07-12-2018, 09:26 PM | #1805 |
Rep 125
Can someone put up some picture tutorial of how to actually remove the bulbs so I can either put in new bulbs or perhaps new HIDs. I can't for the life of me figure out how to remove the old bulbs from the DEPO lights!!! So frustrated....
07-12-2018, 11:44 PM | #1806 |
Rep 37
cut off line
Here are a couple pics of the cutoff line against the wall. Against the wall it looks decent but when driving I get the jagged "batman symbol"
07-13-2018, 09:17 AM | #1807 |
Rep 2,382
Oh wow... Your cutoff looks more drastic than mine. Mine is just one step down. I wonder if the updated ones all have shields like that
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-14-2018, 04:21 PM | #1808 |
Rep 69
Who’s coded out the turn signal bulbs when the low beams are on? Think I read that someone was able to do it. If someone can link me in the direction to get it done I’d appreciate it!
07-16-2018, 09:03 AM | #1809 |
Rep 2,382
I have. Just go to the Coding\DIY section of the Forums and you'll see a big thread with everything you need, including the cheat sheet with plenty of codes.
07-18-2018, 10:13 AM | #1810 | |
Rep 50
In terms of the coding, its been awhile. I believe I had to code out the cold/warm checks for the left and right low beams. I also think I set code that allows the modules to recognize that I had leds installed vs incandescent. |
07-31-2018, 03:53 AM | #1811 |
Rep 69
So far I’m loving these lights but I hate how the projector beam isn’t a straight line across like most projectors. Not a fan of the “step” pattern. Anyone successfully make these flush all the way across?
07-31-2018, 09:04 AM | #1812 |
Rep 2,382
That's the cutoff shield which is legally required. You could go in and modify it, but it's quite the chore to crack these open anyhow. Best thing to do is have them leveled so light from the opposite headlight bleeds into the area and makes it less noticeable.
07-31-2018, 08:33 PM | #1813 |
Rep 144
Drives: 2023 M3 Competition xDrive
So I’ve had these lights for about a year and a half. Just started getting a warning light a month or so ago for low beam malfunction. I have the retrofit source hid kit installed and all lights are in perfect working condition. I have removed and reinstalled the bulb, but no change in the warning. It also doesn’t come on when the low beams are on, only during the day. Any thought on what is causing the warning and how to fix it?
Speedwell-Industries434.00 |
07-31-2018, 10:59 PM | #1814 | |
e90noob
1588
Rep 1,862
and it's nice to see a crisp "step" in the projector's beams
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
BunkerJ1032.00 |
08-02-2018, 02:26 PM | #1815 |
Rep 69
Washed my car today and noticed that the fitment of my lights aren’t fully flushed and you can see a small gap in between the bumper and the headlights. I know it’s aftermarket so the fit isn’t going to be perfect like OEM so am I just being picky and anal or did the shop do a crap job of installing them?
View post on imgur.com View post on imgur.com |
08-02-2018, 03:04 PM | #1816 | |
e90noob
1588
Rep 1,862
the shop got lazy i installed these with a friend's help in a driveway after the initial install, we realized the headlights were way crooked didn't even cross my mind that it could be so off during install took off the bumper and realigned took several tries but in the end, it looked pretty much perfect
08-02-2018, 03:37 PM | #1817 | |
Rep 69
08-21-2018, 10:09 AM | #1818 |
Rep 129
My beam pattern is the same. It looks good up close to a wall but at distance it still has the "divots" in the beam pattern. I have H7 Phillips Diamond Vision bulbs installed. It's just my driver side headlight beam pattern that is off. Anyone able to solve this?
08-23-2018, 08:01 PM | #1819 |
Rep 270
hey pdav, I bought the same HID set up as you. where did you mount the ballasts?
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
08-23-2018, 08:09 PM | #1820 |
Rep 37
08-26-2018, 06:28 AM | #1821 |
Rep 11
08-26-2018, 09:46 PM | #1822 |
Rep 3
Hello!
I have a few questions...so I have a 2014 F30 328i with halogens...I am upgrading to the USR DEPO Projector headlights. I am now looking to add HID lights to my car like yourself. I looked online and noticed 2 different routes... 1. This route posted in this thread: - Part #: 1 × BL70 - Part #: 2 × B292 (Could you please also tell me if I need the A or B configuration) - Part #: 1 × A90 (Would I need 1 or 2 of these) 2. This route was found when I entered my vehicle information on the Retro Fit Source: - Part #: 2 × BL11, 2 × B292, 1 × H210 Could you please tell me which routes in the recommended route and the pros and cons of each route. Also, since I still have to order the HID parts...but I have my Depos now...would it be smarter to wait and install the Depos when I have the HIDs as well or just do the Depos now and HIDs when they come? Thank you very much! Sorry, I'm such a noob |
08-27-2018, 09:15 AM | #1823 | |
Rep 129
Before you install the headlights make sure the HID bulb position is spot on or you'll run into problems with beam cutoff. Take a look at pdav's post about the beam cutoff. I'm having the same issue but not as drastic. |
08-29-2018, 08:53 AM | #1825 |
Rep 2,382
If you get true 55w and not overpowered 35w, then no, they are not too hot. Been running mine for awhile.
08-29-2018, 12:09 PM | #1826 |
Rep 69
