12-29-2023, 08:24 AM | #1 |
Rep 9
Anyone replace their interior handles with aftermarket?
My F36 interior (Carbon Silver) handles are worn out. BMW OEM is expensive (over $200CAD for a single handle pull for cheap plastic). I was looking at these but not sure about fitment and if pattern would match what's on the dash. Anyone else replace their handles with aftermarket?
https://www.amazon.ca/gp/product/B0C...1EGIUKQW&psc=1 |
01-01-2024, 06:06 PM | #2 |
///M
![]() 362
Rep 1,335
Drives: '18 F80 M3 ZCP, '14 F30 328i
i feel like i've had success on the bay for interior trims. I think a complete set depending on the trim and wear & tear can be between $200 - $400 for all the pieces.
F80 ///M3 '18 S55 / ZCP / 6MT / eventuri CF CAI V2 / CSF TMIC / Mosselman oil tstat / CSF engine oil cooler
F30 328i '14 N20 / 6MT / M-sport conversion / dinan sport kit / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Successful Retrofits: 3AG, 248, 508, 544, 710 |
01-03-2024, 10:34 AM | #3 | |
![]() ![]() ![]() ![]() 417
Rep 695
2003 E39 530i 5-Speed w/ M Spec, Sapphire/Black, M54B30, Active Autowerke Perf Tune
2010 E90 328i XDrive, Space Gray/Saddle Brown, N52B30A 2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
wishbone361.50 |
01-03-2024, 05:36 PM | #5 |
Rep 695
Come to think about it, in my E39, the door handles and dash board trims have wood veneer applied to the aluminum base.
01-05-2024, 06:18 PM | #6 |
![]() ![]() 750
Rep 2,093
I had the rubber part deteriorate on both front doors. Used a snap-in carbon fiber look trim for $20.
https://f30.bimmerpost.com/forums/sh....php?t=1880394 For the entire handle, I would look on Aliexpress, Amazon, or EBay unless you want to OEM BMW gold-layered and diamond-studded ones for $1000. Better wear your white gloves with them.... Here for the E90 and F30: https://www.amazon.com/dp/B09DXW9NH7...hlbWF0aWM&th=1 https://www.amazon.com/dp/B08M5GVXVD...hlbWF0aWM&th=1 https://www.amazon.com/MOTOKU-514172...e%2C172&sr=1-4 https://www.amazon.com/dp/B08M3GS3FC...hlbWF0aWM&th=1
wishbone361.50 |
01-05-2024, 08:27 PM | #7 | |
![]() ![]() ![]() 1101
Rep 331
Drives: 2012 335i Sport
On the flip side, though the f30s don’t seem to crack as much, the aluminum seems to separate from the plastic backing after a while, my main one on the dash is doing that and I need to epoxy it down. Still, the real veneers take the trim to a whole different level than the fake painted or plastic stuff in cheaper cars, not even a close comparison |
wishbone361.50 |
01-06-2024, 07:09 AM | #8 |
![]() ![]() ![]() 268
Rep 449
I went for the carbon & alcantara M-Performance trim set...but the carbon door handles come with dash trim pieces too, which made it £600.
Got a good price on the whole lot from a local dealer for £1000:
wishbone361.50 |
01-06-2024, 11:43 AM | #9 |
Rep 695
mmm-five Love the look of dry Carbon, but not fond of Alcantara personally.
I'm thinking about getting this (custom made to order), but the bright aluminum finish of the narrow strips to be replaced with piano black finish: ![]()
01-08-2024, 03:20 PM | #10 | |
///M
![]() 362
Rep 1,335
For exterior handles which I think OP is asking about is easy trim tool removal on the door handles. I've had both the wood and aluminum on my car and with careful removal and installation there won't be any cracks in the materials. Honestly, a full set is widely available on eBay or in the interior member classifieds on this site.
01-08-2024, 04:20 PM | #11 |
![]() ![]() 750
Rep 2,093
Could also use 3M S120 satin aluminum wrap which is a 98-100% match
https://www.ebay.com/itm/35216811586...mis&media=COPY
01-09-2024, 07:47 PM | #12 |
![]() 1324
Rep 2,084
That would look cool and something different than the usual carbon. It would look good with the bottom silver trim painted black or with the black chrome that the F8x uses. There are places that can do colored carbon with whatever pattern also.
Oksamit78417.00 |
10-19-2024, 09:27 PM | #13 |
Rep 9
If the original ones are actual skin, then why do they wear out from simple grabbing and using the handle Should they not avoid wearing through the carbon fiber look to where you only see silver I am referring to the orginal ones that came with car vs aftermarket. If they were true carbon fibre skin, the should not wear out.
