12-28-2020, 09:15 PM | #1 |
Rep 53
Drives: F30 BMW 3-Series Sedan
F30 H&R Sport Springs with M Sport Bumper, issues?
Hello guys, this is my first post so please forgive me if this was posted in the wrong section. I am currently in the process of upgrading my F30 328i sedan and just need some opinions from those who have done this already. I’ve already fitted it with some staggered 18” M359’s, 235/45/18 up front and 265/40/18 in the rear. They are 18x8.5 and 18x9.5 respectively with a 35 offset for the fronts and 33 offset in the rear. My plan is to purchase some H&R sport springs and the M sport front bumper. The car does not have sport suspension and it is on stock shocks/struts. My question is, for those of you with similar setups, were you guys happy with the amount of lowering provided by these springs, and did you have any issues rubbing or scraping the front bumper on curbs or parking spot blocks etc? Additionally, will I need wheel spacers even on wheels with <35 offset? I know this topic has been likely beat to death by now, but any input is greatly appreciated! Pics would also help! Thanks.
12-29-2020, 11:15 AM | #2 |
Rep 576
I think offset wise you will be fine and happy with the fitment as those offsets and widths are pretty close to the sweet spot for these cars. As far as scraping goes, im on the eibach pro kit with the M sport bumper and dont scrape anywhere but Ive heard of people having slight scraping issues on the HR sports. Maybe as long as you dont install a lip and drive carefully in/out of parking lots and driveways you should be fine!
12-29-2020, 12:27 PM | #3 |
Rep 10,256
Mixing stock (soft) shocks with aftermarket lowering springs may result in an undesirable suspension behavior, where soft shocks can exacerbate spring oscillations leading to a bouncy ride.
Good thread to read: https://f30.bimmerpost.com/forums/sh....php?t=1767895 |
12-29-2020, 09:23 PM | #4 | |
Rep 53
12-29-2020, 09:24 PM | #5 | |
Rep 53
01-01-2021, 05:24 PM | #6 | ||
Rep 576
01-02-2021, 08:55 AM | #7 | ||
Rep 5,392
Best choices are Bilstein B8 or Koni Yellow. Many people find B8's more stiff than they'd prefer. Koni Yellow are adjustable for comfort so you have about 10 settings to dial-in exactly how you want your car to ride. Bilstein's are set at the factory so no adjustments. Good luck! |
cfm56d7b5886.00 |
01-04-2021, 07:24 PM | #8 | |
Rep 53
01-04-2021, 08:40 PM | #9 | |
Rep 10,256
If you are still considering B14 coilovers, I suggest to add KW Street Comfort coilovers to the list: excellent comfort oriented coilovers - with adjustable rebound controls. Compression is not adjustable. https://www.kwsuspensions.com/produc...street_comfort |
01-05-2021, 11:10 AM | #10 | ||
Rep 5,392
If you are considering coilovers, like the Bilstein B14's that you mentioned, then that is a different question. Guys often choose coilovers because they want an adjustable amount of drop. The coilover market has more decisions/issues such as quality of materials and construction, the range of minimum/maximum drop, whether it is only drop adjustable or or the dampers themselves are ride adjustable. If you look at it in terms of price, the Koni Yellow/H&R spring combination are high quality components at a certain price. The next higher priced coilover is often a step downward in quality of materials and ride, the only gain is some ride height adjustment. Often you need to spend much more on higher quality coilovers to get back up to that Koni Yellow/H&R quality level of materials and ride. Bilstein B14's are a coilover that is made with high quality materials. It height adjustable but there is no damper adjustability. So the stiffness will be whatever was fixed at the factory. So the B14's have the same knock on them as the B8's vs the Koni Yellows, which do have comfort adjustments. The B14's are adjustable from a minimum 30mm drop to a maximum 50mm drop. So that's about 1.2" to 1.9". I haven't checked the exact fixed drop of the H&R's for your car, guessing somewhere around 1.5" to 1.8". So the practical trade off might be that to go with B14s you may gain the ability to adjust height by a few tenths of an inch, but you would lose the damper adjustability of the Koni Yellows. Just giving you a heads up because many guys love the stiffness of Bilstein's but there are also guys who find them too stiff. Hope this helps! |
Tommi_Mav65.50 |
01-06-2021, 02:17 AM | #11 | |
Rep 53
johnung4528.00 |
02-01-2021, 09:23 PM | #12 |
Rep 53
Ended up going with the Bilstein B14s. Car will be going into the shop tomorrow for a full M sport package upgrade and the B14s! Will update with pics once it’s all done! Thanks for all the help guys!
03-16-2021, 01:55 PM | #13 |
Rep 19
Did you end up getting all the work done? Pics please!!! I'm seriously considering the B14's as well!
03-18-2021, 11:02 AM | #14 |
Noob
70
Rep 254
yea bro where the pics, you cant leave us hanging curious how much they quoted you for an Msport upgrade all around with paint and everything? (just ball park)
FBO, MHD Stage 2+ E20, Xhp Stage 3
09-22-2021, 03:48 PM | #15 |
Rep 53
A bit late, I don’t know how I missed this, but here are some pics!
