04-09-2018, 08:39 PM | #1 |
Rep 136
Bimmercode and screen mirroring
I have read on other forums that screen mirroring can be done with Esys has anyone been able to do it with bimmercode yet?
04-15-2018, 10:44 AM | #4 |
Rep 136
I haven't used the expert mode as of yet because everything I wanted was readily available. That being said I did find some info on it but don't know if it will work but I will share it to see if anyone else knows what to do with it.
Enable WiFi Hot-Spot 3000ENT_MC_WLAN_STREAM_DMP_COVERARTset to: aktiv 3000ENT_MC_WLAN_STREAM_DMP_VIDEOset to: aktiv 3000ENT_MC_WLAN_STREAM_DMPset to: aktiv 3003WLAN_STATUSset to: aktiv 3003WLAN_MODUSset to: ap 3003WLAN_SIGNAL_STRENGTHset to: outdoor 3003WLAN_CHANNELset to: channel_1 -14 |
11-14-2018, 04:47 AM | #6 | |
Rep 92
88tuning.id38.50 |
06-10-2019, 03:32 PM | #7 | |
Rep 8
I tried with my F30 LCI (Japan imported) and can confirm you dont need to adjust WLAN_SIGNAL_STRENGTH set to: outdoor & WLAN_CHANNEL set to: channel_1 -14. I actually these changes gave me errors in the screen, worked perfectly when removed.
07-22-2020, 03:51 AM | #8 |
MICATECH
Rep 7
What am I doing wrong???
Have spent a fair bit of time trying to get screen mirroring working on a 2017 F30 330i. Its a NBT EVO id5 version.
I do not see "screen mirroring" appear at all anywhere. These are the settings I have applied. Made the following changes:- 3000ENT_MC_WLAN_STREAM_DMP_COVERART set to: aktiv 3000ENT_MC_WLAN_STREAM_DMP_VIDEO set to: aktiv 3000ENT_MC_WLAN_STREAM_DMP set to: aktiv 3003WLAN_STATUS set to: aktiv 3003WLAN_AP set to: aktiv 3003WLAN_SIGNAL_STRENGTH set to: outdoor 3003WLAN_CHANNEL set to: channel 14 WLAN_WIFI_DIRECT enable Is there something wrong or missing? Any help appreciated. |
07-28-2020, 09:54 PM | #9 | |
MICATECH
Rep 7
I finally gave up trying with Bimmercode as all the above changes did not work on my 2017 F30 330i. I decided to purchase "screen mirroring" from a 3rd party and it came via email and I placed it on a USB stick and it worked perfectly. I immediately wanted to know what changes had been made that made it work so I trued reading the Headunit via Bimmercode but now Bimmercode "cant read Headunit" ecu. All other ECU's seem fine. Unhappy with this I did a restore of the headunit via Bimmercode and it restore OK BUT I still cannot read the ecu via Bimmercode. Why??? I restore with the very first backup. Anyhone know how I can fix ecu so Bimmercode can read it again? |
07-28-2020, 10:36 PM | #10 | |
Rep 1,789
07-29-2020, 10:08 AM | #11 | ||
Rep 12
11-25-2020, 03:33 PM | #12 | |
Rep 2
I also enabled the options on https://f30.bimmerpost.com/forums/sh...03&postcount=2 I think one of these were not on mine, so I skipped it. Thanks! 2018 320i xDrive EDIT 6/2021 - 2019 430i xDrive, same steps Last edited by akastixx; 06-23-2021 at 10:32 PM.. Reason: New car |
12-31-2020, 06:43 AM | #13 |
Rep 121
Sorry to resurect old post i bought f34 UK 2016 done all setting but for some reason Vehicle WiFi tick box is not selectable for some reason. Any idea why?
The 3003WLAN_MODUSset to: ap ( i cant see MODUS in 3003) can that be why im having issue as it was not changed. |
01-02-2021, 05:43 AM | #14 | |
Rep 121
03-22-2022, 03:28 PM | #16 |
Rep 15
I know this an old post but I was able to get screen mirroring enabled! I now can have Waze on my screen from my android phone
Is it possible to keep my audio connected with bluetooth? I want to be able to change the volume and track with the steering wheel mounted controls |
05-03-2022, 04:06 AM | #18 |
Rep 9
After enabling Screen Mirroring on my F36 realised that my Motorola Android phone does not support Miracast since Google dropped it in 2016 or thereabouts. Tried with a Samsung tablet and it all works as expected, but it's only slightly more than half of the iDrive screen. So, the lesson is, this Screen Mirroring only works if your device supports Miracast standard and does not work if it supports Chromecast!
07-28-2023, 05:36 AM | #19 |
Rep 6
Hi guys,
I activated with expert mode, mirroring, video in motion, wlan, miracast in headunit 3000, 3001, 3002 and 3003 groups. I see now on my iDrive7 menu "screen mirroring" I see in iDrive7 display says : Miracast connect your mobile with bmw59864, I open on my Samsung "screen view" it founds screen mirroring bmw59864, but I can't get last request on iDrive7 to connect with question "would you like to connect yes/no". So everything works good until last step when I have to connect Samsung mobile with Miracast screen mirroring in iDrive7 to make screen mirroring connected. Does anyone of you had similar issue? It works perfect with my old BMW car and iDrive6, but with iDrive7, probably I forgot to activate some parameter with bimmercode and don't know which one in Headunit option |
