03-12-2020, 04:22 PM | #23 |
Rep 4
BMW f30 320d XDRIVE rear whine 60-72 mph
Hi,
I sound like i am having a similar issue! Between 60-72mph under light to medium acceleration there is a loud whine noise coming from the back of the car (can not be heard when sitting close to the steering wheel), the noise goes instantly when the throttle is taken off, so not road or wind noise. I took the car into BMW to check it over- which they came back and said they could not hear the noise but the tyre treads were odd which may have been affecting the XDRIVE (car bought from bmw dealer 2 months earlier). All four tyres replaced with no difference in noise (non runflats). I can only assume someone short was driving it on the test? Car is going back into a different dealer next week as my new commute includes more travelling between 60-70, which is driving me insane! The noise sounds like a machine gearbox whine, maybe some kind of harmonic going on at that speed? I have had the same car previously and a hire car of the same model and both did not make this noise. Has anyone had this issue and had it resolved so i have something to put against BMW when they potentially tell me theres no issue again? Much appreciated! BMW f30 2016 320d XDRIVE 49,000 miles (noise has always been there from buying the car at 24,000) |
03-16-2020, 01:37 PM | #25 |
Rep 118
I know some of you will be skeptical but I had the same exact issue. I had used Techron (for different reasons) regularly. I wanted to try Royal Purple fuel system cleaner and the noise disappeared completely. Now I can hear the engine when I kick the throttle down. My own question is that I don't know if Techron and Royal Purple product that I used are exactly the same. Give it a shot because dealers won't do anything. I tried 4 different dealers and got no results. The last one even told me that they recorded the noise and sent it to BMW AG for analysis.
08-03-2020, 06:48 PM | #26 | |
Total Scrub
36
Rep 25
Hey - did you ever get any resolution on this? I have the same issue on my recently purchased 440i (which I didn’t notice since I didn’t take it up to 70-80 during the test drive. Doh!)
The dealership was useless and said it is a characteristic of the car but its driving me crazy! Quote:
08-03-2020, 11:32 PM | #27 | |
Rep 240
My guess is that it is either the turbocharger or the ZF8 transmission. I did read somewhere that turbos do tend to whine and the most carmakers try hard to mask the noise. But a few of us seem to have the noise pumped into the cabin unfortunately. As with anything mass produced, I feel that many more owners have the noise and either don't notice or can't hear it. Either way, it's present whether the car is hot or cold. And the tech said they can't find any codes to lead them to the cause. It is at least documented that I have this issue should anything become of it in the future. |
08-16-2020, 09:33 PM | #28 |
Rep 338
Same here, i went to two different Indy shops and got two different answers lol 🤷🏻*♂️. One said it kinda of sounds like my rear diff is going but not bad enough to replace and the second said its the tires from the Run-Flats. They both checked for Wheel Bearings, all good there...
Also the second shop i got both diffs fluid changed while there..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
08-17-2020, 05:41 PM | #29 |
Rep 367
Did you mention possibly being the transfer case?
To add to my concern that it is transfer case, looking thru bimmerlink I found code 480AB5 Transfer case Long-term protection function requested by the LMV Couldnt find much on it. It was not delete-able. |
08-17-2020, 08:00 PM | #30 |
Rep 338
You know i was thinking that also, but to make sure i am going to have that fluid changed out very soon as the Indy shop i will be going to for future servicing is only doing that for: $150ish out the door, the shop will use Liqui Moly when its applicable as they did for my recent diff changes both front and back.
IG: DadzBmer_N2o |
