16 |
Rep 4,841
Ok, after the typically back and forth non-committal answers, it ended up being "sorry, we cannot configure that".
My guess is that goes a bit further into the TCU area that XHP cannot touch. Long story short: You can stop looking for this unicorn that does not exist. |
06-22-2021, 12:42 AM | #17 | ||||
Rep 1
06-22-2021, 08:47 AM | #18 |
Rep 4,841
I have noticed that after the weather got warmer, the sport shifts are more firm than before. Not sure if was the transmission adapting, or if the TCU pulls back line pressures when the oil is cold?
Anyways, it's much better now it's summer and I've logged a bunch of miles than the first day impressions. |
