BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
      01-09-2019, 03:48 PM   #221
atzebmw
Drives: Tesla Model 3
Originally Posted by Davef30hull View Post
Mine hasn't worked I'm absolutely gutted. I should have chosen the correct parts for my 2013 f30. I just don't understand why some have success and some don't with exactly the same part numbers. I just cannot inject a cafd into the rdc module. I'd even offer a reward to anyone who can help me get mine working.
Shawn also confirms its not possible.
As you can see here the RDC module HAS a CAFD.
I send you the contact details of an expert by PM.
      01-09-2019, 03:54 PM   #222
atzebmw
Originally Posted by Drimacus View Post
Does it neeed flash?
No.
I only used the trick by connecting as F10, injecting CAFD, connecting again as F30 and then coding.
This worked for me.
      02-09-2019, 05:50 AM   #223
Drimacus
Drives: 2013 F31 320d Luxury
Hi, i connected RDC Antenna, but my car does not reconize it.
May i need to code something before?
      02-09-2019, 08:18 AM   #224
atzebmw
No, the RDC ecu should be visible before coding.
      02-09-2019, 02:22 PM   #225
Drimacus
Now it works,
No cafd injectable, but it works anyway!
      02-19-2019, 07:59 AM   #226
Leut
Netherlands
Drives: MY21 G20 330e
I read that the RDC ECU got integrated into the ABS pump module with reference DSC MK100, which therefore makes such a separate RDC ECU obsolete and that as per 03/2014 TPMS is a standard option for the F3x series.
So I am now curious, what are the requirements of hardware for the TPMS after 03/2014? Is that only the DSC MK100 ABS pump module and four sensors (with metal valves) or is more hardware used?
My car is equipped with such a DSC MK100 module and all my tires have got the latest version of TPMS sensors. Therefore, theoretically, I guess TPMS should be able to work, if my assumptions are right ofcourse.
      02-21-2019, 01:00 PM   #227
SunzOut
Drives: '18 340i and '00 M Coupe
I did this on a 2018 Canadian car that did not have the S2VBA option (it had S2VCA). I removed 2VC and added 2VB and then did a set of changes I picked from a thread to disable TPMS.
No other hardware required, other than the TPMS sensors in the wheels
      03-22-2019, 09:21 PM   #228
MetalMic
Malaysia
Drives: F30 LCI
Originally Posted by THE_AVIATOR View Post
atzebmw It worked. Just the Sensors, part # 36106856209
Did the coding, drove for 2Km and it's working
Greetings there, sorry if I'm digging up a very old post here :')
I have a 2015 F30 LCI and I plan to retrofit the TPMS valve but before I make the plunge I have a question regarding coding.
Since I only have Bimmercode app and it does not support DSC coding and I cannot see any RDC code in the FEM and ICMQL menu in Bimmercode.
I'd like to know if manual coding of FEM, ICMQL and DSC to activate RDC is necessary even though the feature is now integrated into the Mk100 module?
Many thanks for any feedbacks.
      03-23-2019, 04:22 AM   #229
atzebmw
Yes, it‘s absolutely necessary.
      03-23-2019, 04:28 AM   #230
Leut
Netherlands
You'll also need to code a few items in the HU_NBT and KOMBI section.
      03-23-2019, 04:49 AM   #231
MetalMic
Malaysia
Drives: F30 LCI
Oh bummer, I’ll have to get an Enet and download E-says then.
Thanks a lot atzebmw mate, Appreciate it!
      03-23-2019, 04:51 AM   #232
MetalMic
Malaysia
Drives: F30 LCI
Thanks for the advice, yes indeed and I can see those codes with BimmerCode
But not the others
      04-28-2019, 04:04 AM   #233
dncomputech
Drives: F10 520i 2016
Hi
I equipped the 2015 RDC F10 LCI with ECU RDC and 4 sensors. Successful work when the vehicle moves 30km / h temperature and pressure display accuracy. But when the car is turned off and the car is turned on again, all the temperature and pressure are lost and all the vehicles have no error and it only shows wheelchair test about 30km / h
Can I ask if I have completed it correctly, or am I wrong or missing?
The cooding of me, manual tuning is not VO code
1. / HU-H >> 3001 EXBOX, 96
RPA = nicht_aktiv
REIFENUEBERWACHUNG_RDC_RPA >> rdc
RDC >>> aktiv
RDC_SAFETY >>> aktiv
RDC_DRUCK_TEMP >>> druck_und_temperatur
2. / ICMQL
IcmKod_B_S2VBA = verbaut
3. / KOMBI
ST_TYR_RDC_ALIVE = aktiv
ST_TYR_RDC_TIMEOUT = aktiv
KOMBI DSC_MIT_RPA = ohne_RPA
https://drive.google.com/file/d/1mg-...ew?usp=sharing
https://drive.google.com/file/d/1Ll0...ew?usp=sharing
      04-28-2019, 04:40 AM   #234
atzebmw
No, that's all normal.
The tyre pressure and temperature is only displayed when the car is driving or has already been driven a bit.
But if you have just switched on the ignition, nothing is displayed.
      04-28-2019, 07:19 AM   #235
dncomputech
Thank you very much
      05-04-2019, 08:27 PM   #236
flyknit
Drives: BMW 440i
Hi
RPA = nicht_aktiv
RDC >>> aktiv
2. / ICMQL
3. / KOMBI
Hi, so you didn’t perform any VO coding but just FDL coding? Do you do this via esys or can be done via bimmercode (expert mode)
      05-11-2019, 10:43 AM   #237
dncomputech
I confirm is only FDL no VO code Except ECU RDC retroft.
Because when attaching RDC, it brings Vin of another vehicle (I buy and unload the car on ebay). So I have to Select ECU RDC >> Detect CAF for SWE >> select the latest one >> OK >> Code work successfully. I had CAFD for RDC for the vin of my car.
I also did not add 2VB to FA (F10 2015) cars. But I have an FA with 2VB of my own car and I activate it if I want to ECU RDC
Now it works well on my car
      05-12-2019, 09:30 AM   #238
Drimacus
mine work good too, but doesn't need cafd.
      05-30-2019, 07:21 PM   #239
Siki78
Siki78's Avatar
136
Drives: F30,G30
6881891 sensor?
Someone knows can I use this sensor and if yes with wich ecu? Can I use ecu
6876227?
Thanks in advance
      07-22-2019, 07:50 AM   #240
neil0779
Drives: BMW X3 30d
2013 BMW  [0.00]
Hi, do you know that part number for the wire is for the TPMS retrofit?
Thanks
      07-22-2019, 10:11 AM   #241
atzebmw
Thanks
There is no wire for the TPMS retrofit.
You have to build it yourself.
      08-19-2019, 10:20 AM   #242
Amirmostafa24
Drives: Bmw 328i 2015
So, now that my account is unlocked, I can help you finally.
I retrofitted the tpms on my F30 from 02/2014 successfully.
I tried many things.
But on the end only one combination worked.
I installed the control unit 6876227 together with the sensors 6856227.
The connection of the cables and the codings are the same for me.
In my attempts I also tried the sensors 6855539, but it also didn't work.
These sensors are for cars after 03/2014.
I hope this is helpful.
hey i have a 2015 328i and i put new wheels and it's showing the tires are low when they are not so i just wanna code it out with bimmercode.
