01-22-2018, 04:17 AM | #1 |
Stupendous Man
60
Rep 354
Installed Depo headlights, Morimoto HID's, fog lights, and clear side reflectors.
Purchased my car as a lease return, it had EVERY other option EXCEPT the lighting package. I had to ditch the horrible halogens, and I really wanted fog lights. Here are the items I purchased for this project.
Headlights https://www.uniquestyleracings.com/i...d=1023&search= Clear reflectors https://www.uniquestyleracings.com/i...product_id=697 Fog lights https://www.uniquestyleracings.com/i...roduct_id=1094 HID parts https://www.theretrofitsource.com/h7...ros-48909.html https://www.theretrofitsource.com/hi...reselect=50553 https://www.theretrofitsource.com/hi...anbus-35w.html LED bulbs for the fog lights https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Pig tails for the fog lights https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I purchased these BMW part numbers from Rock Auto, which was BY FAR the cheapest price. These parts install into the bumper so you can install fog lights. 51118054155 51118054156 51118054163 51118054164 First thing I did was prepping the headlights for installation by retrofitting the H7 halogen bulb in the projector with the Morimoto HID kit. The pictures are pretty self explanatory. The only thing I did a little different was I removed the screws for the bulb mount and installed some very small washers so they had a little more bite on the H7 euro adapters.
2022 BMW x30i Premium
2016 BMW M6 Coupe Comp Pkg. 2003 BMW M5 ~ Twin Turbo LS swap (SOLD) |
01-22-2018, 04:28 AM | #2 |
Stupendous Man
60
Rep 354
Now for the install. There are plenty of headlight install threads and videos, so I won't go in to major detail on that. Installing the fog lights was very simple. Unbolt the old parts inside the bumper and install the new parts. Nothing magical. I made my own wiring harness for the fog lights with the pigtails, a 40amp relay, power and ground, and a turn on signal from the passenger side low beam signal on the headlight connector. So any time the headlights are actually on, the fog lights kick on. Again, nothing fancy.
With the clear reflectors, they are another easy install. Pop out the old ones, clean all of the old 2 sided tape off COMPLETELY, and install the new ones.
scostu1621.00 StoneWall7474.50 |
01-22-2018, 09:55 AM | #5 |
Stupendous Man
60
Rep 354
Thanks, I will snap a picture this evening....
01-22-2018, 10:24 AM | #6 |
¯\_(ツ)_/¯
537
Rep 1,000
Looks awesome
01-23-2018, 03:27 AM | #7 |
Stupendous Man
60
Rep 354
Not at the measured 25 feet, just off my garage as I was leaving this morning....
01-24-2018, 10:01 AM | #9 | |
Stupendous Man
60
Rep 354
I mounted them directly under the headlights and zip tied them to the frame there. There is a small cavity, which easily fit the ballast and error cancel box.
01-24-2018, 12:18 PM | #10 |
Rep 7
01-24-2018, 12:46 PM | #11 |
Stupendous Man
60
Rep 354
Sorry, not really an expert on HID's. Check the bulb to make sure it is properly seated in the housing?
01-25-2018, 04:35 AM | #13 |
Stupendous Man
60
Rep 354
To the horn mount. I checked continuity between the horn mount and the battery ground. Works perfect. Had to snip off the ring terminal that was on it and install a larger one though.
2016 BMW M6 Coupe Comp Pkg. 2003 BMW M5 ~ Twin Turbo LS swap (SOLD) Last edited by timmay77; 01-26-2018 at 03:45 AM.. |
01-26-2018, 03:44 AM | #16 |
Stupendous Man
60
Rep 354
Correct, 5500k.
02-28-2018, 12:34 AM | #18 |
Rep 92
What bulb did you use for the high beam? I'm thinking about copying your set-up with the TRS HID kit. Did TRS give any other details as to why they suggested the hylux ballast/canbus/amp over the H7 elite kit?
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
03-01-2018, 06:42 AM | #19 | |
Stupendous Man
60
Rep 354
Update: 100% completely satisfied with these headlights. They are super bright and work perfect. Zero issues. I work at 4am, so I drive in the dark every morning. The 35w ballasts are plenty bright. I wouldn't change a thing.
They said the Hylux unit is more reliable with European cars when it comes to code canceling.
03-15-2018, 12:53 AM | #20 | |
Rep 92
03-15-2018, 04:25 AM | #21 | |
Stupendous Man
60
Rep 354
03-15-2018, 08:54 AM | #22 | ||
Rep 92
