08-12-2023, 02:34 PM | #1 |
Rep 125
Is BimmerUtility the only way to properly code with ESYS?
Let me start off by saying I'm not an expert when it comes to coding at all, I mainly rely on BimmerCode and BimmerLink to do the job. My NBT Evo is retrofitted and I cannot really access the HU module with BimmerCode no matter what I try, and it's probably because the HU is retrofitted rather than stock. My only other option is Esys, and although I used it successfully in the past, things seem to have changed when it comes to tokens and stuff like that, rendering it a bit useless for me.
What are my options here if I want to code the Head Unit with Esys? Would I have to buy BimmerUtility or are there alternatives out there? Thanks |
08-12-2023, 03:37 PM | #2 |
Rep 94
Take a look at bimmergeek’s protool.
It’s android only, but it’s far more powerful than BimmerCode and easier than esys. I used to to VO code a 6WB cluster to my car and have been using it since. |
08-13-2023, 05:59 AM | #4 |
Rep 125
Sent them a message. I'd rather avoid having to buy their adapter or cable because importing those from abroad would cost me way too much money in terms of international shipping, import fees, and customs. I wouldn't mind buying a software-only license and either using my own vgate BT adapter or enet cable. Thanks for this!
08-15-2023, 08:43 AM | #5 |
Rep 50
Protool is the way, my friend. It has every single capability of E-sys, save for flashing a DME. Totally worth the money, and their customer service, with the ability to code remotely, is like having the dealership at your service for free.
08-22-2023, 09:35 AM | #6 |
Rep 125
Thank you for this. I contacted them about buying a license but it seems as though I’d need to buy their own OBD adapter, I really wanted to use the Vgate one I have rather than having an adapter shipped internationally for a lot of money and time. They also told me I can probably use my ENET cable with an Android phone using an Ethernet adapter of some sort, so I’ll probably look into that.
08-22-2023, 11:32 PM | #8 | |
Rep 94
I’m pretty sure if you can connect to esys with your adapter you can connect to Protool. |
08-24-2023, 10:16 PM | #9 |
Rep 1,117
08-24-2023, 11:47 PM | #10 |
Rep 2,047
08-26-2023, 05:14 PM | #11 |
Rep 7
TheNine90
How? could you please PM me? I'm trying to code an F45 but have my previous E-Sys Launcher expired and would need FDL coding. Last edited by stone86; 08-26-2023 at 05:26 PM.. |
08-26-2023, 11:56 PM | #12 |
Rep 2,047
10-07-2023, 11:16 AM | #15 |
Rep 16,083
10-08-2023, 08:16 AM | #16 |
Rep 593
Drives: 2018 F48 X1 xDrive 18D
But there is for older models.
Tokenmaster Launcher Pro 2.81 with lifetime token and older e-sys is free. |
tarekelsakka32.50 |
10-08-2023, 11:08 AM | #17 | |
Rep 332
Unfortunately, it looks if TM has given up as he hasn't posted or updated anything since Nov 2022. His website is now inaccessible. |
Billfitz8243.00 |
10-17-2023, 03:10 PM | #18 |
Rep 4
Hi, I am currently trying to FDL-Code my retroffited TRSVC but without BimmerUtility this is not a fun. My Car is from 2014 and I suppose, the old version would works fine for me. Can someone please share the link for the Tokenmaster Launcher Pro 2.81 with lifetime token and esys? Thanks in advance!
03-13-2024, 08:30 PM | #20 | |
Rep 125
