03-01-2021, 03:27 PM | #1 |
Rep 9
Suspension Options Koni Special-Active vs B12 PRO vs B4 vs SACHS
So after failing my inspection at the Swiss DMV, I have started to look at my options in terms of replacement parts for both the front and rear.
After searching for the best deals in CH and DE, I've priced out 4 different options for my 2014 335 xDrive(M Sport Package). As I live in Zurich, I do a mix of city driving but also venture out into the mountains quite often. Snow is something I will need to consider if I decide to lower. Also, I don't track the car or anything like that. SACHS(315 872,315 870,315 871) w/ original springs $345 This should hopefully just refresh the suspension. Not expecting anything to be too different. Read that this should get me close to the original OEM feel. B4(19-220093,22-238269,22-238276) w/ original springs $489 From what I've read, these should be a bit stiffer and handling should improve slightly. Don't really like the price point as I compare it with the other options. Koni Special-Active(8745-1378R,8745-1378L,8245-1319) w/ original springs $550 I think this is going to be my preferred option. Not alot of info out there on these but I like that they seem to offer comfort but still offer performance above the SACHS or B4's. I checked the on Koni site but want to confirm these will work for my model and the springs B12 (E90-20-031-06-22) $700 I want to want these but I'm not sure if they are a right fit for me. Seems like it would be pretty stiff and since I do some city driving, that might get old quick from a comfort aspect. Are they a lot rougher than the KONIs? In terms of lowering the car, I've read that AWD lowers differently than RWD? Let me know what you guys think about the different options! Last edited by jpjpjpjp; 03-01-2021 at 04:29 PM.. |
03-03-2021, 05:00 PM | #2 |
Rep 10,256
This is a great thread to read with full credit going to FaRKle!.
https://f30.bimmerpost.com/forums/sh....php?t=1662711 johnung is a a fan of Koni Special-Active shocks. Given the choices, I also suggest Koni Special-Active. I had an almost identical car to yours in the past: 2013 BMW 335i xDrive sedan. After installing KW Street Comfort coilovers, the handling was transformed without sacrificing ride comfort. The suspension height was intentionally set at near OEM height. But - KW Street Comfort coilovers cost more. |
johnung4528.00 |
03-04-2021, 04:06 AM | #3 |
Rep 9
Swiss Regs
My first thought was to go with B16 or some KW's. Unfortunately, it seems like if you "change the suspension type" in Switzerland i.e. coilovers, you potentially need to get "expert opinions" and that can lead to needing additional testing.
Spoke to my mechanic and he even advised against the B12's since the new springs would lower the car, the MFK might raise issues. I pulled the trigger today on the Koni Special actives. Hopefully everything goes well with the inspection, my only worry is that they see those bright red shocks and start asking questions. |
03-04-2021, 11:34 AM | #4 | |
Rep 10,256
03-04-2021, 12:11 PM | #5 | |
Rep 468
03-04-2021, 03:57 PM | #6 | |
Rep 15,858
Koni's valving and resulting damping map, gets you close to an adaptive damper performance, without electronics involved. |
03-05-2021, 06:37 AM | #7 | |
Rep 9
Nope TUV is not accepted. Depending on the canton, the ABE may be accepted but you always run the risk. Typically, you need an "expert opinion" or CH-Eignungserklärung
with any suspension that "changes the suspension type". Basically means that you either pay for the part from a Swiss reseller which will upcharge you between 30-50% on the part or you buy the "CH-Eignungserklärung" apart which can cost you between 130-250 CHF depending on the part. If you import your car here with the part installed, they might let you slide or not depending on who is reviewing the car. Basically, when importing a car into Switzerland, try to keep it as stock as possible, all sorts of horror stories out there. Rims seems to be the biggest gotcha as any after market rim needs to have Swiss approval. Spoken to many people here in Switzerland that literally have a set of parts they install before going to MFK and then revert back to aftermarket once the car passes. Here is an example(for a VW): https://shop.eibach.ch/ch-gutachten-...-pc-16-m116-02 Quote:
03-05-2021, 06:45 AM | #8 |
Rep 9
Just to clarify, not advising that anyone do this. If the aftermarket part is deemed to be the cause of the accident and wasn't approved/registered during MFK inspection, your insurance company can basically deny coverage and leave you with the liability.
