BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Why does the water pump activate even when the car is cold after locking the doors?
      11-10-2024, 05:05 PM   #1
RezNaz
Drives: BMW 320i Xdrive
Hello friends, I hope you can guide me to find the problem!
Some time ago, the car did not start and I realized that the battery was completely dead! I replaced the battery and registered it. After 2 days, the battery was completely discharged again. No error codes found for low battery or anything related. I checked with ISTA+ and bimrmerlink.
By chance, I noticed the sound of the water pump after locking the doors! Apparently, it doesn't matter if the engine is cold or hot, this happens.
I changed the thermostat last year because I thought the engine was a bit hot. I will say that I have not received any errors or warnings for engine heat so far.
I open the negative terminal of the battery every night so that my battery does not discharge, I hope you can guide me.
I want to thank you in advance.
BMW 320i XDrive 2014
91,000 Km
      11-10-2024, 10:49 PM   #2
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
It's a known problem with some BMW's. You'll need to continue disconnecting your battery until you get the water pump replaced.
2017 430ix Gran Coupe
      11-10-2024, 11:14 PM   #3
RezNaz
Thank you got your reply, are you certain that this is an issue from water pump? Could it be an issue with relay or from a sensor that is draining he battery?
      11-11-2024, 11:27 AM   #4
Arthurrs
It certainly could be. Find yourself a good indy mechanic to diagnose the problem correctly.
Glean what you can from these three threads:
https://f30.bimmerpost.com/forums/sh...r+pump+running
      11-11-2024, 06:51 PM   #5
RezNaz
Thank you so much.
