05-05-2018, 09:43 AM | #1 |
Rep 150
OBD RPM output
Hi guys is it possible to pick up a rpm signal, switched live and ground from the OBD port?
335d X drive, Turbo Dynamics hybrid turbos, Wagner Comp Evo2 IC, Torqbyte methanol injection, custom 3" exhaust. 451.2 bhp and 829nm
05-05-2018, 09:48 AM | #3 |
Rep 150
Which pin outs are which, do you know?
05-05-2018, 09:49 AM | #4 |
Rep 150
This is what I'm trying to get them for but the pin locations don't match up
05-06-2018, 12:55 AM | #6 |
Rep 150
Anyone?
05-06-2018, 07:57 AM | #7 |
Rep 2,302
Pin 9 is the right one.
Maybe you should look at this . Edit: OK, i just see this is actually the same, but from the other side. In any case, the diesel should have a black wire on Pin 9. |
05-12-2018, 05:27 AM | #8 |
Rep 150
For anybody who searches for similar I found a solution. Canm8 RPM module wired in to the FEM can bus to give RPM readings
08-09-2018, 05:45 AM | #9 |
Rep 2,357
08-17-2018, 08:29 AM | #10 |
Rep 150
That's exactly what I am using. I used a canm8 rpm unit perfect
08-17-2018, 08:30 AM | #11 |
Rep 150
Some of my install
08-17-2018, 09:05 AM | #12 |
Rep 2,357
OBD RPM output
Wau. Nice install! Clean! Wish there was a stealth tank for the 1-series. Rpm signal is on OBD pin9 for my F-series so I am using that.
(A Dane in China) |
08-18-2018, 07:41 AM | #13 |
Rep 150
You will not get an rpm feed from there mate that's what I tried first
08-19-2018, 12:07 AM | #14 |
Rep 2,357
But I do... Just set 3 pulses/rev and it reads correct. I have a problem with the MAP signal though, I cannot get it to read right. Its all over the place. Using TorquePro I see ~3-4psi when revving in neutral but I cannot get it to read that. Looking at the log I am thinking that there is some interference on the signal???
(A Dane in China) Last edited by harkes; 08-19-2018 at 12:17 AM.. |
08-19-2018, 01:58 AM | #15 |
Rep 150
Sorry is yours petrol? That would be why as mines diesel
I used a stand-alone map sensor and took a feed from the inlet elbow
08-19-2018, 04:46 AM | #16 |
Rep 2,357
Ahhhhh ok. Yes mine is petrol. Rather strange that makes a difference on the OBD output. OK, I'll contact support regarding the MAP
(A Dane in China) |
