BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Do I need to code the TRSVC Module (Reverse camera)
      06-01-2019, 04:45 PM   #23
atzebmw
Drives: Tesla Model 3
Please check the fuse 154 in the Fuse box in the trunk.
https://www.newtis.info/tisv2/a/de/f...d-lim/KYx5a1VB
      06-01-2019, 04:54 PM   #24
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
Just checked and the fuse is fine. It's strange that it disappeared from ista and everywhere like if I deleted the module
      06-01-2019, 05:00 PM   #25
F30RiK
Also if I put my car in reverse now it's like if my car never had the reverse camera option.
      06-01-2019, 05:10 PM   #26
atzebmw
When you read the VO in the upper left window and you click trough the elements up to Salapa-Element is there the "3AG" like in my picture?
      06-01-2019, 05:59 PM   #27
F30RiK
Yes it's there
      06-02-2019, 06:05 AM   #28
VicSPB
Drives: BMW 320dX
When you press Read(ECU) button, you should see TRSVC Ecu. If isn't, you have problem with ECU, power, or CAN-Bus
      06-02-2019, 10:02 AM   #29
F30RiK
Ok thanks, I'll try later today to see if I have power with a multimeter and a good ground. Someone can provide the pinout ?
      06-02-2019, 11:11 AM   #30
atzebmw
Here the wiring diagram
https://www.newtis.info/tisv2/a/en/f...lim/1VnZ8JNgY2
and here the pinout
https://www.newtis.info/tisv2/a/en/f...lim/1VnYSh1Fpf
      06-02-2019, 01:08 PM   #31
F30RiK
Thank you
      06-02-2019, 08:29 PM   #32
F30RiK
Update, my friend with the exact same car as me came in, we swapped out both module . He's module is working on my car perfectly (except it give an error on the cluster) but the camera work.
On his car with my module it doesn't work..
Conclusion : the module I received from eBay is not good.
      06-20-2019, 11:23 AM   #33
F30RiK
Update : received the new replacement module.
It's working now and is recognized in the ECU's list.
It's also working when I put the car in reverse but the image is upside down.
I also have some fault in ista : trsvc no current coding , control unit is not coded, K-cAn line fault.
Can someone help me code it via esys. I don't want to make any mistake lol
      06-20-2019, 11:36 AM   #34
F30RiK
Ok it's working.
Detect caf
Assign last cafd
Code
Working
Big Thanks to atzebmw
      06-20-2019, 11:42 AM   #35
atzebmw
Ok it's working.
Detect caf
Assign last cafd
Code
Working
No problem.
      07-03-2019, 03:54 PM   #36
Abi
Drives: BMW 430d M-Sport
2015 BMW 318d  [0.00]
Sorry for off topic but:
Is there any way to code TRSVC module to use it only for rear camera without any errors. It all works but it is annoying when I see all the errors in ista for side camera, top camera etc.
      04-21-2020, 04:05 PM   #37
F30RiK
Up, my new (used module from eBay) broke again ., Is that possible ? Lasted 8 months. Same behavior , black screen, random issue with the car when the module is connected (cooling fan full speed intermittent , super slow almost not responsible iDrive, airbag faut pops up). When I read the modules with ista, 3-4 of them are red and not responding. As soon as I disconnect the reverse camera module everything is back to normal.
I don't understand
      04-22-2020, 03:36 PM   #38
Ace320
Ace320's Avatar
Italy
128
Drives: F31 M Sport, 6MT, Alpine White
I don't understand
Myb you are bad luck, If the module was working fine for 8 months and all of the sudden starts acting weird, to me it's faulty module.
5 months ago I have retrofitted backup camera (also with help of atzebmw) with 360 camera module and it's working like a dream.
Tho, I got my retrofit kit locally, not from eBay.
Most of this stuff sold on eBay is coming from stolen cars, and who knows how many times it's been dropped and damaged inside and it works for short time and it dies.
      05-12-2020, 01:13 PM   #39
F30RiK
Thanks, I just received my new used module from a 2015 435i and it's back working (coded it in e-sys)
      05-12-2020, 03:08 PM   #40
F30RiK
ok it stopped working literally 5 minutes after it worked. It's not detected anymore by Ista and esys.
So I tried to put back my original module, it worked right away.. I also tried the second module I bought 8 months ago and it worked also.
I installed the original one back, and everything is working perfectly now?
I think there's something wrong with the wiring harness maybe?
It's working but I have a K-Can fault in ista with the TRSVC module.
I don't understand what's happening lol.
      03-06-2024, 08:40 PM   #41
gameson
Drives: 2015 BMW 320i N20
My rear camera is acting weird. Sometime it works. Sometime it doesn’t work. When it doesn’t work, it would get black screen with camera fail on it. Sometime on the 6wb, it said rear camera failure, but the camera works.
What would be the issue? The camera, the module, or the cable connecting camera and module?
Also if i buy a new unit of module or camera and swap it, do i need to code it? Same unit same part number.
Thanks.
      03-06-2024, 11:41 PM   #42
BradNC
Drives: F36 440i xDrive
Thanks.
I have rear, side, and surround cameras and mine weren't working intermittently (on an LCI). I tried everything, chasing errors, diagnostics, VO coding all related modules, and nothing worked. Trying to display test images resulted in ERROR ECU CONDITIONS NOT CORRECT.
I was on an i-Level from early 2019 and saw other people fixed similar problems back then by going to the dealer for a software update. I updated to the most recent i-Level using ISTA+ and it seems to have fixed my problem.
There's some THSA bulletins about BMW cameras not working and software updates being the fix.
      03-07-2024, 02:53 AM   #43
gameson
What do you mean by software update? I have hidden features, and also bm3 stage 2. If i update at dealer, would it update everything and my hidden features gone along with bm3 and xhp?
This is how it looks like. It has a rear view camera failure on the dash but the camera is working.
When it doesn’t work, it will have black screen with camera failed message on it. I checked all cable connection and everything seems connect properly.
      03-07-2024, 03:28 AM   #44
BradNC
Look into getting a recent version of ISTA and use that to diagnose your car. In there it will also tell you the i-Level of your car. The first half of 2019 is when I was seeing people post about camera problems.
