02-25-2014, 09:53 AM | #1 |
Rep 1,894
Coding for adaptive headlights in Europe
Hi all,
I appreciate that a majority of people on this forum drive on the right side of the road. In the UK we drive on the left, and when I cross into Europe I need to switch off the adaptive headlights, otherwise I'll be blinding the oncoming traffic. I'd like to investigate if this can be changed via coding, and maybe like the DRL ON/OFF option, maybe something that can be coded and then changed in the iDrive menu. Can anyone point me in the direction of where the lights/adaptive lights coding section is? |
02-25-2014, 10:11 AM | #2 |
Rep 1,892
Lights are controlled in the FEM_BODY.
The camera is either FLA3 (for HBA only) or KAFAS (if you have SLI, front/side cameras, etc). You will have one or the other, not both. Good hunting! |
02-25-2014, 06:56 PM | #3 |
Rep 40,648
He wrote AHL, not HBA.
FEM_BODY => C_BLC_ENA = F30disable should disable AHL.
02-28-2014, 03:32 AM | #4 | |
Supreme Being
1804
Rep 5,425
Adaptive Headlights left/right hand drive KAFAS>3050>LEFT_OR_RIGHT_HAND_DRIVING>>LEFT or RIGHT Enable DRL options in iDrive HU_NBT>3000> DAY_DRIVINGLIGHT>PERM_ON or STANDARD
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
02-28-2014, 06:08 AM | #5 | |
Rep 1,894
Have you tried the LEFT/RIGHT coding yourself? Be good if there was a new option in iDrive (like what they have in Mercs). |
02-28-2014, 04:54 PM | #7 | |
Rep 40,648
Automatic High Beams (High Beam Assistant) only uses cheaper FLA Camera.
02-28-2014, 05:04 PM | #8 |
Rep 1,894
Doh. Those I don't have.
The Visibility Pack in the UK comes with:
It could well be the adaptive headlight for right hand drive cars are physically different from the left hand drive, the part numbers are different on realoem....if so this who thread is dead in the water. |
02-28-2014, 05:11 PM | #9 |
Rep 40,648
So, you have nothing in the Visibility Pack that requires KAFAS Camera, which is why you have FLA Camera instead.
03-05-2014, 04:57 PM | #10 | ||
Supreme Being
1804
Rep 5,425
My assumption is the same settings will be somewhere I the FLA module settings - I've not checked yet. Will let you know if I figure it out.
03-06-2017, 02:39 PM | #11 |
Rep 444
Did anyone solve this in the end?
I need to programme my left hand drive 2012 F30 with CIC, active xenons and active full beam. I have Speed Limit Information but no Lane Departure Assistant; according to the above, though, I should still have the KAFAS camera (or KAFAS2 as it's called in my coding tree). I've tried changing "KAFAS>3050>LEFT_OR_RIGHT_HAND_DRIVING>>LEFT or RIGHT" but the options I get are "right_hand_driving" or "left_hand_driving". The default is "right_hand_driving" so presumably this is referring to the side of the road, not the side of the car the steering wheel is on. I've tried changing it but it keeps reverting when I re-open the KAFAS2 coding menu, whether I'm doing the programming online of offline. Saving doesn't seem to achieve anything. What's puzzling me is that above, the KAFAS and FLA modules are referred to as different versions of camera, but in my KAFAS2 coding options 3050 is listed as "3050 FLA_CODING, 20". Anyone got any idea what's going on? Or is it another option that I should be changing? |
03-07-2017, 10:50 PM | #12 | |
Rep 1,986
As noted, the headlight assembly is different for right hand drive. So UK anti-dazzle will blind drivers in EU, if this is your wanted end result. No way around that unless you want to change headlight assembly every time you go through Chunnel. |
03-08-2017, 01:05 AM | #13 | |
Rep 512
Drives: 320i M Sport Shadow Edition
What I found out is the with the Focus there was a leveller within the headlight unit that operated a lens shutter that can be slide which effectively blocks the glare pattern to the left for right hand drive cars. The reason for this function is that you were not supposed to apply the lens deflectors on the headlight unit itself. Here is a picture of the Focus light unit with the lens shutter, not sure if this is also possible on the BMW but worth a shot. [IMG]http://i821.photobucket.com/albums/z...pszcmgxsay.jpg[/IMG] |
03-08-2017, 01:22 AM | #14 |
Rep 444
Thanks guys. The thing is that I don't have standard Xenons, I have adaptive xenons with adaptive full beam. Checking my vehicle spec from when I bought it I have:
522 Xenon Headlights 524 Adaptive Headlights 5AC Highbeam Assistant I thought that having Adaptive Headlights and Highbeam Assistant meant that I could just reprogram the throw of the lights. I don't think there's a lever as the mechansim for these systems is quite complex. Or did the technology change shortly after I bought my car, as it did with the iDrive?? |
03-09-2017, 08:23 AM | #16 |
Rep 1,894
I've coded the option but it doesn't work.
03-10-2017, 03:29 PM | #17 | |
Rep 444
I see you have NBT. What year is your car? What headlight options do you have? I really want to get to the bottom of what's needed to change the lights between LHD and RHD as noone seems to know! |
03-10-2017, 08:16 PM | #18 | |
Rep 1,986
Changing the Headlight Assembly is ONLY option with Xenons. It's a hardware issue, nothing that can be coded. Otherwise, you will need to use manual High Beam in Europe with UK Car. |
03-11-2017, 12:29 AM | #19 | ||
Rep 444
03-11-2017, 12:36 AM | #20 |
Rep 444
OK so I've eventually found they're now using LEDs for the main headlight too - I hadn't realised that. So it's only cars with LED main headlights that support the side of the road being changed in the programming. Man, that's annoying. Doubly so that it's not really explained properly unless you dig and dig.
03-11-2017, 12:23 PM | #21 | |||
Rep 1,986
http://f30.bimmerpost.com/forums/sho...&postcount=192 Last edited by Kabrich; 03-11-2017 at 12:28 PM.. |
03-12-2017, 12:24 PM | #22 |
Rep 444
Dude. That isn't exactly what you told me twice. Your initial post wasn't clear to me as I didn't even realise LED mainbeams were a thing - I thought it was just the DRLs that can be LED - which is why I asked for clarification, which you didn't answer until I posted again. And I'd never seen your other thread before you linked to it in your last post - even if it had come up in my search I wouldn't have read it because it's about retrofitting US cars with European adaptive full beam which wouldn't have seemed relevant. And besides, it's 11 pages long, so it's not exactly a "simple" read.
Adding to my confusion is my colleague has just bought the outgoing 5 series with, he believes, "standard" lights - no active headlights or adaptive full beam - so, I would have thought, no LEDs. He has the option in his NBC to change the lights for driving on continental Europe. But for some reason his paperwork doesn't say whether he has Xenons or LEDs, which I do find hard to believe but he bought it cause the dealer had it in stock and wanted rid so he had no choice on options. Anyway, despite all that you're the only one to explain why I've been unsuccessful and I'd otherwise still be chasing my tail on this so for that I thank you . |
