BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Retrofit auto dimming mirror possible?
      04-12-2014, 02:24 AM   #1
Terabyte
Austria
18
Drives: BMW F30 316d
Hello
Is it possible to retrofit Inside auto dimming mirror?
And what Hardware will be need?
- New Mirror
- Cable
Something else?
Where do I have to connect the cable?
Thank you
      09-11-2015, 07:21 AM   #2
softestplease
Drives: F34 GT
I am also want to know if this is possible, has anyone successfully done it?
      09-16-2015, 09:07 AM   #3
TePee
Drives: F34 LCI MY2019
Normally you just need to connect power & ground cable and it will already work.
If you want full function, you need the reversing signal etc., but I'd say it's not really necessary.
Of course you have to buy an aut. dimming mirror, which is mechanically plug&play.
      09-20-2015, 11:13 AM   #4
radair
radair's Avatar
Drives: G26 i4 M50
Hi
It is quite simple.
By a electrochrome mirror.
By the correct plug with cables (see etk.cc) from BMW.
Connect the loose ends of the cables with the rain sensor cables.
--> there are three pins (look into rheingold a there you can find the wiring plan)
One is ground, one is power 12V and the third is LIN Bus (violet/black).
The LIN Bus is necessary to get all electrochrome functions like no dimming when the interior light is switched on.
Good luck!
Greetings Radair
      09-20-2015, 12:15 PM   #5
vithy
Drives: 2016 F30 328xi
Terabyte, have you looked into this? I want to get this done too. Let me know if you made any progress.
Originally Posted by Terabyte View Post
Hello
- New Mirror
- Cable
Something else?
Thank you
      09-20-2015, 04:36 PM   #6
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Originally Posted by radair View Post
Hi
It is quite simple.
Good luck!
Greetings Radair
Any idea where I can get rheingold from? Thanks
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      10-18-2015, 01:51 AM   #7
Terabyte
Austria
18
No. I haven´t done this till now.
But I think the best way is to put the wires to the FEM, like it is OEM
      10-18-2015, 05:21 AM   #8
Tcheslavie
Drives: F33
I have done it. Pretty straight forward operation. You can connect all wires to the rain sensor and it would work fine, however the mirror uses the KL30 power from factory comparing to the KL15 for the rain sensor.
      10-19-2015, 08:17 AM   #9
popi2009
Drives: F30
it is not that simple.
I have a rain sensor in my F20 - I have bought an autodimming mirror from another F20. If I connect just power and ground it DOES NOT WORK
If I connect it to another car that had the dimming mirror - the mirror works well
What I noticed there are 4 cables to work with
+12v
Ground
GEAR SENSOR
4th cable that works with map lights (map lights on - the mirror does not work)
what is funny on the gear sensor you have about +8V when you select reverse it drops for a second to 0V and then +8v again
Any idea how to make it work? Remember +12v and ground - NOTHING WORKS
      12-10-2015, 09:31 AM   #10
pimp4cheddar
El Capitán
pimp4cheddar's Avatar
Drives: BSM X3M
BUMP...looking to do this on my car.
      01-16-2017, 08:36 PM   #11
boafriend
Drives: 2012 BMW 328i
I am interested in doing this too, in addition to the side mirrors, for my 2012 328i, but was told by a German specialty shop I go to that BMW told them it will cost $10k to retrofit since my car wasn't factory built with the necessary wiring. Apparently a lot of wiring needs to be installed That $10k is obviously bull, but I'd like details from anyone who has been able to do this.
Anyone have any success in doing this?
I found a thread from Bimmerfest but there aren't any more details aside from a pin connector map.
      05-12-2017, 02:30 PM   #12
omorzo
Always on track!
omorzo's Avatar
Italy
Drives: 328i
I used the pinout to use the wires of rain sensor. The dimmer works!
      08-08-2017, 06:34 PM   #13
cgnavarro
Drives: 15MY F30 320i Sport
Hi all, I am trying to do this retrofit too and I just checked the bimmerfest post, my car is an F30 2015 320i Sport.
I have a mirror from a donor vehicle with options S430 (Interior/outside mirror with auto dip) and S431 (Interior rear-view mirror with auto dip)
This mirror has 4 cables: (I tested it with a power supply and compass and homelink worked fine, but no auto dip at all)
Pin 3 - (+)
Pin 6 - LIN
Pin 9 - LED for alarm status
Pin 10 - GND
My car only provides wiring for Pin 9 an 10, so the FEM does not know there´s a mirror.
Rain Sensor looks the same with the 3 wires, as described in that other post, the pinout should be:
Pin 1 - (+)
Pin 2 - Lin
Pin 3 - GND
Do you think if I wire it, this can work? I´m wondering how the LIN bus assigns a new LIN ID to the new discovered mirror if the FEM was configured to not have it.
Has anyone else tried this from manual mirror to auto dip?
Thanks in advance.
      08-09-2017, 02:25 PM   #14
dob4odob4o
Drives: f25
i have done this. check ista-d for wires setup there are 2 variants high and basic
      08-18-2017, 03:11 PM   #15
cgnavarro
Hi, I don´t have ISTA, do you think you can help me with the diagrams needed?
thanks!
      08-20-2017, 04:37 PM   #16
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
Very easy if you have the rain sensor:
Rain sensor;
PIN Type Color
1 + Red/White
2 LIN Violet/Grey
3 Ground Brown/Black
Mirror;
PIN Type Color
3 + Red
6 LIN Black/White
10 Ground Brown
Coding info:
Without VO;
FEM_BODY;
FEM_01 > PfInternalMirror 3120 > ISP_EC = aktiv
FEM_01 > PfInternalMirror 3120 > ISP_KOMPASS = nicht_aktiv
FEM_01 > PfInternalMirror 3120 > LIN_ISP_VERBAUT = aktiv
FEM_01 > PfInternalMirror 3120 > PF_INMI_LIN_VAR = ISP_g_EC
With VO;
FEM with 431 option
      08-21-2017, 08:23 AM   #17
cgnavarro
Rain sensor;
PIN Type Color
1 + Red/White
2 LIN Violet/Grey
Mirror;
PIN Type Color
3 + Red
6 LIN Black/White
10 Ground Brown
Coding info:
Without VO;
FEM_BODY;
With VO;
FEM with 431 option
Thank you very much! I just wired (+) and (LIN) to the mirror and it worked! Luckily I did not need to code my car as the LIN commands were already available in the LIN Bus to make the mirror work. Even the console intensity control is able to dim the compass intensity.
Thanks all for helping out and contributing, I can provide pictures or any additional details to anyone interested, just send me a PM.
      12-07-2017, 07:58 PM   #18
Jhnblckwood
Drives: F30 2014 320i xdrive
I heard u only have to code if u want the dim to not work during reverse. Anyone confirm that?
      04-07-2018, 07:34 PM   #19
Jhnblckwood
I installed mine same way everything worked without coding but ista gives error. I coded fem and still get errors so while u can connect to rain sensor jus kno u will get errors n when u go for service it may cause problems. Didn’t for me but I told them not worry about anything electrical jus change my oil since I’m under warranty but afraid if something major was wrong they could try n blame that idk. U been warned.
      11-29-2019, 01:41 PM   #20
valenperez
Drives: BMW X3 F25 2013
Rain sensor;
PIN Type Color
1 + Red/White
2 LIN Violet/Grey
Mirror;
PIN Type Color
3 + Red
6 LIN Black/White
10 Ground Brown
Coding info:
Without VO;
FEM_BODY;
With VO;
FEM with 431 option
I need your help !!
What is the Retrofit option in ISTA+ ? (is for F25 chasis)
To many thanks
      03-01-2020, 11:12 AM   #21
BMWcompas
Netherlands
Drives: BMW G31
Thank you all for the information. It works great. I didn't even need coding.
First I connected the mirror GND and +12V in test an thought the mirror was defective. Later I decided to install the mirror anyway and connected GND, LIN and PWR. I made a splitter cable from the Anti Condens Sensor of the Climatronic (also behind the mirror). It worked right away.
I didn't have a rainsensor but I do have Automatic Climate Control.
It worked without coding, even the revese signal disables the dimming!
      07-13-2020, 12:05 AM   #22
Gidimba
Drives: BMW 320i (F30) 11/2013
Hi guys,
Where can I fond the cable for the auto dimming on the mirror?
2014 F30 320i
H
