08-06-2018, 11:28 AM | #1 |
Rep 3,030
Hey guys here's a good read on brakes...not saying it's correct or validating the article but thought I would share.
M sport rotors: Front: 340mm rotors, 4-piston Brembo caliper painted blue Rear: 345mm rotors, 2-piston Brembo caliper painted blue M performance rotors: Front: 370mm rotors, 4-piston Brembo caliper (yellow/gold, orange, or red color) Rear: 345mm rotors, 2-piston Brembo caliper (yellow/gold, orange, or red color) The pads are also different. http://www.tuningforbmws.com/?q=f30-328-brake-specs
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
08-06-2018, 01:21 PM | #2 |
Rep 415
Drives: 2019 440i Coupe
Your link is only accurate where your car is concerned (F30 328i).
For those with a 335/340/435/440 after MY2013 here are the specs: https://www.turnermotorsport.com/e/t...ke-differences M Sport and M Performance rotor sizes are the same front and rear, and the M Sport pads appear to be preferred (even with their high amount of dust). |
08-06-2018, 01:27 PM | #3 | |
Rep 5,457
Drives: F30
08-06-2018, 01:27 PM | #4 |
Rep 216
Thx buddy. I would love the blue M-sport setup on my f31. Purely for aesthetics as the stock brakes are pretty amazing for my needs (no track days)
How are they for daily driving? Too bitey? |
08-06-2018, 01:30 PM | #5 | |
Rep 3,030
One thing I did notice though is they don't get neatly as hot as the old ones.
2016 BMW F80 ZCP
kern4174446.50 Hammer Werke101.50 |
08-07-2018, 01:10 AM | #7 |
Rep 10,473
08-07-2018, 02:36 AM | #8 |
Rep 3,869
I have not noticed any excessive brake dust from my M Sport brakes. Of course I cannot compare to the BMW basic ones, but based on experience.
08-07-2018, 06:14 AM | #9 |
No 55mph
1621
Rep 8,476
There are (2) versions of the Blue Brembo calipers:
4 Piston Fronts for 340mm Rotors - have '340' cast into backside of caliper 2 Piston Rears for 345mm Rotors 4 Piston Fronts for 370/380mm Rotors - have '370/380' cast into backside of caliper 2 Piston Rears for 345mm Rotors The latter are found on F8x cars - I have the blue brembos with 370mm front/345mm rear on my 435 that came from an M4
Silverturfer_f303.00 burnurass92.00 |
08-07-2018, 08:47 AM | #10 | |
Rep 962
kern4174446.50 |
08-07-2018, 10:20 AM | #11 |
Cheapskate
4447
Rep 4,993
I feel like all of this is incorrect lol. The issue with calling anything "Msport brakes" is they don't come on all cars with the MSport package/the MSport package isn't always required to get the blue brakes.
I've been doing a lot of research on this lately as I'm searching for a budget friendly BBK, and this is what I have found, confirmed with part numbers. As far as F3x cars go: Base -35i/-40i, MSport -28i/-30i Front: Grey 4-Piston Calipers (PN: 34116850931/34116850932) 340mm Rotors (PN: 34116792223) Rear: Grey 1-Piston Calipers (PN: 34216850973/34216850974) 330mm Rotors (PN: 34216864899) Track Handling Package -28i/-30i/-35i/-40i Front: Blue 4-Piston Calipers (PN: 34116875649/34116875650) 370mm Rotors (PN: 34106797606) Rear: Blue 2-Piston Calipers (PN: 34216799461/34216799462) 345mm Rotors (PN: 34206797607) MPerformance Brakes Front: Red/Orange/Yellow 4-Piston Calipers (PN: 34106875651/34106875652/34106875653/34106875654/34106875655/34106875656) 370mm Rotors (PN: 34106797603) Rears: Red/Orange/Yellow 2-Piston Calipers (PN: 34206855481/34206855482/34206855483/34206855484/34206855485/34206855486) 345mm Rotors (PN: 34206797600) The only cars that came with 340mm front brakes with blue calipers are the F2x 2-series models. Edit: And F31/F33/F34. Also, the MPerformance rotors appear to be the same as the Track Handling Package rotors, except they are drilled and slotted. They are listed as an optional upgrade for the standard blue brakes. And yes, the 4-piston calipers for 340mm brakes are different than the calipers for 370mm brakes. Confirmed by roll_the_dice https://f30.bimmerpost.com/forums/sh...0#post21760990
08-07-2018, 10:57 AM | #13 | |||
Rep 3,539
The main body of the 340/370mm caliper is the same (so same brake pads and retaining/rattle hardware), but the mounting ears are different to accommodate the different diameter rotors. |
08-07-2018, 11:36 AM | #15 | |||
Cheapskate
4447
Rep 4,993
I had a basic level of awareness up until a few weeks ago when i started seriously looking, and the main thing I've gathered is there are so many unique combinations for no reason that I feel like BMW was just throwing money out the window. All I know is I want 370mm fronts/345mm rears without paying $1500 lol. |
08-07-2018, 11:39 AM | #16 |
Rep 397
Are the grey unpainted calipers 4 piston as well? Turner motorsports have them listed as single piston.
https://www.turnermotorsport.com/t-b...ke-Differences |
08-07-2018, 12:29 PM | #17 |
Rep 552
I've got the blue M-sport brakes and really tired of the brake dust from these OEM pads...definitely replacing /w ceramic pads when these wear out within a few months. Makes my black wheels look brown. LA traffic..
08-07-2018, 12:34 PM | #18 | ||
Rep 3,539
Maybe you're getting a floating caliper and fixed caliper confused. Look them up, and you'll realize you could never mistake one for the other. |
08-07-2018, 12:39 PM | #19 | |
Rep 148
https://www.shopbmwusa.com/PRODUCT/3...E-BRAKE-SYSTEM |
08-07-2018, 01:21 PM | #20 |
Cheapskate
4447
Rep 4,993
Ah gotcha. I misunderstood.
08-07-2018, 01:35 PM | #21 |
Ex-Lurker
23
Rep 29
08-10-2018, 08:52 PM | #22 |
Rep 1,288
I have the blue-calipers and the discs are humongous! 370mm's... can't believe how big they are... needless to say... stops on a dime with 9cents left over...
