BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Easy Entry Bimmercode
      07-15-2019, 02:44 AM   #1
DarkF30
DarkF30's Avatar
54
Drives: F30 328i
So i went to 3000 SM_Global -> EINAUSSTIEHSHILE
and I dont see the option for Modus_FA_SLV. Does this mean I cannot add the feature?
      07-15-2019, 03:55 AM   #2
cjn
Drives: 2021 F40 M135iX
Have a read of my post here, it may help you:
https://f30.bimmerpost.com/forums/sh...4&postcount=23
EDIT:
Possibly not, as I just realised that you couldn't find the basic setting. The positioning adjustments are a secondary issue.
Were you actually looking for the correct item name: EINAUSSTIEGSHILFE ?
Is the Modus_FA option available? If so, give that a try.
      07-15-2019, 10:11 AM   #3
Somebloke
From memory, the various options moved from 3012 to 3015 under Expert Mode in the Seat Module Driver ECU option.
      07-15-2019, 10:32 AM   #4
cjn
Yes I described this issue in my linked post. However, this doesn't explain why the OP apparently can't find the desired option for the basic item under 3000.
      07-15-2019, 01:35 PM   #5
DarkF30
DarkF30's Avatar
54
Drives: F30 328i
EDIT:
Found this on another post."The option of Modus_FA_SLV is available only for the firmware using the SM ECU CAFD version of 12 and above i.e. 000000B5_012_xxx_xxx. I found that SM ECU module part number was changed on 7/2013. So flashing my old ECU with new firmware is not possible ;-( In other words, the Easy Entry feature is not possible by flashing/coding for F30 produced before 7/2013"
dang was really looking forward to doin this with bimmercode
      03-13-2024, 08:13 PM   #6
Charlesfeedomgundam
New Zealand
Drives: Bmw f30 330d
Hi man, I just found the info you posted it's very helpful. Is there any chance I can know the part number of that ecu so I can install it in my 06/13 f30 m sport leather with headed function and lumber support seat to get the easy entry function? If you can truly appreciate
