12-30-2021, 05:21 AM | #4094 |
Rep 3
12-30-2021, 05:22 AM | #4095 | |
Rep 3
12-30-2021, 05:40 AM | #4096 |
Rep 3
HELP
There is some way to update from android 9 to 10 with non snapdragon version?
mcu: 415144 blzh-ccc-HW8-190710(b1280_170325) FrameworkVer: 9PQ2A.190305.002 eng.work2.20190912.164845 ANDROID: 9 app Ver: 2019092901T_1280x480_970 RAM: 4 UUID:010E6A88-3BFD-00B6-0000-000100001A88 |
12-30-2021, 07:59 AM | #4097 | |
Rep 2,348
Drives: E63 645Ci
01-02-2022, 02:42 AM | #4098 |
Rep 8
01-05-2022, 10:53 PM | #4099 |
Rep 9
Hey guys.
So I bought a unit from someone, managed to install it without instructions and now Im trying to Understand what I have. Its the px6 unit with 2gb of ram, running android 8. From what I read here, its impossible to upgrade it to android 9/10 (?) Eventhough the seller claimed it had a built in apple CarPlay, Im guessing these units wouldnt have that built in. Can a USB adapter be used to accomplish apple CarPlay with my head unit? Here is what Im running: |
01-07-2022, 06:35 AM | #4100 | |
Rep 47
I've been looking for this update for a long time, it seems to correct many bugs (wifi access point disconnection, in ID7 you can scroll through the left panel, open small settings options, control again in carplay with idrive knob. I could see it on the screen of an acquaintance. |
01-07-2022, 06:38 AM | #4102 |
Rep 47
01-07-2022, 07:42 AM | #4103 | |
Rep 2,348
Drives: E63 645Ci
It might as well have it. It would've been called Speedplay or something like that. On newer units it's called Zlink. But all of these apps would require activation from Chinese so if the unit was factory wiped, chances are the activation is gone as well. In that case Carlinkit is your best bet. |
01-07-2022, 02:31 PM | #4104 |
Rep 9
Thanks for the response.
Unfortunately it does not Have any of the apps mentioned above for the car play. It does however have the EasyConnection that wirelessly mirrors iPhone (Xr, iphone 13 on the other hand does not work at all. Displays gray screen) Installed AutoKit app, it installs but obviously not working without a device. If my device had built in chip for apple CarPlay would autokit app work? Also I cant connect to the units Bluetooth. Its not showing up when searching for it. This is the Bluetooth screen on the device. |
01-07-2022, 03:07 PM | #4105 | |
Rep 2,348
Drives: E63 645Ci
Regarding CarPlay, you need this dongle for AutoKit app to work. The app requires very specific hardware. |
01-07-2022, 04:31 PM | #4106 |
Rep 9
Thanks!
Just realized the USB ports i connected to the device, seem not to be working. (Tested with my iPhone. Its not charging when plugged in) Im guessing it should? (Also when going into androids settings USB section is grayed out. |
01-07-2022, 07:47 PM | #4107 |
Rep 2,348
Drives: E63 645Ci
Not necessarily. These ports can provide up to 0.5A which is just enough to charge Nokia 3310 but not any modern smartphone. Just plug in any USB stick and check if it's getting detected.
01-07-2022, 11:03 PM | #4108 |
Rep 9
Aah, no luck either with the usb sticks. Tired 3 different sizes and formats.
Also I realized the unit does not provide any sound. Tried connecting audio out to the aux - without any luck (there is actually 2 female audio out - non of which seem to work. I start to think my unit is a mess all together. |
01-15-2022, 11:06 PM | #4109 |
Rep 13
Hello .. Does anyone has their set reboot by itself, using it less than 5mins or running?
I am hvg MTK version/ Android 10, and noticed the set will self reboot continuously. However it happened under hot weather conditions, ard 38deg C .. After the car has cooled down, it can run back to original condition. During the loop mode, i can return back to original IDRIVE with no problem while reverse-camera also no issue (Original car doesnt have). The only thing i changed was setting the air-vent timer to activate itself and the 1st occurence of reboot happens exactly the same time as timer. Not sure it is related or not. |
01-16-2022, 12:40 AM | #4110 | |
Rep 1,546
You should do a test and count how many times out of 10 times when the ventilation timer starts the unit reboots. If it's a CAN signal issue I'm not sure what you can do unless there was some kind of a firmware upgrade already to fix that. If it's not a genuine snapdragon unit may have to search for an update. But, if it's rebooting because it gets overheated then maybe you can take it apart and make sure the heat sink touches the casing (if any). Or add a heat sink to the chip(s). Or drill some holes in the casing.
01-16-2022, 01:40 PM | #4111 |
Rep 4
help me please
Hello everyone, first of all thank you for the information contained in this discussion. I just installed a 10.25 snapdragon (dGS) system on bmw f20 with nbt 8.8 system, everything smokes perfectly, but the audio on the Android part is almost non-existent even at maximum volume. I tried to connect the aux under the armrest but the situation remains unchanged. I assume it's a software problem as the wiring has been checked. Can anyone help me? A thousand thanks
01-16-2022, 01:52 PM | #4112 | |
Rep 1,546
As far as USB drive sizes: some had luck with 8GB size, but generally cannot go above 32GB. |
01-16-2022, 01:57 PM | #4113 | |
Rep 1,546
01-16-2022, 04:59 PM | #4114 |
Rep 4
I tried various equalizer options, the only way to hear the audio slightly is to max out the volume of the aux input. But it feels like the sound is coming from headphones, pianissimo and noisy almost non-existent!:gridare:
