07-20-2018, 01:59 PM | #1 |
Rep 2,557
Can I lock key in the car from dashboard button
Really specific question here, hoping someone has the answer, old threads didnt cover this use case, I have an F32 with comfort access and need to do afterhours pickup from a body shop and i want them to just lock the key in the car.
Can they just stow the key away and use the central locking button on the dashboard? |
07-20-2018, 04:07 PM | #2 | |
Rep 110
07-20-2018, 08:25 PM | #3 | |
Rep 134
Drives: 2017 f32 440i coupe
1. Buy a rf insulation bag (avaliable on amazon) which blocks the key detection. I suspect tin foil also works. 2. Lock the car ouside with one people staying inside the rear trunk 3. The guy inside the car use emergency trunk release to leave the vehicle. Which does not unlcok the car. 4. Put key in the bag and throw into the car. 5. Close the trunk. Last edited by Cyanfall; 07-20-2018 at 08:33 PM.. |
07-20-2018, 09:18 PM | #4 |
Rep 16,082
Have them lock the car, then open just the trunk. Take the battery out of the fob, put the fob and battery in a small plastic bag, put it in the trunk, close the trunk.
07-20-2018, 09:23 PM | #5 |
Rep 2,557
thanks for the replies, I actually figured out a simpler solution....
As noted the car won't lock with the key inside ( they tried) What will work: I told them put the key in and call me when they left the car for the day. I used the app and locked it remotely! I guess the app overrides all. Considering if you can lock it with the app then you can unlock with the app. |
07-21-2018, 11:15 AM | #6 | |
Rep 4,449
Drives: '23 X1 28i xDrive
1. Open the trunk and close all doors. 2. Lock the car with the fob. 3. Put the fob in the RF insulator bag 4. Put the bag in the trunk 5. Close the trunk. |
07-21-2018, 11:17 AM | #7 | |
Rep 4,449
07-21-2018, 11:20 AM | #8 |
Rep 1,048
Here is how you can do it: If you put the key into the trunk and close the lid, the car will know you are an idiot and the lid will pop open. If you immediately close it again, the car assumes you really want to do it and the lid stays closed.
kern4174447.50 |
07-21-2018, 11:25 AM | #9 | ||
Rep 2,557
07-22-2018, 03:26 AM | #11 | |
Rep 552
07-22-2018, 05:47 PM | #12 |
Rep 4,449
07-22-2018, 08:16 PM | #13 | |
Rep 689
See #9. on below link from BMW Connected Drive... 9. When I lock my vehicle, is my anti-theft alarm also activated? The alarm is not activated when the vehicle is locked using the My BMW Remote app. http://content.bmwusa.com/microsite/...remote_faq.pdf Last edited by BMW11; 07-22-2018 at 08:39 PM.. |
