10-11-2018, 02:07 PM | #23 |
Rep 268
Make sure the build up of rust on the outer edge of the disc isn't making contact with the back plate.
Sometimes the back plate can become knocked/ distorted / damaged and cause a similar noise if it makes contact with the disc outer edge, often when cornering. I had a Lexus bearing replaced, the noise didnt go and it really was that simple. |
10-11-2018, 02:19 PM | #24 | |
Rep 820
Guess I’m just slightly cynical about insurance trying to get out of paying. I’d still use the dealer tho! |
10-11-2018, 02:26 PM | #25 |
Rep 3,664
As has been commented on above, they don't just change the bearing these days - the complete hub is changed and hence the higher cost. My dad had the same recently on his XC60. Less than 50k miles and both front bearings shot.
Volvo charged around £750 for the pair so that price seems consistent with major main dealer pricing. Might be worth asking an Indy if intends to press the bearings out as opposed to just replacing the whole hub. Pair of wheel bearings (inner and outer) is no more than £50 from an engineering company and not much difference in labour cost to change.
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
10-11-2018, 02:52 PM | #26 |
Rep 5,681
On the face of it that's just abysmal! Going back over 20 years I had company Cavaliers and Mondeos that did over 100k miles without needing any wheel bearing replacements so for two to go at less than 50k miles implies parts that are just badly engineered and not up to the job (unless of course your dad does a lot of off-roading in his XC60! ).
10-11-2018, 02:53 PM | #27 | |
Rep 15,858
Many a wheel bearing has been changed when it is tyres that are at fault. If there is a bit of 'heel and toe' tread wear, it can often get a whine as the tread depth reduces. Sometimes even the best of mechanics get it wrong. I'd be tempted to change the tyres if it was me, and wasn't obvious it was definitely a wheel bearing. |
10-11-2018, 02:58 PM | #28 | |
Rep 15,858
10-11-2018, 03:01 PM | #29 | |
Rep 5,681
I'm certainly not a mechanic but the noise I'm getting doesn't sound like any worn wheel bearing I've ever heard so I'm hoping changing the tyres will do the trick; if it doesn't I may have to bite the bullet with the wheel bearing change but I'll cross that bridge if and when I come to it! |
10-11-2018, 03:12 PM | #30 | |
Rep 3,967
Rukka2647.00 |
10-11-2018, 04:25 PM | #31 |
Rep 542
Is the noise apparent straight away each time you use the car or does it take some time before you hear it?
I’m changing rear tyres this weekend for a similar reason. I hear a rumble which only starts after a few miles at speeds above 65mph -ish. But once it starts, it’s there at all speeds until the car has been parked up for some hours. 20 miles on A roads going to work isn’t enough to trigger it. (50 to 60mph –ish) Cars done nearly 120k. I've already had rear disks and pads changed (needed them changing) but the noise was there before these were changed. It's just had an mot. I would think (hope?) a wheel bearing fault would be picked up during mot? Just replacing the tyres would be a nice fix.
335d xDrive
10-11-2018, 05:26 PM | #32 | |
Rep 5,681
10-12-2018, 12:49 AM | #33 |
Rep 159
Had both rear bearings replaced at 91k under extended warranty. Only paid £250 excess but bill would have been £850.
No play in bearings they were just noisy - drone at higher speeds.
_________________________________________
M135i F40 2020 - Misano Blue l Tech Pack 1&2 l Comfort Pack 1&2 l Adaptive Suspension Previous: 335d F31 MSport 2017 - Sapphire Black |
10-12-2018, 04:51 AM | #35 | |
Rep 2,444
Drives: 2018 630iGT sport
On an e39 years ago that had COntinental tyres on, they were almost down to the wear markers and would make a noise exactly like a wheel bearing failure. Would starting whining about 35mph and would stay constant (like a wheel bearing does) any speed above that. Would get slightly less when cornering as well, which made it seem even more like a wheel bearing. New tyres and noise was gone. If the OP needs new tyres anyway, nothing to loose by changing them first and see what happens. |
10-12-2018, 06:58 AM | #36 |
Rep 15,858
Another pointer to trouble shooting tyres vs. wheel bearings; tyres often change the note/pitch when the road surface changes, bearings will be pretty constant.
I'm the sort of guy whole is always on the alert to new sounds and vibrations, in any vehicle. Anything that seems to hint at bearings has to be explained. My summer tyres are now about 4 - 5mm and starting to get a bit noisy on rougher surfaces. I've recently thought it seems a bit like a bearing at the rear, but as soon as I'm on a smooth surface, noise is gone. Definitely a tyre induced sound. |
10-12-2018, 07:48 AM | #37 |
Rep 542
I’m having winter tyres put on a 18” spare wheel set I have for the F30 335d.
I was going to use the fronts from that set to do the test tomorrow on the E90 which has the problem. (Same tyre width). I’ve just realised, the E90 has 17” wheels. It's going to look really odd with 17’s on the front, 18’s on the rear and the wheel styles are totally different...
335d xDrive
10-12-2018, 08:32 AM | #38 | |
Rep 777
10-12-2018, 08:41 AM | #39 |
Rep 2,444
No different really from having a totally different size space saver spare on when you get a flat.
10-12-2018, 09:05 AM | #40 | |
Rep 777
I think with a space saver you drive with restrictions having 2 totally different wheels and tyre sizes could be classed as changes to the spec I could be wrong but be careful. |
10-12-2018, 09:39 AM | #41 | |
Rep 5,681
As a slight aside, I was given an F31 320d Shadow Edition S-Drive as a courtesy car and two observations. Firstly, it confirmed my suspicion that the turning circle of the X-Drive is indeed larger; the S-Drive was noticeably easier to manoeuvre in tight spaces and on my drive so a definite negative against X-Drive there. Secondly, although I think the 35d lacks the refinement of the 35i or 40i petrols, my god it's on a different planet from the 20d; that really is a bit of a clunky lump to sit behind IMO but if nothing else the experience has made me appreciate my own car a bit more! |
10-16-2018, 10:48 AM | #42 |
Rep 5,681
Brief update, new rear tyres fitted today (which were getting due anyway) but sadly the noise persists; looks like it is indeed a wheel bearing then and car booked-in to have the work done the week after next.
It is at least covered under the extended warranty albeit I'll have to pay my £250 excess; just hope the replacement solves the problem as I won't be happy if having forked-out for my excess the noise is still there! |
10-16-2018, 10:51 AM | #43 | |
Rep 1,470
10-17-2018, 01:38 AM | #44 | |
Rep 5,681
However, it seems some dealers are prepared to try it on - see post number 7 in the thread below! https://f30.bimmerpost.com/forums/sh....php?t=1544192 |
