09-16-2018, 08:13 AM | #617 |
Rep 40,306
My guess is only LED Option on F06 is Adaptive LED, and that non-Adaptive LED in invalid, as in never available as a factory option.
09-16-2018, 09:11 AM | #618 |
Rep 87
is it normal that engine management light comes on after odd flash ? reading ista d, it obviously ses faults from flashing stage but actual car is ok
also i was under impression that EPS hasn't been updated because of below message but now its no longer on list of items to update https://ibb.co/h3WRme Last edited by pcp1234; 09-16-2018 at 11:09 AM.. |
09-16-2018, 02:22 PM | #619 | |
Rep 24
yes there is LED headlights from 2015 LCIs are LEDs now and the one i got is none Adaptive thought because i didn't had Adaptive Xenon I should go for none adaptive LEDs. Last edited by dashti640; 09-16-2018 at 02:31 PM.. Reason: to add picture |
09-16-2018, 02:29 PM | #620 |
Rep 40,306
And in 2015 car with non-Adaptive LED Lights from factory, what is Option Code? Does FA have 5A2? Did you change FA Build Date (Zeitkriterium) for LCI Date?
09-16-2018, 02:38 PM | #621 | |
Rep 24
that is the next step is to get a copy of the FA build data for a none Adaptive LED and try that but i don't know how to get FA data for a F06, F12 or F13 do you think that would work or do i need to change the ZGW to 8SK module? thanks |
09-16-2018, 02:40 PM | #622 |
Rep 40,306
If 552 works, and 5A2 does not, I am not sure why ZGW would matter.
09-16-2018, 02:46 PM | #623 | |
Rep 24
. thanks |
09-16-2018, 02:56 PM | #624 |
Rep 40,306
I have no idea what the issue is. If 5A2 is valid factory option and you use correct FA Zeitkriterium, it should not be an error.
09-16-2018, 03:03 PM | #625 |
Rep 24
09-16-2018, 03:17 PM | #626 |
Rep 40,306
Not one with 5A2 in it. I have a 2016 GC F06, but I have 552 ADAPTIVE LED HEADLIGHT in mine.
09-16-2018, 04:17 PM | #627 |
Rep 24
nice one, one more question if i get a VIN number for a car with 5A2 is it going to be any use for my case to get FA data build or just have to be the file itself-copied from the car ? thanks
09-16-2018, 04:20 PM | #628 |
Rep 40,306
If you have car with factory 5A2, you should be able to load same FA, and VO Code FRM and Light Light Modules without error.
09-16-2018, 05:24 PM | #629 |
Rep 24
09-21-2018, 07:04 AM | #631 |
Rep 40,306
PM sent.
09-22-2018, 05:46 AM | #633 | |
Rep 2,302
https://www.bimmerfest.com/forums/sh...d.php?t=983244 |
09-22-2018, 07:46 AM | #634 |
Rep 40,306
PM sent.
09-23-2018, 09:47 AM | #635 |
Rep 87
updated another car yesterday, below time stats; was F010-13-07-506 to F010-18-07-530
1. ZGW = 3m 7sec 2. EGS = 2m 28sec 3. DSC = 4m 28sec 4. PDC + JBBD = 1m 42sec 5. EKPM = 1m 31sec 6. FZD = 2m 22sec 7. FRM = 4m 43sec 8. TBX + ZBE = 3m 10sec 9. TRSVC = 4m 37sec 10. SZL + EMF = 1m 54sec 11. EPS = 1min 32sec 12. HKMF = 1min 37sec 13. TCB = 12min 53sec 14. SM = 3m 6sec 15. DME + KM = 6min 45sec overall 55mins and 55sec |
atzebmw588.00 |
09-24-2018, 09:34 AM | #637 |
Rep 40,306
PM sent.
10-10-2018, 04:33 PM | #638 |
Rep 87
i keep getting this error on EPS, any reason or guidance please?
[EPS - 30] - [Exception - EPS - 30] SVK-Ist does not match expected SGBMIDs for ecu ECUId:EPS_0x30. Excpected (relevant process classes only): [hwel_00000e1c-001_004_005, hwap_00000e21-255_255_255, hwap_000002be-255_255_255], Actual (relevant process classes only): [hwel_00000e1c-001_004_000, hwap_00000e21-255_255_255, hwap_000002be-255_255_255], Missing SGBMID(s): [hwel_00000e1c-001_004_005], Surplus SGBMID(s): [hwel_00000e1c-001_004_000] |
