03-02-2020, 06:46 PM | #441 | |
Rep 1
Does the dealer charge to inspect a suspected timing chain noise? Im also coming up on 7yrs 7k miles. No slack in the chain but the morning whine after cold start is noticeable.
Thanks. Quote:
03-02-2020, 07:32 PM | #442 | ||
Yiolli
26
Rep 119
03-02-2020, 08:08 PM | #443 | ||
Rep 5,458
Drives: F30
I suspect they will want an hours labor... if they find anything wrong covered under warranty, that should be waived. Might be a good idea to book an oil change or other minor service and ask to check while they have it on the rack. |
03-02-2020, 08:22 PM | #444 | |
Rep 661
Drives: 2014-320Xi / 2017-330Xi
They will have to write all of that in the Service Order. You will probably pay for that diagnose. In case BMW doesn't want to repair, and you eventually have problems in the near future, you created records that maybe helpful when discussing with BMW and your dealers. |
03-02-2020, 11:38 PM | #446 | |
Rep 4,456
Some people will never experience this issue and others have blown motors from it. |
03-03-2020, 04:26 PM | #447 |
Rep 1,760
I've not seen this happen on late build 2015s or 2016 cars. Wonder if it's an age thing or if the updated components (1/2015) really did the trick.
2016 428ix, r, 2018 430iC, 2018 330it
03-03-2020, 09:31 PM | #448 |
Rep 7
That sucks man,
I work in a bmw dealer and most of the early n20's are getting goodwilled. This means bmw is supplying the engine and the customer pays 3,000 for labor to install it. The early n20s are trash and hopefully they do something about it sooner or later and you get compensated |
03-04-2020, 01:21 AM | #449 | |
I can haz cheezburger?
6808
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
It seems all we can do is put the finger in the dyke and pray. |
03-04-2020, 06:30 AM | #450 | |
Rep 2,674
03-04-2020, 06:54 AM | #451 | |
Rep 1,760
03-04-2020, 11:16 AM | #452 |
Rep 145
There is a class action in Canada as well, not too sure if it is the same case as the US.
https://www.newswire.ca/news-release...653043233.html |
obert1781.00 |
03-04-2020, 10:09 PM | #454 | |
Rep 367
https://decoder.bvzine.com/ |
Yiolli25.50 |
03-04-2020, 10:27 PM | #455 |
Rep 147
Respectfully, from where, precisely, are u drawing this info?? I know many have indicated that there was a part # change in early 2015, but I have not seen the change narrowed to March 2015? Please share....? Thanks!
03-05-2020, 06:52 AM | #457 | |
Rep 1,760
03-05-2020, 10:57 AM | #458 |
Rep 147
03-05-2020, 12:34 PM | #459 |
Rep 19
03-05-2020, 04:54 PM | #460 | |
Rep 7
the early n63's and n20's are garbage and are def ticking timebombs. however the later n20's are great and are almost bulletproof besides for like common stuff like ofhg and other common stuff. |
floridaorange10257.00 |
03-05-2020, 06:19 PM | #462 |
Rep 499
Here's the link to the document for the alleged n20 models that have the bad timing chain. https://bmwtechnician.com/2019/01/31...ain-7-70-list/
In regards to when your car was manufactured, just look in the driver's door jam -- the date is listed there. No need for an online decoder. |
