01-20-2018, 04:20 AM | #287 | |
Rep 32,881
I’d recommend map 1, then play with the adjustments. No point in position 1 & 2, but 3, 4 or 5 should all be tried. |
01-20-2018, 07:35 AM | #288 |
Rep 68
I just swap between Map 1 and Position 5, and then Map 2 and Postion 5.
Map 2 postion 5 feels slightly better. There seems to be no difference in low end torque between the maps. I guess Postion 5 is the maximum fine tune/power for the given Map? The higher model boxes seem easier to understand, and give different gains. Oddly people don’t try them on maximum fine tune on each different map? Luke |
01-20-2018, 09:33 AM | #289 | |
Rep 32,881
01-20-2018, 11:56 AM | #290 | |
Rep 1,447
I believe the Pro version provides more aggressive states of tune and one of the reasons those of us who ran them previously stayed away from maximum settings was due to fuel cut issues. We all experience instances where the car would cut or limit power due to the box asking too much of the injectors and fuel pump as Teaston alludes to above. One of many reasons I went for a remap, but you should be ok if you're not pushing things too much.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
02-04-2018, 03:53 PM | #291 |
Rep 68
Thanks.
I did look at changing it for a CR2 box, or the Pro. But for £90 its working fine, no issues running it on max. I wouldnt want to have a Pro box, and not having it on full, would seem you are better with a CR1/2 box on max, than a Pro box on medium? Luke |
02-16-2018, 10:48 AM | #292 |
Rep 2
Tuning Box
Hi
I Just want to make a second opinion about this tuning box CHIP TUNING BOX BMW 3 320D 163 cv THEITALIANBOX REMAPPING ECU..does anybody tried this product before? cheers |
02-16-2018, 03:41 PM | #293 |
Rep 7,000
05-29-2019, 06:47 AM | #294 |
Rep 73
05-29-2019, 07:02 AM | #295 | |
Rep 1,447
In a nutshell, all diesel tuning boxes work by fooling the ECU into increasing fuel rail pressure thereby injecting more fuel into the cylinders. On a diesel, more fuel = more power. The more advanced boxes might alter boost pressure and vary the amount they increase rail pressure at any given point in the Rev range to deliver a smoother tune. A remap can alter several other parameters, such as injector timing, to achieve increase in power and alter the characteristics of power delivery. Now that remapping can be done over OBD using a laptop, there's little to recommend a tuning box instead unless you're still under warranty (tuning boxes will be harder to detect, though not impossible) or running a lease car or something.
05-29-2019, 03:29 PM | #296 | ||
Rep 73
05-30-2019, 03:43 AM | #297 | |||
Rep 1,447
I went tuning box to remap and the engine was definitely a lot happier with the remap. If you're really worried about something going pop, I'd avoid either!
05-30-2019, 05:12 AM | #298 | ||
Rep 73
