12-08-2018, 11:31 AM | #1 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
HP Estimation with Intake & JB+
I clocked my 0-60mph at 5.03 seconds with the P3 ODBII vent gauge. Injen claims an increase of ~22hp, and JB+ (at max setting) of ~25hp.
So, using a 0-60 calculator (not 100% accurate, I know) I came to this: 357.7 x 16% Drivetrain Loss = 57.232 357.7 - 57.232 = 300.468 whp Seem like an overestimation?
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan Last edited by whoismorggan; 12-08-2018 at 12:01 PM.. |
12-08-2018, 11:59 AM | #2 |
Rep 943
Drives: F30 328i Msport
Was this using launch control? Cant argue with the ~5 second 0-60, pretty good!
whoismorggan553.00 |
12-08-2018, 12:04 PM | #3 |
Rep 3,680
The 0-60 seems right, but the intake adds ~0hp, so using stock dyno data from Dinan, the stock whp is around 230, add about 25 for JB+ which is about right, and I'd estimate your whp to be around 255-260, so maybe 290-300 at the crank.
12-08-2018, 12:07 PM | #4 |
553
Rep 802
Probably right. I thought I read the intake would add a little bit in the low range.
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
12-08-2018, 12:08 PM | #5 |
553
Rep 802
Yes, using LC. Thanks!
12-08-2018, 12:52 PM | #6 |
Rep 3,680
I've read the same but chose not to believe that a tube and filter intake will add power over the proven-to-be-not-restrictive stock air box. There are claims that it adds anywhere from 5-20hp, but from the reading and data I've seen, I (and many others) have come to the conclusion that it adds close to no hp. The benefit of the intake is really just for sound, and it does a pretty good job at that .
12-08-2018, 01:50 PM | #7 | |
553
Rep 802
12-08-2018, 01:51 PM | #8 | |
553
Rep 802
4.89!
12-08-2018, 03:32 PM | #9 |
Rep 59
What mods do you have installed?
2013 EB 335i Xdrive, Msport package, BM3 Stage 1 93 octane, VRSF Chargepipe
12-08-2018, 07:38 PM | #10 | |
553
Rep 802
12-09-2018, 12:51 AM | #11 | |
Rep 943
I find with 255's in the rear its next to impossible to break grip off the line, unless its pouring rain, im running bridgestone RE980 all seasons (great tire btw) |
12-09-2018, 11:58 AM | #12 | ||
553
Rep 802
Staggered: 245/35 and 265/30 Achilles ATR Sport. Cheap tires = 0 grip in the rain. I need to upgrade soon.
01-04-2019, 05:05 PM | #13 |
553
Rep 802
Right on the money.
N26Ghost496.50 |
01-04-2019, 05:47 PM | #14 |
Rep 190,802
01-04-2019, 05:48 PM | #15 | |
553
Rep 802
I need more power Mike, help me!
01-04-2019, 05:49 PM | #16 |
Rep 3,680
Good numbers and good on you for getting some objective data! Pretty impressive torque numbers as well
01-04-2019, 05:51 PM | #17 |
Rep 190,802
Send the JB+ to us, we will use it as a credit for a JB4 + Intercooler + Charge pipe
whoismorggan553.00 AsianBill73.50 |
01-04-2019, 05:52 PM | #18 | |
Rep 3,680
OP if you want any noticeable increase in power over where you are now, you need a catless downpipe, and if you want to do it right, a flash tune and intercooler.
01-04-2019, 05:54 PM | #19 |
Rep 190,802
Jb4 + Intercooler will definitely add power over Jb+ with stock FMIC
01-04-2019, 06:00 PM | #20 | |
Rep 3,680
How much of a benefit is there really going from JB+ to JB4? Running the same amount of boost or close to it... Not much else the JB4 can do to add power. I'd suspect the difference is minimal. I'm sure it's there, but minimal. And then, not that this is something you don't know but for the sake of the thread, the FMIC is better for consistent power rather then straight up adding power. Like I said, I'd recommend BM3, catless DP and FMIC.
01-04-2019, 06:03 PM | #21 | ||
553
Rep 802
01-04-2019, 06:04 PM | #22 | |
Rep 190,802
Jb4 has very important features which are not available on the JB+ For example the boost by gear (most important one in my opinion) and boost by RPM
whoismorggan553.00 Pittcrew34.00 |
