BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > B58 cutting when wot at high rpm
      11-10-2024, 04:49 PM   #1
Mihkel440i
Drives: BMW F36 440i
Hi, i have a problem with my 440i 2016. The car is cutting at high rmp when wot. I have not felt this before the car runs mhd stg2+ and xhp stg3 for one year now. Yesterday when i first time felt it i read the codes and i got codes from vanos. I erased them and they have not came back but the issue is still there. I will add here picture of fault codes and the 4th gear log. Where should i search the fault? Rail pressure seems to do some odd drops.
https://datazap.me/u/mihkel440/log-1...8?log=0&data=3
      11-11-2024, 07:43 AM   #2
PETED678
Drives: 420D Gran Coupe F36
213601 - Battery drain from what I’ve been reading might be good first to see how many volts it’s producing
130715 - vanos actuator probably needs replacing then reset adaption values, I believe these sit at the rear of the engine
      11-11-2024, 08:12 AM   #3
LA430
Drives: 430i
No need to reset adaptations with vanos replacement on the b48/58.
These are pretty easy to swap. The specialty spanner helps, but isn’t required. There’s plenty on the forums about how to replace these.
