11-27-2021, 04:57 PM | #45 | |
Rep 2,048
If you buy a 4wd car you have to expect that you will need to be careful with tyres. With the exception of industrial 4wd systems on old school pickups etc that can tow a tank it's always been that way, through Volvos, Subarus, Audis etc etc. Therefore it can hardly come as a surprise when the BMW X-drive system requires the same level of care. |
Armaan714.50 |
11-28-2021, 03:36 AM | #46 |
Rep 1,101
Hankook have been up with the premium brands for at least five years now. I would buy a Hankook S1 Evo over a Bridgestone Potenza any day of the week!
11-28-2021, 04:21 AM | #47 |
Rep 306
Father in law has just bought his first BMW (F30 320D XDrive)
In two years time it will have 4 budget tyres and the cheapest pads he can find at ECP and will then be complaining it has no traction and there is a grinding noise from the front . I’ve told him he needs star marked tyres and as it’s 4WD he needs to be careful about tread front to back as well as getting the exact right size fitted but I know he won’t bother. |
11-28-2021, 04:30 AM | #48 | ||
Rep 4,227
We had a customer in an E39 M5 on BMW Finance. All he would ever do for service was the bare minimum to get the stamp. Tyres, brakes, and all other consumables were replaced by the cheapest he could find elsewhere. He'd also run the rear tyres right down to 1.6mm before replacing them. It got to the point where the techs would refused to drive his car as they felt it was dangerous. |
11-28-2021, 12:26 PM | #49 | |
Rep 542
E46. BMW 320dse Black Sapphire. Lovely motor. Always put Eagle F1's on that.
335d xDrive
TouringPleb4368.50 |
11-28-2021, 01:06 PM | #50 | |
Rep 12,242
65000 miles in 20 months. Those were the days. Mystic Blue with grey leather.... |
11-28-2021, 03:44 PM | #51 |
Rep 1,263
In the 15 years I've had mine it's never run on anything other than Michelin Pilot Sports. Your tyres are your first point of contact to the road, if there's one thing not to skimp on it's them.
11-29-2021, 03:45 PM | #52 |
Rep 311
Cars due back tomorrow. Been looking on black circles and asda tyres for a new set all round. Do I stick with whats on already and go for perilli p zeros or do I choose something different?
asda tyres have p zeros (not sure which knew because they've got a couple for slightly difference price and ratings) for around £800 graded A in the wet and C for fuel consumption. Black circles have got hankook evo s1 which again are graded A in wet and C for fuel for around £750. Or do I go for something like Bridgestone that I used to have on my 3 series? |
11-30-2021, 03:33 AM | #53 |
Rep 2,048
I suspect that the Pirellis and Hankooks will be pretty similar. Not high performance, not cheap crap, just good solid all round tyres. That said, I've never had a Pirelli summer tyre that I've liked in the wet, they've all felt rather glassy when the road is greasy.
It depends which Bridgestone's you're looking at for the size on your car and whether they're run flat. The S001's do last a long time but aren't very good performance tyres. But they do last a decent distance so if that's something you care about then they will outlast the Pirellis and Hankooks. As an example I changed the original S001's on the back of my car earlier this year at 38k miles. The replacement Michelin Pilot Sport 4S's I've put on I doubt will do more than 15k miles, but the performance is night and day. |
11-30-2021, 04:03 PM | #54 |
Rep 311
I can't remember the exact model of the bridgestones but I think they was potenza. I'm swaying towards the hankooks. I've read the reviews and they seem pretty good from x3 owners.
How can I check if they are star marked? Black circles say they are but just want to make sure. I've got the car back now and took it out tonight. I was getting flashed alot. Looking at the headlight beams they seem pretty high. Is it possible that the headlights have been moved during the repair? |
11-30-2021, 05:22 PM | #55 | |
Rep 25,112
My car made front page of Bimmerpost
12-01-2021, 03:38 AM | #56 | |
Rep 2,048
As for tyres, they should have a * on the sidewall next to the size/model info. If they say they're starmarked then they will be. But get them done asap and avoid driving the car if at all possible while you've still got the wrong size of tyres on the front axle. |
12-01-2021, 07:03 AM | #57 |
Rep 8,081
In order to change the differential bearing they will have dropped the suspension wishbones - I suspect they've broken or not reconnected the fragile plastic arm that links to the sensor that adjusts the headlamp aim on the OSF lower wishbone.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-01-2021, 01:52 PM | #58 |
Rep 311
I've turned the screw on both headlights and took them down so I think they are working OK but unsure what height they need to be at.
unfortunately the car is being used with the old tyres still on but its minimal use (dropping kids off at school, nipping shop etc) I want to get the tyres sorted ASAP but want to make sure I get the right ones on and not have this problem again. I rang bmw up earlier to get a quote on the hankooks but she said she couldn't find the rears but could find the fronts (i think it was that way round). Is there any reason why they couldn't find them on the system? she did confirm though the ones she fount are star rated and work with xdrive. I've looked at the sticker on the inside of the door. Am I right in thinking the rear 275/40/19 needs to be xl? |
12-02-2021, 05:57 AM | #59 | |
Rep 1,446
https://www.blackcircles.com/catalog...?tyre=34748571 If so that matches the door sticker, looks like XL is only specified for the winter (M+S) tyres.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
Armaan714.50 |
12-02-2021, 12:18 PM | #60 |
Rep 311
that is the one I'm looking at. Regarding the door sticker you've got top and bottom left and right. Do I need top and bottom from both the same side? At the minute the fronts are top right and rears are bottom left
12-02-2021, 02:07 PM | #61 |
Rep 5,427
Drives: Beige G31 40ix m sport
I find tyrereviews.com quite informative when shopping for tyres, link attached
https://www.google.com/url?q=https:/...Qsr_fpGlvG876q
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
12-05-2021, 02:31 AM | #62 |
Rep 311
been out in the car today and its juddering quite bad at low speeds. Decided to pull the plug on p zeros. At national tyres I can get p zero pz4 for £777 or p zero at kwik fit for £737 (15% offer code). Now whats the difference between p zero and p zero pz4? Both have A rated wet grip and C rated fuel
12-05-2021, 03:59 AM | #63 | |
Rep 1,643
Got for Michelin Pilot Sport 4 non run flat. That's what I've put on my parents X3. They said it transformed it. |
G50954.50 |
12-05-2021, 07:54 AM | #64 | |
Rep 1,446
12-05-2021, 01:11 PM | #65 | |
Rep 2,048
I get the suggestion someone else made about the Michelin PS4. They're great tyres (at least in PS4S form) on my 335d, but are they really required on a 2 litre X3? |
12-05-2021, 01:16 PM | #66 | ||
Rep 1,641
