03-29-2014, 08:24 AM | #6139 |
Rep 28
03-29-2014, 10:24 AM | #6140 |
Rep 1,044
Due to a system crash, I need to rebuild the virtual machine on my Mac in which I code my MY12 F30.
I have E-Sys 3.23.4, a valid token and PSdZData 50.4, which worked fine the last time I coded my car -- and the dealer hasn't updated anything (yet). Before I take the time to rebuild everything (install XP in a VM, etc.), I wonder if anyone would recommend an updated E-Sys and/or PSdZData level. I kinda don't think it makes any difference, but wanted to ask the gurus. Appreciate the input.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 Last edited by Yobyot; 03-29-2014 at 10:31 AM.. |
03-29-2014, 10:27 AM | #6141 |
Rep 40,841
There is no point in updating anything unless car has newer than 50.4.
03-29-2014, 01:23 PM | #6143 | |
Rep 12
partially working!
Anyone with a clue as to what I am missing here? Is there another config parameter that needs to be changed or is this being locked out some other way? Thanks for any insights into this... Lynn Last edited by ellweber; 03-29-2014 at 03:30 PM.. Reason: lousy typist and proofreader... |
03-29-2014, 01:44 PM | #6144 |
Rep 205
Can anyone help me figure out where I need to extract my updated PSdZdata files? I downloaded the 2 lite files but they both have a large number of unorganized files (i.e., not in a predetermined folder structure). It looks like they match what is currently in my esysdata\psdzdata\swe folder but the 'swe' folder has subfolders that match the prefix of all the files within the two Zips. Thus I'm hesitant to just drop them all into the 'swe' folder...
if it helps, some of the subfolders that seem to already be established based on my old PSdZdata are swe\blup; swe\btld; swe\cafd... any thoughts? can i just delete the current content and replace with the extracted files from the two zips without a problem?
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats |
03-29-2014, 03:30 PM | #6145 | |
Rep 286
If i remember correctly. When I tried this.... After writing the donor/valid VIN. and read the fsc codes it shows up as still accepted. However when you allow the car to sleep or reboot the NBT/CIC it took a while for it to reject. You will see Navi and Voice functions get deactivated on the screen too. Read the fsc again after it will definitely be rejected.
Same goes when writing the original VIN back. For me at least, it took a while. BTW. I have an Emulator on mine. Quote:
03-30-2014, 03:04 AM | #6146 | |
Rep 28
But I thought you "write" using VO code method or you use the FSC extended feature? Maybe both will have same result??? |
03-30-2014, 09:36 PM | #6147 |
Rep 1
Hi Shawnsheridan,
Just received my MY2014 320ED a couple of days ago. Would you be kind enough to send me info on the latest coding software please. I want to code out the inaccurate speedometer reading which really bugs the life out of me. Also would like to get BMW connected working if possible but I understand I may need an additional BMW code for that. Kind Regards |
03-31-2014, 08:59 AM | #6148 |
Rep 28
Hi Shawn,
I think since I don't have the hardware emulator, whenever I change my nbt's VIN, it will be changed back to follow the car's VIN. Because of this I will not be able to update the service and enable bmw online/internet since my VIN don't have this service. Maybe the solution is to purchase an emulator and activate the service then take it out.... do you think my thinking make sense? Hi vithy, Did you take out your emulator when you perform your change? |
03-31-2014, 11:17 AM | #6149 | |
Rep 40,841
I don't think you will be able to correct the Speedometer Advance though. BC_V_KORREKTUR seems to do nothing. 6NR Connected Drive will require a 9C FSC Enabling Code.
03-31-2014, 11:29 AM | #6150 | |
Rep 40,841
03-31-2014, 07:31 PM | #6151 | |
Rep 1,772
Is there any further progress on this? I have f30 with kafas2, LDW, LCW, FCW, ETC. I added 5AC and VO coded kafas2, nbt, kombi, and FEM body for good measure. However, I don't have the stalk button to activate, and the code for auto on in f10 does not appear to exist. Only reference to FLA was FLA_Aktiv. Which I changed to A Oder position 2. Still nothing. Any ideas? |
04-01-2014, 09:21 AM | #6153 | |
Rep 28
Do you have any FSC cert for 6F (Sat-radio) or E5 (laptimer)? Since it will accept any VIN, I want to see what is the status when I write in the cert. These are the only 2 without certs. The rest are all activated. By writing an invalid cert it will not destroy the valid cert, am I right? Thanks. |
04-01-2014, 09:22 AM | #6154 |
Rep 40,841
PM sent.
04-01-2014, 09:25 AM | #6155 | |
Rep 40,841
04-01-2014, 10:33 AM | #6156 |
BooGooBird
17
Rep 79
It seems like nothing shows up when in full map mode on CIC even on high way w/ exits.
04-01-2014, 11:19 AM | #6157 |
Rep 13
Hi Shawn,
I'd like to start coding for my 435. Could you please PM me with the information needed to obtain the latest software, at your convenience? Thank you very much for your help! |
04-01-2014, 11:24 AM | #6158 |
Rep 40,841
Sorry, but I can't, as you are unable to send or receive PM's yet.
04-01-2014, 02:52 PM | #6159 |
Rep 13
04-01-2014, 03:08 PM | #6160 |
Rep 40,841
Reply sent.
