BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > New turbo time
Studio RSR
      12-05-2018, 11:25 AM   #1
Fronttwelv
Fronttwelv's Avatar
Drives: 14 328i xdrive msport
Getting loads of white smoke at startup. Getting ready to replace the oil pipe this week but I'm sure it's new turbo time. Should I get a used OEM unit? A remanufactured OEM unit or a bigger unit with matching tune? I really want an OEM driving experience but wouldn't mind the extra kick. I'm not doing any drivetrain modifications and really don't want to upgrade engine hardware either. What would YOU do?
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO
      12-05-2018, 12:18 PM   #2
s3ri3s1
s3ri3s1's Avatar
188
Drives: alpine white 328
How many miles are on your car? If you have the coin, going with an upgraded turbo would be more fun
      12-05-2018, 12:56 PM   #3
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Well to start, the oil feed line could be the issue, and you could fix that and be fine, no need for a new turbo.
If that's not the case however, what I would do is get a bigger unit from MHI because I already have most/all of the additional hardware I would need, but it sounds like stock is more your style. If you get a bigger turbo it has to be accompanied by additional hardware, which doesn't sound like something you want to do. If I were you, I would replace with a new stock unit. If you wouldn't mind an extra kick, maybe add a tune after the new turbo is in, but it doesn't sound like the upgraded turbo route is right for you.
      12-06-2018, 05:56 AM   #4
Fronttwelv
Fronttwelv's Avatar
Just turned 60k
      12-06-2018, 02:10 PM   #5
MRMIAGI
MRMIAGI's Avatar
Drives: 2015 228i THP M-Sport Tech Lig
2015 BMW 228I  [0.00]
Originally Posted by Fronttwelv View Post
Just turned 60k
Wow that's kinda concerning that's happening already at 60k.
      12-06-2018, 06:11 PM   #6
Fronttwelv
Fronttwelv's Avatar
Believe me I'm not happy about it. I've had it a little over a year and it's going to be on the chopping block soon.
      12-10-2018, 01:58 PM   #7
BMWF30PGH
BMWF30PGH's Avatar
Drives: 2016 320i xDrive
Just turned 60k
I would try a good faith repair through the dealer. What could it hurt to try?
      12-11-2018, 01:36 PM   #8
Fronttwelv
Fronttwelv's Avatar
Finishing up install today. It was a PITA getting the turbo out. Ah well you live you learn.
      12-22-2018, 07:08 PM   #9
Fronttwelv
Fronttwelv's Avatar
Forgot to update. There was oil everywhere when I took the intake, intercooler, turbo/mani and downpipe apart. Honestly I thought something was terribly wrong. I cleaned it all up, replaced the oil pipe and put it back together. The next couple days were spent putting miles on the car, checking oil level and observing cold start excess smoke. Other than the car smelling like a 2 stroke for a couple days, Nothing. I think I'm good for now but time will tell.
