05-07-2014, 06:46 PM | #1 |
2132
Rep 5,011
A Closer Look At The BC Racing F30 Coilover Suspension
Hi everyone,
We wanted to give you a more in-depth look at the BMW F30 coilover setup from BC Racing. Their BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle - no preset ride height here - and the patented concave lower locking ring keeps it locked in. All of the BC systems come with top-quality mounts to provide the most feedback possible from your suspension and to sharpen your steering response. The included front camber plates also allow you to get the perfect alignment setup without compromise. BC Racing camber plates are vehicle specific and engineered to be rigid superior replacements to the OE Top hats. These plates can reach 3 degrees of camber depending on the level of drop. Each lower mount is designed with the OEM in hand to ensure OEM like fit and exact tolerance specifications matching OE manufacturers. All this while providing a strong, attractive looking coilover system that won't break the bank! You can start to see why we are fans of their products. Features:
Enjoy the photos! Last edited by Sean@PSI; 05-08-2014 at 08:50 AM.. |
05-08-2014, 01:44 AM | #2 |
Rep 347
what's the minimum drop? on bc racing's catalog it shows the front camber plate is N/A. what's the part number on this ? i-29 ?
13' F30 335xi mods are on their way
09' E90 LCI 328xi (GONE, BUT NOT FORGOTTEN) 19" m310,quad conversion perf exhaust, full mtech conversion, m3 sides, kwv1,etc PICS:http://www.e90post.com/forums/showthread.php?t=757811 PM me if you need coding for f30s in GVR |
05-08-2014, 06:01 AM | #3 |
2132
Rep 5,011
I-29 is the correct part number yes, and because the application list on their site is from 2013, it is NOT correct about the camber plates.
All F30 3 Series kits now ship with the front camber plates as shown above. These images were shot last week of a brand new kit. BC Racing is local to us and we work with them on developing new kits for BMW. When we tested the first F30 kit we could make the car actually ride HIGHER than stock. So minimum drop is whatever you'd like it to be that's lower than stock. Maximum drop is basically undriveable. Unless you want to drive in a straight line and never turn. We made about a 30 point turn in our parking lot to get some photos of it. Any sort of turning of the wheel caused the tire to rub on the fender. Last edited by Sean@PSI; 05-08-2014 at 08:48 AM.. |
05-08-2014, 03:16 PM | #5 | |
2132
Rep 5,011
I am not 100% sure it'll work on a 435i (hasn't been tested yet by BC) - I should have test car fitted soon - I will keep everyone posted. |
05-09-2014, 08:53 PM | #8 |
wannabe
252
Rep 819
05-12-2014, 01:44 PM | #9 |
2132
Rep 5,011
05-15-2014, 04:33 AM | #10 |
I'm The Captain Now
501
Rep 1,809
Drives: X5M/X7
Garage List 2021 BMW X7 MSport ... [0.00]
2018 Raptor [0.00] 2015 X5M (SOLD) [0.00] 2014 BMW M5 (SOLD) [10.00] 2014 BMW M5 Totaled [10.00] 2014 Jeep SRT (SOLD) [0.00] 2012 C63 AMG (SOLD) [0.00] 2015 BMW M4 (SOLD) [0.00] 2011 Porsche Cayenn ... [0.00] 2007 911 Turbo (997 ... [0.00] 2013 335i M Sport ( ... [0.00] 2002 Porsche 911 Tu ... [0.00] 2008 BMW 135i (SOLD) [6.00] 2002 BMW M3 SOLD [10.00] |
Group buy? lol
05-16-2014, 08:12 AM | #14 | |
2132
Rep 5,011
If you have EDC, you would need a defeat module or custom coding. |
05-16-2014, 04:33 PM | #16 | |
Rep 10,249
Thanks for confirming that the same, factory height can be maintained with this kit. |
05-16-2014, 04:44 PM | #17 |
2132
Rep 5,011
05-17-2014, 07:30 AM | #18 |
Rep 10,249
Sean,
My vehicle does not have DHP (wish I ordered it). I am looking for an improvement in the current "float" symptoms of my 2013 F30 335i xDrive without changing the suspension geometry, hence the goal of not changing the ride height. Not a stiffer ride but a slightly more controlled compression and rebound behavior that could be adjusted. I live in Washington, DC area where the roads could be better (a lot better after this winter). |
05-17-2014, 08:32 AM | #19 | |
2132
Rep 5,011
They would definitely help with the adjustment factor you mention. |
01-27-2015, 09:34 PM | #22 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
So will these return my car to factory like comfort and still keep it low, but get rid of the bouncy harsh feelings my H&R supersports give it?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
