09-22-2018, 08:37 AM | #1 |
Cheapskate
4445
Rep 4,993
F3X LCI Unique Coding
Does anyone have a list of coding differences for LCI models? There are a few things I'd like to code but the directory in existing cheat sheets either doesn't work or isn't present for me.
Here are a few that I can't find for LCI models: Rear Fog Lights Add Tire Temperature to iDrive (may be ID6 issue?) LED Full Brightness |
09-23-2018, 12:00 AM | #2 | |
Rep 411
Both FLE Modules POLI1_Idx POLI2_Idx POLI3_Idx Change the 05 to 04 in werte values ex: the default is like this 00, 00, 00, 00, 00, 00, 05, 00, 00, 00 after it should be like this 00, 00, 00, 00, 00, 00, 04, 00, 00, 00 |
Dominic 881.50 kern4174445.00 |
09-23-2018, 02:51 PM | #3 |
Rep 11
For rear fog lights after you mod the switch use the following (I used BimmerCode in "Expert" mode):
REM Module REM -> Mapping_Nebelschlussl_L_output: nsl_l REM -> Mapping_Nebelschlussl_R_output: nsl_r FEM_BODY 3060 NSL_Verbaut: verbaut |
09-23-2018, 06:33 PM | #4 |
Rep 198
Do the LCI models have rear fogs? I have 2018 F36 and don't have them...or at least didn't think I did. 😜
09-24-2018, 05:02 AM | #5 |
Rep 3,860
I have the fog lights button next to headlights switch.... and when I have used it, I have always assumed it is not just an indication in the instrument cluster that it activates
Don't you have a button there? @kern417 "Add Tire Temperature to iDrive (may be ID6 issue?)" works just fine on LCI. Same way it is described in the cheatsheets from what I recall. I just re-coded it a week ago and it was very straight forward with Bimmercode. What do you want to do with the rear fog lights and what LED brightness do you mean?
09-24-2018, 06:55 AM | #6 | ||
Cheapskate
4445
Rep 4,993
For tire temp, I'll check again. But either I couldn't find the directory, or it already said activ when I checked (probably meaning I tried to code it a few months ago and it never worked). For reference I use E-Sys on my computer, not a phone app. for LED brightness i want to make the halos brighter and maybe the main LED lamps if that's possible. |
InstigatorX58.00 |
09-24-2018, 10:07 AM | #7 |
Rep 3,860
If I remember correctly the DRLs were already at 100% brightness, but I may be wrong.
Generally no rear fog lights in the states or how come?
09-24-2018, 11:13 AM | #8 | |
Rep 11
Good luck! |
InstigatorX58.00 |
09-24-2018, 11:44 AM | #9 | |
Cheapskate
4445
Rep 4,993
Rear fog lights are not standard in the US. I think the higher chance of gloomy weather in Europe makes it standard there, but here it's only on European cars with aftermarket tail lights or coding. Like on my volkswagen, I had to swap to european tail lights to get the rear fog light function. A lot of people don't like it though because sometimes it replaces one of the reverse lights with a red fog light, which americans probably need the reverse light more lol. Also european rear lights have to have yellow turn indicators, and US has to have orange reflectors in the front bumper/headlights. There are a bunch of differences in regulations around lighting and improving visibility. |
09-24-2018, 04:04 PM | #10 |
Rep 32
sorry if this one hijacks the thread but ive been looking for answers with no luck and i think someone here might help.
for LCI models that dim the halos during turn signal, does anyone know how to adjust that to make them bright all the time? |
09-24-2018, 06:29 PM | #11 | ||
Rep 198
09-25-2018, 09:22 AM | #12 | |
Rep 32
youre probably trying the f30 code. FEM -> 3060 -> NSL_Verbaut (Value= Verbaut) REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 0x20) REM -> 3063 -> Mapping_Nebelschlussl_L_function (Value=nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 0x21) REM -> 3063 -> Mapping_Nebelschlussl_R_function (Value = nebelschlusslicht) |
InstigatorX58.00 kern4174445.00 |
09-25-2018, 09:59 AM | #13 |
Rep 3,860
And how are you guys controlling the fog lights (when enabled) if you don't have the corresponding switch?
09-25-2018, 01:11 PM | #14 | |
Rep 198
Do you have any pics of before/after? |
09-25-2018, 02:19 PM | #15 |
Rep 32
no but it just uses the outer turn signal ones as fog lights. they still work with turn signals too so its not like they are turning into fog lights only.
InstigatorX58.00 |
09-26-2018, 12:12 AM | #16 |
21st Century Horse Rider
64
Rep 114
For adding tire temperature to the TPMS display, navigate to...
HU_NBT2 3001 EXBOX RDC_DRUCK_TEMP Change "druck" to "druck_und_tempratur". |
09-27-2018, 06:22 AM | #17 |
Rep 308
I have coded and modified my rear fog switch in my F31 LCI. Hardware is there, just need to mod the HL switch and code.
2017 F31 328d xDrive
M Sport M Performance |
10-02-2018, 05:50 PM | #18 |
Rep 32
dont think this works...my f32 2018 only has FEM module. not FLE. and the POLI controlls are not there.
03-03-2019, 04:52 AM | #19 |
Rep 1,509
04-11-2019, 09:32 AM | #20 |
Rep 81
I recently just bought the LCI tail lights for f32, can somebody provide me with the code needed Ford in her lights to be properly working and fully functional. Preferably using BimmerCode
