09-25-2021, 12:16 PM | #1 |
Rep 80
Switched from BM3 Transmission tune to Stage 2 xHP Transmission tune
09-25-2021, 01:07 PM | #2 |
Rep 7,591
The change is trans tune isnt really going to affect your log at all since both should remove torque limits. Timing is good in the log but WGDC looks a bit high especially since you are a bit below boost target.
09-25-2021, 01:50 PM | #3 |
Rep 80
How do I fix this and is it serious? Also could it be that I'm using a Vargas Stage 1 turbo?
09-26-2021, 11:55 PM | #4 |
Rep 7,591
You're fine. Most people dont rev as high as you are, but it might be worth confirming no boost leaks. A bigger turbo should make it easier to reach boost target (i.e., lower WGDC)
