03-24-2023, 10:46 PM | #1 |
Rep 7,429
How to code the Steering (EPS) on an F series BMW
Credit: speedsnice https://f87.bimmerpost.com/forums/sh...81&postcount=3 In this thread I will be teaching you how to code the steering rack (otherwise known as the EPS) as this process should be almost the same on any F series BMW. But the instructions will be specific to my m2 so I cannot guarantee that they will work on other cars, so you can search on the forum of what modules you may need to code to get the desired results if my instructions are not the same for your car. Again I will be talking about coding in context of my 2017 BMW M2, on ISTEP level F020-19-07-539, so what I may be able to do might be different to what you will be able to do as there is a difference in vehicle and software version. So before we begin you may ask why would I want to code my steering rack? The reason why is because BMW programs these steering racks differently from car to car, and this different programming has significantly different behaviors. Some programming/codings make the steering wheel super light for comfort, this is typically present on non M BMW’s and is typically geared for the luxury feel - meaning you sacrifice alot of steering feel and precision. Some steering feels are extremely heavy to the point where you have to fight the wheel and lose precision, like the stock F87 steering coding. Some steering feels are absolutely perfect in my opinion, and that is the F87cs coding. So having the ability to select different “codings” will allow you to better tailor the car to your desired steering feel, instead of being forced to deal with what BMW gave you from the factory. Now you may ask how is this possible? Well the answer to that question is because the M2, M2C, M2CS, M3, M3CS, M4, M4CS, and M4 GTS (the non M models also share their own steering racks, and the SUV’s will share their own rack as well) all share the same electronic power steering rack: https://www.realoem.com/bmw/enUS/par...&q=32107852660. The only difference is the programming or coding that is used to operate the steering rack currently selected in the EPS’s ecu, otherwise they are all the same. The good thing about this is BMW does not have bespoke software for each car. Instead they have a bunch of “codings/programmings” in the EPS’s ecu that are toggled to a specific car. So essentially you will already have all the different codings available, all you have to do is set which one you want. The only exception to this is if your car’s current software level otherwise known as ISTEP has those codings available, aka if your car’s software is too old chances are you won’t have the GTS or CS settings. Of course the model of your car will affect this too. The last question you may have is what do you use to code these things? Well my answer to that is either BMW’s special software called ESYS (which I will not be explaining in this thread), or Protool which is an android app that allows you to code everything ESYS can. Here is a link to my review on protool explaining everything a bit more in depth, and why you really should buy this app over the alternatives: https://f30.bimmerpost.com/forums/sh...8#post29968598 Disclaimer: Damage/Injury Disclaimer: Any technical advice, coding advice, installation instruction, or product installation demonstrated in my reviews is to be done at your own risk. I will not be responsible for personal injuries, injuries to others or any living being, or any damage to your car, or any property damage. Coding these advanced features like the GHAS (differential), power steering (EPS), and DSC (traction control) can be very dangerous as it causes your car to behave much differently than before. So proceed with caution. Again I will not be responsible for any outcome that occurs due to you (the reader) using my instructions to code a car. Monetary disclaimer: I do not make commission, or profits or any kind of monetary gain from the sale of this App (Protool). Image Credits: Images and videos used in this review are all property of their rightful owners as credited below each image, I am just using them for the purpose of this review but if you (the owner of the image) would like them removed please let me know via pm. Otherwise thanks to the respective image owners (I made sure to credit your online name and link where I found the photo) of the photos, without you this review would be so much more bland. Before we start talking more about coding, I would like to give some tips on how to code your car safely: Make back ups before you code, this way if something goes wrong you are able to revert your car back to factory settings. Make sure you know exactly what you are doing before you code. This means doing plenty of research on what coding you will be doing, what the changes itself does, what ecus need to be coded and how to make the changes, and of course if the coding you want to do is available for your car. Make sure you have an appropriate (and good quality) battery charger to keep your car powered while you code, because if your battery drops below a certain voltage while coding your car will shut off and this can leave the car bricked. For some coding you can leave the engine running while coding, but do not drive while coding. Use quality cables/wireless adapters - cheapo adapters/cables are slow and can fail part way through the flashing process. In the past I have purchased cheap enet cables from aliexpress, and while on the outside they look clean and good quality. When I opened the obd2 shell I saw how terribly put together they were, the wires were stripped extremely poorly and the cables had patches of exposed copper all over the place. This could lead to a short if the adjacent exposed wires touched, and that would be bad news for the car. Read the protool’s user guide completely and thoroughly before you begin, failure to do so can result in damage to your car. How to code the EPS/Steering rack: Step 0: Connect a battery charger to your car, if it dies during coding you may brick it. Connect only to the under hood terminals not directly to the battery to avoid damaging the IBS. Make sure you read the protools manual before starting to code, failure to do so can result in damage to your car. Step 1: Connect to your car with protool, after this step you should see a menu screen like so: Credit: F87Source Credit: F87source Credit: F87source Step 2: From the menu screen you will tap on the Electric Steering (EPS) box under the chassis heading, and the following screen will pop up. Credit: F87source Step 3: Click on the coding option and the following screen will pop up: Credit: F87source Step 4: From this screen you will click edit coding and the following disclaimer will pop up: Credit: F87source Step 4: click confirm and back up the current coding for your car. This is a critical step incase errors were to occur. Afterwards the following menu will be displayed: Credit: F87source Credit: F87source Credit: F87source Credit: F87source Step 5: Scroll down to “Variantencodierung Normal” and click on it, the following steering coding options will show up (these options are the chassis codes for each possible car, typically you should code only the chassis codes that share the same steering rack as your car otherwise you risk damage. So for example the m2 can have the m3 and m4 codings and vice versa, as they share the same rack. If in doubt look on the forums to see what others have done before doing anything risky. If you code a non compatible chassis you can get errors, also avoid the not supported, custom, or veh options - only select valid chassis codes AGAIN IF YOU ARE UNSURE DON’T DO IT, RESEARCH THINGS CAREFULLY). Credit: F87source Credit: F87source Credit: F87source Step 6: select on the desired chassis code, for me I selected F087CS. Once you have done so click on confirm, and then finalize to finish coding your car. You may be told to cycle the ignition afterwards, so follow the instructions on your screen. Step 7: Disconnect from the car and you are done! If there are any other instructions to follow protool will let you know and you should follow them. Otherwise enjoy your new EPS/steering rack coding!
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
03-24-2023, 10:50 PM | #2 |
Rep 7,429
Reserved for future posts.
05-23-2023, 06:53 AM | #4 | |
Rep 7,429
Why would you need FSC injection when you're trying to FDL code? I believe you're doing something wrong, if you need help please post screen shots or contact protool support.
06-14-2023, 03:27 AM | #5 |
Rep 6
Which chassis code will be best for me? F30 '16. 320i
I have a problem with a heavy steering wheel when im parking or at very low car speeds. I would like a lighter steering wheel control when the car is not moving. |
06-14-2023, 03:42 AM | #6 |
Rep 7,429
I don't know, you should try all of the settings and pick one you like the best.
08-03-2023, 09:13 PM | #7 |
Rep 1
Coding new steering rack
So I’m having to replace my steering rack and was wondering if anyone knows how to use protool to code the new rack ro the car. I’m very new to protool and the coding aspect. PLEASE HELP!!”
08-03-2023, 10:24 PM | #8 |
Rep 7,429
You should email protool for help, they should be able to point you in the right direction.
08-04-2023, 03:48 AM | #9 |
Rep 2,047
08-05-2023, 01:30 PM | #11 |
Rep 770
Servotronic steering needs and FSC code installed for the variable steering to work in different drive modes.
08-05-2023, 01:57 PM | #12 |
Rep 7,429
Ah I see, you can do fsc injection via protool so I'm not sure why it failed for you
08-25-2023, 01:58 PM | #13 |
Rep 2
Drives: 2014 BMW 435i xDrive M Sport
Hi guys, I am currently driving a 2014 BMW 435i xDrive 6MT. When decoding my VIN, I saw nothing about steering whatsoever so it is my belief that I at minimum do not have VSS.
Here is my Concern/Questions: I came from an e46 ZHP and steering was phenomenal on it, I would like to get my 435i as close as possible to it. I drove my friend's 2019 M4CS the other day and the steering was insane. I was shocked. I'm just wondering if it's possible to code the M4CS steering onto my 435i. From the research that I have done, I found that the steering rack on the M4 and 435i are not the same but I also read that the M4 simply has a larger motor. Would the code work on my 435i? Would it damage it? I would appreciate any input. Thanks |
08-25-2023, 02:51 PM | #14 |
Rep 770
It is not possible. I looked into variant coding the rack last year. The only really worth while variant for our rack is the 135i, and it was a minimal difference. Some people have had luck changing the EPS max current from 105amps to 80 amps. This effectively reduces the amount of power assist. But I didn't notice much difference to keep it that way.
08-25-2023, 03:26 PM | #15 | |
Rep 7,429
10-16-2023, 11:46 AM | #16 | |
Rep 239
Drives: '17 M240i 6MT
If any of these look like they're worth changing from "initwert" to "FF" I'm willing to be the guinea pig.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
02-09-2024, 02:06 AM | #17 |
Rep 7
02-09-2024, 03:28 AM | #18 | |
Rep 7,429
With protool they're based in the US, and I would assume American liability laws are different and allow them to be immune from anything that may arise from allowing providing a means to perform such coding.
03-07-2024, 03:31 PM | #20 |
Rep 7,429
I'm not sure. You should email protool to ask.
