BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Upgrading stock 17" to 19" on 2017 330i questions
      05-24-2021, 04:39 PM   #1
30secs
Drives: Bmw 330i
Hi all, I have a 2017 330i with 17". I found a bmw 19" set with Dunlop tires (2018 540i): front 245/40/19r, back 275/35/19r.
will these work for my car?
Do I need to do any modifications or can I just swap them myself?
any other adjustments/concerns needed?
Thank you!
      05-24-2021, 04:45 PM   #2
zamboni
I want to drive a Zamboni
zamboni's Avatar
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
Don't think the offset would work on F30, stay with compatible wheels.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      05-24-2021, 09:20 PM   #3
jared21927
Drives: 2016 550i
Check the bolt pattern because the new BMWs use 5x112 whereas F30s use 5x120. I could be wrong here, but I believe I've read that in multiple places. Either way, confirm for your own benefit.
      05-24-2021, 09:59 PM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Ask here: https://f30.bimmerpost.com/forums/fo...play.php?f=423
Two negatives is that they'll ride harder and noisier and you'll lose gas mileage.
      05-27-2021, 08:16 PM   #5
Heel328
Heel328's Avatar
79
Drives: 2013 328i 6MT
Likely that's a bigger setup than what you have stock. Even if the rims could work, to match your current tire's circumference you'd need smaller tires on those rims. Perhaps 35 (front) and 30 (rear) series tires. I don't know what is stock on your car currently to compare..
2013 328i 6MT
1995 S6*
1993 S4*
1984 944*
1988 16V GTI*
      05-28-2021, 03:19 AM   #6
HighlandPete
Drives: BMW F11 535i Touring
The simple answer is, G-series rims are not compatible with the F-series, centre hub and bolt PCD are different.
J555578.50
      05-29-2021, 05:13 PM   #7
kpgray
GasCompressor
kpgray's Avatar
341
Drives: 2022 Porsche 911 Cabriolet
Taller Tire and incorrect wheel rim offset. Beware of the issues all of the above can cause. If you run the 5-series 19" wheels as is on your 3er, I believe the standard tires will rub.
Most stock OEM 19" setups were staggered wheel set up and have higher speed limiter. So the tires are a higher speed tire (Usually "Z" rated or higher) and although they grip better, will wear faster. If you have xDrive, also be aware that these do have specific tire sizes that must be maintained for correct driveline operations. My xDrive runs a staggered 19" in winter and staggered 20" in summer. The front and rear tires must also be inflated at different pressures to keep the tire diameters as close to equal as possible.
Stay with the wheels for a 3-series and avoid any headaches, good luck!
2022 Porsche 911 Cabriolet Agate Grey/Black PDK
2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold)
2014 335i M-Sport Black/Beige MPPK/MPE (Totaled)
2013 328i Sport xDrive Imperial Blue/Grey (Sold)
      05-30-2021, 01:31 AM   #8
30secs
Drives: Bmw 330i
Thanks guys for all the wisdom. Decided to look through FB marketplace for bmw m performance oems that should fit my 330 like a glove. Would you advise to get the 18" or 19"?
I hear opinions for and against both. I live in Florida if that matters.
      05-30-2021, 07:27 AM   #9
2017F30
Drives: 2017 330iX AT
I’m pleased with my set of 18” 441M in terms of ride and performance.
      05-30-2021, 08:11 AM   #10
Billfitz
Billfitz's Avatar
You don't have to worry about potholes, but still with a shorter sidewall and less air capacity 19s have a harsher ride and are noisier than 18s, they don't handle any better, and the tires are more expensive. I suspect that the total weight of the rim plus tire is more with 19s as well, as aluminum weighs more than rubber.
      05-30-2021, 10:26 AM   #11
AspektUSA
Drives: 340i MSport/THP
I would get 18s over 19s personally, as my 442Ms can be a little bumpy.
      06-01-2021, 09:18 AM   #12
hooligan_F39
Space Shuttle Door Gunner
hooligan_F39's Avatar
6547
Drives: 2022 X2 M35i
Depends on what you're used to. My current 430i Sportline with OEM 19s (225/40/19) rides better than my previous X1 M Sport with 18s (225/45/18).
      11-09-2024, 05:37 PM   #13
RCEm
Drives: '17 330 Wagon & '21 X3
Wheel Size 330 ix
I have a 2017 330 ix wagon with 18" wheels. I'm assuming 17" wheels will give me a softer ride?
But I don't want to foul up the speedometer. If I currently have 225 45 R18's what 17" tire would give the same diameter?
      11-09-2024, 10:04 PM   #14
Billfitz
Billfitz's Avatar
Your speedometer is already fouled up, they come from the factory reading 3% low. But you'd size the tire to a higher aspect ratio to maintain the same diameter anyway. As for the diameter find it at Tire Rack, they have specs on every size.
